After Market IN DASH NAV,DVD player advice for a non-idrive user
10-11-2011, 08:30 PM | #1 |
Rep 231
I was searching through ebay and found this unit: http://cgi.ebay.com/ws/eBayISAPI.dll...K%3AMEWAX%3AIT
Is it worth upgrading from a stock cd player to something like this. I currently have a prologic7 and rear pdc. As he has listed in his auction tha tit would work, is this a better solution? Also, If I get something like this, do I still need to save my stock player? |
10-11-2011, 09:22 PM | #2 |
Rep 13,104
This guy is asking the same question
http://www.e90post.com/forums/showthread.php?t=596539
When you replace the Logic 7 system with a new head unit you have to replace the logic 7 amp to because it uses a proprietary fiberoptic signal protocol that only the original head unit can provide. Also the original head unit should be mounted in parallel its covered in the above link. its better to buy that unit from caraudio craze for support the price is about the same. Last edited by ctuna; 10-11-2011 at 09:27 PM.. |
10-12-2011, 11:38 AM | #4 |
Rep 13,104
Right
You pretty much have to get rid of everything but the speakers and you probably would want to upgrade some of those. Nothing works with the BMW firberoptic L7 Amp . There are a few products that convert head unit output to toslink format but I don't know of anything that will convert to the BMW format and feed the L7 Amp.
As far as I know there aren't any Head Units in the aftermarket that use a fiberoptic interface and there doesn't seem to be a standard for it in car stereo. Also you should still mount the old system in the car if you want the BMW programmer to be able to update your cars software, the chimes to work, and errors not be displayed on your dash do to the missing connection to bmw SOS . If you read those links you can see there are a few surprised guys who got that dynavin unit and had this issue its the same with all aftermarket head units. From another post Quote: Originally Posted by psychoactive View Post Oh, is the OEM deck part of the optical buss thing that if I remove one item, every device on it will stop working? Thanks again! It's not easy to replace the headunit in e9x. This are findings about it (I have Eur Spec car) The problems with removal of the MID ( it's not just a headunit). 1) You will have to replace all Amps and probably the speakers 2) You will lose the OEM bluetooth, cd changer (if you have it) 3) You will lose the PDC (sounds cames from the speakers) 4) Steering wheel buttons 5) The dealer wont be able to upgrade/diagnose the software in the car The solutions... for Alpine Headunits 1) Use aftermarket amps and speakers(beware of size/depth and locations of the speakers) 2) Get Parrot Bluetooth Kit and the Connects2 Steering wheel adapter(CTPPAR006 or CTPPAR009) 3) Alpine Interface APF-R100BM will enable PDC sound for the rear the sensors, they don't have a solution for both rear and front sensors yet. Connects2 have similar interface(CTRBM001), only for rear sensors also. Dietz has an interface that uses a separated speaker they claim( i haven't test it yet) that works with both sensors although the sound tone is the same for front and rear. 4) Alpine Interface APF-S100BM, this is an CANBUS Interface with Steering wheel buttons integration , it also have Speed Pulse, Light, Reverse and Ignition signals. 5) There isn't solution yet, just keep your OEM headunit and install it when you need to upgrade/diagnose the car software. Last edited by ctuna; 10-12-2011 at 12:01 PM.. |
10-12-2011, 12:06 PM | #5 | |
Rep 231
Thanks for the detailed information.
Thanks ctuna. You saved me tons of headache in digging into the details on all the forums. I had no idea that it's more than just the head unit.
10-12-2011, 12:18 PM | #6 |
Rep 13,104
Modern Cars
Essentially have many computers that are interlinked on and interdependent network and its become I giant headache to add aftermarket stereo. Its not just the Euro Cars now its all of them.
The common thing the L7 guys are doing now is the MS-8 with and aftermarket amp and speaker upgrades. |
10-12-2011, 12:46 PM | #7 |
Rep 231
I'm mainly looking into having a GPS system, DVD and SAT radio along with bluetooth functionality. I dont know much about retrofit that were being offered here. I heard that they are pricey but can I get them to work on my e90?
10-12-2011, 01:18 PM | #8 |
Rep 13,104
Well BMW doesn't do retrofits as far as i know
They would have to give you a whole new Dash for there retro if they
even do it.(assuming you want Nav they can add some of the other stuff for an arm an a leg) And any retrofit that BMW does costs and arm and a leg. You would come in under the cost of doing that with a total aftermarket redo and it would sound better. Thats why a Head Unit retrofit seems the only path . That dynavin unit delivers a lot of gizmos and functions and looks like it belongs in the dash .( and it does it relatively cheaply) I don't know how good the quality is and the software is kind of retro plus I don't think it has pre outs for feeding an amp. (no preouts is kind of lame maybe I'm wrong on that) You have to be prepared to put up with all the stuff you have to do to make the car right though and in the case of L7 that's quite a lot. Last edited by ctuna; 10-12-2011 at 01:25 PM.. |
10-13-2011, 07:44 AM | #9 |
Rep 8,801
search dynavin
there's a thread on this forum. there's a new android version out v6.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
10-13-2011, 11:59 AM | #10 | |
Rep 149
10-13-2011, 12:30 PM | #11 |
Rep 13,104
pkirk do you have one? If you do?
How do you have it setup and whats been your experience so far?
So it has pre outs ? A full set ? Do you use any of the amped lines to drive speakers. Are you able to bypass the amped lines into the harness to drive your amp . Was the harness designed to Interface with the Base System or the Hi Fi System? Did you relocate your OEM Head Unit? |
