Strange Climate Control Behavior
05-06-2007, 05:53 PM | #1 |
don't anticipate problems, look forward to them...
Rep 21
2 week new owner of a E90 335i, and I don't understand what is happening w/ my climate control. In either mode (auto, or non-auto) the blower will distribute out of the assigned vent, but then after a bit (30 seconds or so) the assigned vent will decrease in volume and be redicted elsewhere, then shift back again to the assigned vent after a few seconds.
I don't know how to describe this better, but it seems to occilate for no apparent reason. Is this normal (if so, what the hell is it doing, and why?) If it's not normal than back into service it goes... :mad: |
05-06-2007, 06:00 PM | #2 |
Rep 582
Mine does this too. I went back to the manual and read through the climate control section. If you have iDrive you can adjust the intesity of the "Auto" control from ...eh, "light" - medium and intensive. If you set the temp and hit the auto button ...it still cools the cabin, but as you said directs the airflow somewhere else. The manual says that is automatically distributes airflow for optimum cooling/heating of the cabin. When it is on manual it directs airflow where I tell it to...at 4 bars of fan speed it comes out at a reasonable pace, not like what i'm used to...but there are vents in the rear as well that may be taking the punch out of the front vents. I haven't bothered to mess with it...the a/c and heating still work very well.
I think this is normal...just unusual how they designed it. Still cools and heats really quite well I think even though the air isn't blasting in your face all the time. Even so, if you have the opportunity consult with the dealer about it and see what they say...i'd be interested to know. |
05-06-2007, 09:18 PM | #3 |
Rep 21
Ok, good to know..
a) I'm not imagining this b) My car is working 'correctly' (although mysteriously designed) c) I'm not the only picky bastard who would notice. I'll talk to the ONLY decent contact I have here in San Diego at the dealer - another thread on the dealer service nightmare later... |
05-06-2007, 09:25 PM | #4 |
Rep 3,011
the auto function works great, IF you are patient. You won't get a blast of cold air in your face, but you will get cool after about five minutes.
"Teach the ignorant. Ignore the stupid."
05-07-2007, 08:55 PM | #5 |
Rep 215
Drives: 335i Coupe
Last month I received the software update 25.00.02 and though my idrive responds with greater speed, my fan is now "cycling", which it didn't do before. Sounds like you need to get the latest software update which will handle the cycling problem. I'll be taking mine back in next week to handle this issue.
e92/Black Sapphire/Coral Red/Aluminium Trim and Pedals/Sport/Luxury/Nav/Keyless/Ipod Adapter/6MT/Sirius/Turbo Tuner
05-08-2007, 09:54 PM | #6 |
Rep 36
05-09-2007, 12:49 AM | #7 |
Smiling politely
165
Rep 7,931
Yes and yes. Once you hit Auto, the A/C button lights up and stays lit.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
05-09-2007, 09:40 AM | #9 |
Smiling politely
165
Rep 7,931
Maybe they've changed the way climate control works on the 335i versus the 330i, but on mine, once I turn on "auto," both it and the a/c button light up.
05-10-2007, 06:02 AM | #10 | |
Rep 21
Software Sucks
I drove another 335i this weekend that did NOT exhibit this odd behavior. It only made me more frustrated to see it working correctly... :mad: I've actually got a better description of the cycling issue: it seems that the system is cycling between fresh and recycled air. This is part of the 'auto recirculation' system, but seems to have a mind of it's own with this new software version. |
05-10-2007, 07:50 AM | #11 |
Rep 1,035
Also, check out the air quality/recirculation button. I found that if I have this in auto mode, and the car decides that the outside air quality is sufficiently poor that it needs to switch to recirculated air, it sometimes changes the vents it's using. I don't know why it does that, but it has happened once or twice, and it went away when I turned off the auto air monitoring feature.
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
05-10-2007, 05:21 PM | #12 | |
Rep 21
05-11-2007, 07:46 AM | #13 | |
Rep 1,035
05-12-2007, 11:09 PM | #14 |
Rep 21
RESOLUTION
When the dealer installed the iPod interface the box which contained the A/D and control was place in a location which interfered with the movement of the recirculation vent.
The result was that the recirculation vent was unable to close completely and would try then reset to the fresh air position. It would wait for a number of seconds and then try again; thus causing an oscillation in the system. Once the iPod interface box was moved the problem was resolved. The shop foreman has entered a note to have the iPod installation updated to reflect this potential problem in the future. |
05-13-2007, 08:14 AM | #15 |
Rep 582
Strange. I didn't mention it at the time - my fathers 535xi does the same thing as my 335xi.
He does not have an iPod adapter like the 335's need. His comes with the USB port in the armrest and just has a part to connect the iPod and...anyway there was not "install" by the dealer such as there was with my iPod. Maybe your particular dealer messed something up, but since the Auto program acts like this in the 535 - i'm inclined to think it is normal. |
05-14-2007, 05:00 PM | #16 |
Rep 215
Drives: 335i Coupe
Had progman 25.01.1 installed today and will pick her up tomorrow. The cycling issue with the a/c is supposed to be handled. We'll see and I'll let you guys know.
05-14-2007, 05:08 PM | #17 | |
Rep 215
Drives: 335i Coupe
cycling
05-15-2007, 04:33 PM | #18 |
Rep 110
My 320 D has had this issue from new.. March 2006. It was on progman 23 but was updated to 24.0 three months ago... but no better....
I reported it to my dealer.... they said it was definetly a component... but still it does it. It only happens in very hot weather... not often here in the UK.... the cycling is very annoying. I am due version 25 next week, so I will se how that goes... |
