E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > changing OEM HIDs on my 330i to aftermarket HIDS
      09-08-2011, 07:10 PM   #1
drshoelaces
drshoelaces's Avatar
Drives: 2006 BMW 330i
Hello e90post!
This is my first thread, sorry if it's kinda noobish, I searched a bit for what I want to do and found no results.
I own a 2006 330i and finally my factory HIDs have gone out on me (only the lowbeams).
After finding out new ballasts and bulbs are over $200 each I began to wonder if it was possible to buy a whole different aftermarket system and put it in (even if it means making a new circuit).
Has anyone else done this? Or can someone point me in the right direction
thank you very much!
EDIT: I guess I should add, a shop told me my ballasts are out. Both low beams not working, both high beams working.
      09-08-2011, 07:39 PM   #2
RupertPupkin
RupertPupkin's Avatar
Drives: Freak Beast
Your HIDs are actually low and high beam. The projector houses one bulb and when you flick the stalk forward a sort of door opens and allows the beam to go higher and wider.
As far as replacment, any D1s bulb will work if it is just that, or check out any number of the vendor sites. New bulbs in many K varieties can be had for around $100. If it is the ballasts as well It may be another issue.
FYI the inside bulbs towards the grilles without a projector lens are actually the flash to pass bulbs. They come on briefly when you pull back on the stalk.
Is it both sides, or just one of the HIDs?
Hope that helps.
      09-08-2011, 07:43 PM   #3
RupertPupkin
Drives: Freak Beast
Here:
http://www.jlevistreetwerks.com/3-Se...duct_info.html
OR
http://www.ecstuning.com/BMW-E90-330...ghts/ES256094/
      09-08-2011, 07:44 PM   #4
RupertPupkin
Drives: Freak Beast
Cheapest:
http://www.helix13.com/3-series-bmw/lighting/#go
OEM is 4300K
6000K is whiter, 8000k is Whiter still/almost blue
      09-08-2011, 11:20 PM   #5
drshoelaces
awww you guys are so helpful!!
thank you!!!
A shop told me it was my ballast and not my bulbs . You guys know a cheap ballast site? I haven't turned up anything.
However! my high beams still work (both), but both my low beams are out.
thanks again for all your help - you e90 guys are cool.
      09-09-2011, 06:18 AM   #6
Vesar
Vesar's Avatar
Greece
71
Drives: 320i Ε92 M-Sport
2007 BMW 320i  [10.00]
thank you!!!
They told you this because they thought you ve got h4 or h8 type of bulb which is FAIL. Our cars have D1S type of bulb
      09-09-2011, 06:41 AM   #7
drshoelaces
so what you're saying is, my ballasts are fine, it's just my bulbs? (my car has 115k miles on it)
thanks again
      09-09-2011, 07:19 AM   #8
Vesar
Vesar's Avatar
Greece
71
thanks again
There are too options.
1) your car has projector headlights which you need to replace the D1S bulb
2) your car has reflective headlights which doesnt have oem HID only a H7 halogen bulb
      09-09-2011, 09:14 AM   #9
drshoelaces
yea I have the projectors.
thanks
      09-09-2011, 10:20 AM   #10
fdriller9
Drives: '06 AW 330xi
2006 330xi  [6.44]
All US spec 330s had xenons standard.
It doesn't make sense that your high beams work and your low beams do not.
Our cars have 2 sets of high beams. The xenon high beams, which are activated by pushing the stalk away from you. Or halogen high beams , flash-to-pass, which are activated by pulling the stalk toward you.
The xenon high beams, like someone mentioned before, are the same as the low beam bulbs. A shutter opens to let a wider and higher beam out.
If your xenon high beams went out, your regular driving lights, xenon low beams, will also be out.
      09-09-2011, 11:10 AM   #11
exclusivo
exclusivo's Avatar
126
Drives: race car
precisely
      09-11-2011, 02:30 PM   #12
drshoelaces
omg... I am such a noob. sorry guys. thanks again for your info. I am going to continue researching
e90post
