Clock Spring Installation
10-22-2011, 09:56 PM | #1 |
Rep 219
Drives: 14 BMW 335xi M-Sport EBII
So long story short. I was installing my Paddle Shifter Retrofit kit and I broke my old clock spring so I bought another one.
installation was simple. I pointed the wheels completely straight, removed the old clock spring and installed the new one and everything felt great. Then i backed out of a parking spot and turned the wheel hard to the right and I felt something pull loose. None of the buttons on my steering wheel work any longer. Luckily I don't seem to have an air bag failure (yet?). So what Did i do wrong? Am I supposed to install the clock spring when the wheel completely turned to the left or right? I didn't break off the red tab until it was installed to the car so there is no chance that i moved while outside of the car. Anyone else familiar with the clock spring? I am not happy spending another $100+ bucks on another clock spring. The Bentley manual had nothing on the subject. According to TIS I replaced it properly as well (see attachment) EDIT: Installed new one. Broke in the exact same manner. Last edited by nemith; 01-25-2012 at 11:15 AM.. |
11-06-2011, 05:25 PM | #3 |
Rep 219
I took out the clockspring and used a multimeter to test continuity on the wires/traces. They are all broke except the 4 traces going to the steering wheel heater.
So has anyone replaced a clock spring? Looks like i need to buy another one (another $100 down the drain), but I don't want to break the new one. Anyone know what I did wrong when installing it. Again the steering wheel was straight. I installed the clockspring and then broke off the red tab. Everything was lined up straight. Edit: I opened up the clock spring and you can see connections disconnected: View post on imgur.com View post on imgur.com Last edited by nemith; 11-06-2011 at 05:43 PM.. |
11-06-2011, 05:28 PM | #4 |
Rep 2,396
I have my old clockspring if you want.
http://www.e90post.com/forums/showthread.php?t=597765 |
11-06-2011, 05:45 PM | #5 | |
Rep 219
11-08-2011, 09:38 AM | #8 | |
Rep 219
Looking at doing a retrofit? I don't think it would be that difficult. The heater button is one the steering wheel column and goes directly into the harness. Although I haven't traced anything out. |
11-08-2011, 01:20 PM | #10 |
Rep 2,396
Make sure your wheels are straight when you are installing the clockspring!
What probably happened is that you had the steering wheel turned either one or two rotations in either direction. |
01-23-2012, 09:50 PM | #12 |
Rep 219
Ok Wheel and TIRES were completely straight. Replaced the clockspring with a brand new one. Went no longer than a day and broke the new clockspring again!
So apparently this is not the correct way to install a clock spring or I happened to got two faulty clocksprings or installing it with the wheel straight is the wrong way to install it. Last edited by nemith; 01-25-2012 at 11:14 AM.. |
03-03-2012, 06:30 PM | #14 |
Rep 219
Still no clue, broke another clock spring in the mean time.
05-03-2012, 11:03 AM | #15 |
Terorist!
29
Rep 315
hello
can you help me with some info pls. i have a e90 2006.i have a steering wheel heated and i want to instal it on my car. can you help me with a part no for that pice what need to be replaced? it's posibile to replace just the conectors from the steering column? when you say steering wheel clockspring you reffer to foil with wires? if it's posible to change just foil with wires can you give me a part no pls? thnks
E90/320d/163cp/2007/black/retofit LCI front/rear/Mtech/style 162/M3 mirrors/auto dimming mirrors int-ext/EIBACH PRO KIT/M3spoiler/Performance Kidney Grills/MT/shadow line/M shift knop/M3 steering wheel cover/M footrest/M door sills/M handbrake/Performance aluminium pedal pads/sunroof
___________(Oo) (|||) o (|||) (oO)____________ |
05-03-2012, 11:35 AM | #16 |
Rep 405
I am by no means an expert but this is what how I would do it if I ever needed to do it myself.
First make the steering wheel straight as you did before, wheel straight in center. Take the clock sprint and with your finger rotate it all the way to clockwise and then reverse it all the way to the anti-clockwise direction. Make a note of number of full rotations and make sure you rotate it back in the middle of both the extremes. Reason for rotating rings to both the ends is to ensure you can find a center position. Only thing I see wrong in your failed installations above is your steering wheel has been centered but your ring wasn't, thats why it broke. Hope it helps.
650i F12 - HUD, 6WA, SLI, Logic 7, Dynamic and Adaptive Drive, Comfort Access, Soft-close, top-view,
Previous X5 40d M Sports and 535d LCI |
12-13-2014, 01:11 AM | #17 |
They say I'm Invincible
22
Rep 85
Did this ever get resolved? Might be attempting mine here soon. Same thing here, the controls and paddle shifters are not working, the horn still works though. Odd.
IDKWHP|IDKWTQ |
12-13-2014, 09:40 PM | #18 |
all day
48
Rep 1,181
Drives: 2012 135i
I messed with my clock spring and I just had to make sure the arrows on the back lined up and it was all good. Now my only issue why my horn keeps staying on.
12-19-2014, 03:55 PM | #19 | |
Rep 718
I read on another forum a guy just fixed the connector for his buttons. I may take my wheel off this weekend and see if I can do that rather than getting a new clock spring.
04-07-2019, 10:37 AM | #20 |
Rep 996
Old thread but anyone looking to replace a clock spring, make sure the actual clock spring unit is centered.
The clock spring can rotate around 6 full turns so make sure it’s right at the middle at 3 turns from both left and right before installing the steering wheel straight. I think some of the issues above are from the clock spring being removed from a car that wasn’t centered. |
08-24-2019, 01:36 PM | #21 |
Rep 185
Sorry to necro an old thread but how does one make sure the clock spring is centered?
Edit: Figured it out (I think.. is this right)? - There's a white pin on the front of the clock spring assembly, and if it's at the 4 O'clock position the clock spring will be locked in place (will only move 10-15 degrees left or right) - Pressing in the white pin and holding it will allow the clock spring to rotate freely. - Turning it all the way counterclockwise from center is about 3 full turns Last edited by Canuck335; 08-24-2019 at 03:12 PM.. |
08-30-2019, 04:59 PM | #22 |
Rep 420
Drives: E92 335XI (sold)/E92 M3 (sold)
Another necro here.
A few people have stated its 6 full turns left to right. This is wrong. There is no center with 6 full turns. The clock spring has 5 full rotations. From all the way over from counterclockwise to the center is 3 full turns...same as from clockwise to center. With the clock spring, full left 1 to 2 - ( 3 center ) - 2 to 1 full right. With ur steering wheel centered, you can turn just over 1 full rotation from center to full left and from center to full right. From 3 center, 2 left clock spring turns = 1+ steering wheel left turn. From 3 center 2 right clock spring turns = 1+ steering right wheel turn. |
