sub install help needed...
05-03-2007, 04:27 PM | #1 |
Rep 1,599
Drives: Arctic e90 330i
Garage List 06 pre sept model e ... [10.00]
2007 e61 [0.00] 2003 e53 [0.00] my winter ride [0.00] e90post chicago sub ... [0.00] e90post chicago mee ... [0.00] |
I have pm'ed some of you sub/amp install questions and you all have been very helpful. I really appreciate all the help you guys have given me. I just have a few more questions to ask and then I will be installing the sub and amp soon.
I have read that the left channel is wire 8 +, wire 18 - and the right channel is wire 6 +, wire 16 -. Can someone please let me know which wire should be what? I have attached a picture of the amp and labeled the possible wires(1-6) I am suppose to tap. I think I am suppose to use wires 1,2,5, and 6, but I do not know which is what channel and which is + or -. This is for the Logic 7 amp. I am using the PAC trunk-loc. Any help would be very appreciated. Thanks.
......support your local vendors. view my garage for a list of mods.
05-05-2007, 02:36 PM | #3 |
Rep 1,599
my install has been completed. thanks to all of those that pm'ed me with help. i really appreciate it. i just need to tweak my settings a bit and it will be totally finished.
05-05-2007, 02:43 PM | #4 |
Rep 192
can you please post the results i have the exact same question, which wires are power-on, +/- sub pairs? just use your pic and tell me the numbers :-)
thanks! |
05-05-2007, 03:09 PM | #5 |
Rep 1,599
1,2 are one channel and 3,4 are the other channel. you should get a pac trunk-loc if you are gonna do this setup. if you use a pac trunk-loc:
wire 1- (red/blue) will go with the gray wire from pac. wire 2- (brown/white) will go with the gray/black wire from pac. those are the right sub wires. wire 3- (red/white) will go with the white wire from pac. wire 4- (brown/yellow) will go with the white/black from pac. those are the left sub wires. green wire from pac should go on wire 4 (brown/yellow). ground wire form pac goes to ground on car or ground it to the amp(i grounded to the amp ground). red wire from pac goes to +12 on amp. blue wire from pac goes to remote on amp. good luck.
05-06-2007, 06:47 AM | #6 |
Rep 136
05-14-2007, 09:02 AM | #9 |
Rep 179
05-14-2007, 09:07 AM | #10 |
Rep 1,599
it is the one pictured on the bottom of this link. here are the basic instructions for the pac trunk loc. these links were given to me by thd13, when i needed help. i hope these help you out also.
01-02-2008, 11:34 PM | #11 |
Rep 1,003
wow thanks a lot ntp! so you're not supposed to tap into the wires running out from the radio but rather out from the factory amp?
also, why does the "green wire from pac go on wire 4 (brown/yellow)." can you specify what the green wire is? |
01-03-2008, 01:03 AM | #12 |
Rep 1,599
yea you tap into the factory amp. the green wire is the trigger. you dont have to connect it to the exact same wire as i did. you can connect it to any speaker wire. i just decided to follow the pac instructions; so there wouldnt be any confusion. if you need any help; just let me know.
01-03-2008, 02:00 AM | #13 |
Rep 9,032
Why not tap before the amp?
ntp, any pic's of the install?
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
01-03-2008, 02:59 AM | #14 |
Rep 1,599
so all the the work would be kept inthe trunk and no need to run wires from the head unit. also, i was told my other members this was the proper way to get it done in our cars. i have a few random pics of the install, but nothing thorough. if you need help; let me know.
01-03-2008, 08:22 AM | #15 |
Rep 1,003
hey thanks for all the help! any reason why you went with PAC over the other brands? like say stinger? can you just tap into one of the speaker wires already going into the PAC for the remote turn-on? i.e. make a 3 way connection between factory wire, grey PAC, and green PAC for remote?
11-08-2008, 12:53 PM | #16 |
Rep 3,713
hey i follow with your instruction.
i have a pac loc also. my sub make hiss or some kind of weird sound. help me! i tap everything like you say. when i unplug the RCA from amp the sub still make those sounds. help me out. if anyone know why please pm me. but it be better if someone can give me a call. pm me for the number please. i really need this fix Last edited by s1cke92; 11-08-2008 at 03:40 PM.. |
02-18-2010, 03:37 PM | #18 |
Rep 7,089
Drives: '06 AW 330xi
02-18-2010, 03:38 PM | #19 | |
Rep 7,089
Edit: Just realized this question was asked a year ago. Haha |
02-19-2010, 09:39 AM | #20 |
Rep 710
Would you please elaborate how to find a LOC that is compatible. I'm looking to do the install myself. What exactly do i need to make it work? I have an amp and sub already taken from my old car. Can i use a standard wiring kit?
03-27-2010, 04:32 AM | #21 |
Rep 14
03-27-2010, 10:44 AM | #22 |
Rep 7,089
The L7 sub outputs are 70W so a LOC that can handle a 70W or more input would be ok. I'm using a 60W LOC and haven't had any problems so far. I never turn it up that high. You'll know it's not compatible because the LOC will cut out.
