10-21-2011, 02:23 AM | #1 |
Rep 234
Dinan Stage 2
Dinan stage 2 is just a software update. Did Apple charge extra for iOS5?When I first got my Dinan stage 1, I was wondering what everyone was raving about on the forums. I kept asking myself where is all this power? First gear, not sure maybe a little stronger, second gear, the same, third gear, not yet, ......wait, 3000rpm...... Ok here it is! I thought there was something wrong with my tune. Several reflashes and many calls to dinan and it was the same. Dinan denied that there was any problem with the tune. They never admitted that the tune didn't make full power in the first two gears.
They advertised their ecu flash making 570 lbs of torque. When they charged you $3000 (- discount for some) Did they tell you it doesn't make that kind of power until 3rd gear? I did not expect this from a company that takes pride in their reputation. Since I'm already knee deep and invested, I did pay for the Stage 2 update, but think it should have been handled differently. To their credit, Dinan did wave the labor charges for my stage2 and they do offer a revised stage 1 for free to people who had the early stage 1 tune (they claim full power in all gears in this revised tune)Stage 2 is really about the same in the top 6 gears. Power comes in maybe about 500 rpm earlier. In the first two gears, you can really feel the difference because full power is now available. Apparently, they removed the torque limiters that BMW had placed in those 2 gears for safety. |
10-21-2011, 09:56 AM | #2 |
Rep 119
I was dissappointed with my Stage 1 also. However, I am pleased with Stage 2 as it feels much improved, especially in first two gears. I was considering selling my car prior to getting the stage 2 but now its a keeper.
10-21-2011, 11:02 AM | #3 |
Rep 17
Thank you guys for making me spend more money.... now I'm on the phone trying to set up an appointment to get the stage 2.. lol, thank god for this discount Dinan is running this month!
10-30-2011, 09:32 PM | #7 |
Rep 119
10-31-2011, 10:27 AM | #8 |
Rep 18
11-09-2011, 07:36 AM | #10 |
Rep 177
Quarter mile figures would also be helpful, thanx
F10 550i M-sport: Space Grey/Oyster Black
E39 M5 : Carbon Black/Caramel E39 520i : Titanium Silver/Beige (Sold) |
11-09-2011, 08:27 AM | #11 |
Rep 285
If you search other forums you will find an F10 6 speed manual with Dinan S2 that recently ran the 1/4 mile in 12.99 sec at 112.95 mph. (1/8 mile was 8.58 sec at 88.76 mph). Breaking into the high 12's is impressive for a vehicle of this weight with only a tune.
F10 550i Space Gray | Dinan Stage 5 | Eisenmann Race | ACS springs | 20" Ferric Grey 312 - Michelin PSS
11-09-2011, 09:00 AM | #12 | |
Rep 514
Im guessing I should be able to break into the high 11s.... http://f10.5post.com/forums/showthread.php?t=590292 |
11-09-2011, 09:02 AM | #13 | |
Rep 514
From Dinan's website: The Authorized Dinan Dealer will, without charge for parts or labor, repair or replace the defective Dinan component(s), as well as any original vehicle manufacturer’s component(s) that may have been directly affected by a Dinan component, using new or authorized remanufactured parts. |
11-09-2011, 09:47 AM | #14 | |
Rep 285
The 6speed had traction problems causing slow 60' times (2.155). His MPH at 113mph is headed in the right direction. Are the tracks in your area closed for the season?
11-09-2011, 09:56 AM | #15 | |
Rep 966
You won't hit 11's, but you may be able to shave a tenth off your time. Someone else has done multiple passes with your set up and just Dinan S2 and got very consistent ETs around 12.5. |
11-09-2011, 09:53 PM | #16 | |
Rep 514
Stage 2 and an exhaust has made a very noticable difference and my guess, between the two are easily worth a .3-.4sec savings especially that I dont have launching issues with the 1st and 2nd gear modification. Even if not high 11s, most likely low 12s NOT mid 12s....I was at 12.485 stage1 and the temp was 70 or 75 degrees with a little more than a 1/4 tank of gas....If I can get to the track this weekend, it will be 40-50 degrees with 3-4 gallons of gas....big difference....we will see and I will post if the track is open one more time before the season closes....If not, early spring it is.... Last edited by dmetuning; 11-09-2011 at 10:16 PM.. |
11-10-2011, 01:13 AM | #17 |
Rep 234
I have no official times but I raced against my friends 2010 merc E63. In sport+ from first gear. I walked away from him easily bec my traction controll gives me just the right amount of wheel spin and his TC was cutting in too aggressively slowing him down.
Later on we ran from about 60 to about 120-130. He got a slight jump on me by one wheel lenght (dont know he may have stepped on the pedal slightly sooner but that engine has better throttle response) we stayed neck to neck the whole way. |
11-10-2011, 01:20 AM | #18 |
Rep 234
Also went against a 2009 vette. Not a Zo6, stock engine rental car. from a rolling start of about 10 mph i walked away from him by about 1-2 car lenghts. after he gained traction he stayed at that same 1-2 car lengths, did not gain or loose any ground to about 80 where we had to back off. he could not believe it! The vette was only a one time race, not like the E 63 where we tried many different times to ensure consistant resuls.
11-10-2011, 01:27 AM | #19 |
Rep 234
BTW my plastic engine cover is turning yellow ish in color as a result of extra heat from the turbos which reside just below between the cylinder banks.
I'm considering removing the cover but need to check first with dinnan. want to make sure this will not cause another problem. Any one had experienced the same with their tuned car? |
11-10-2011, 04:51 AM | #20 | |
Rep 966
My guess is you hit 12.39-12.41, but would be happy to be proven wrong! |
11-10-2011, 11:10 AM | #21 | |
Rep 514
11-10-2011, 12:40 PM | #22 |
Rep 966
Good luck!
Hopefully the temps stay warm enough. I went to the track at the end of the season last year in my 335xi with summer tires and could not find traction. Would spin all 4 tires and had to let off to get moving. |
