What are the common issues about 335?
08-24-2011, 09:33 PM | #4 |
Rep 30
08-24-2011, 09:39 PM | #5 |
I <3 My E93
180
Rep 3,259
turbo and waste gates are free if your under warranty but its your not then its around $600 for each turbo + misc parts + labor
spark plugs are cheap injectors are $70 each i believe vanos, no idea again search is your friend
Bagged and Wrapped E93 335i
08-24-2011, 11:17 PM | #7 | |
Troll
79
Rep 1,193
I'd say probably that an M3 will walk it.
BMW E92 M3 Coupe | Jerez Black | Fox Red Extended / Carbon Black Trim| Fully Loaded | Moonroof | 6MT | Gintani Sport Quote:
08-24-2011, 11:50 PM | #8 |
Rep 2,979
Drives: 07 SBM E92 335i 6MT
Huh?
The E9x (and even more so the N54) can have quite a few problems. It's sometimes exaggerated by some on here (of course by the ones that have the problems). I have owned a lot of cars and have never had one with as many problems this one is prone too. If you don't want to worry about having to spend the $$ on getting it fixed, it's not worth the risk. ESPECIALLY if you plan on mods. If you can get one with a lot of warranty left, then no big deal. But then again, maybe you will be lucky like some on here and not have any problems.
In the process of restoring an 07 335i
08-25-2011, 12:37 AM | #9 |
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
interior cheapo plastic rattles...the rear deck especially notorious
08-25-2011, 01:01 AM | #10 |
Rep 2,979
^^are you being sarcastic? That's the one problem this car doesn't have I thought?
08-25-2011, 01:46 AM | #11 |
Rep 1,922
Drives: 2021 G80 M3
Anything new? so helpful. Did you get your post count up cause your reply was all it's good for. Troll.
I wouldn't call it cheap but some things start to peel off.
'21 G80 M3
'11 E82 135i DCT (Gone but not forgotten) '08 E90 335i (Gone but not forgotten) |
08-25-2011, 02:08 AM | #12 |
Rep 2,928
08-25-2011, 02:26 AM | #13 |
Rep 2,554
i wouldn't expect you to be making monthly repairs, with that said set aside $2000 a year for maintenance and repairs and you'll be more than set. depending on how much you drive, $1000 is probably more realistic
08-25-2011, 02:28 AM | #14 |
Rep 2,554
Oh, and i'd like to say i've only had the hpfp go out (with the previous owner with the older pump type) and that my interior has no rattling nor peeling.
As for other's "peeling interiors" I think they're referring to the steering wheel trim which costs a nice hundred or so dollars for a carbon fiber replacement: http://www.e90post.com/forums/showthread.php?t=320470 |
08-25-2011, 04:08 AM | #15 |
Going nowhere fast.
56
Rep 2,243
A New Turbo cost $3000 each x 2 = $6000
The main issues with a 335i are not the turbos though, its rather rare for a turbo have issues. You need to be prepared for the cost of service at the designated intervals, having a Indy shop that works on BMW's will save you a lot of money, about 50% off the dealer prices. Besides the main issue of the HPFP which is covered for 10Y/120K, there are other items to consider- Spark plugs at 35K $200 Pads/Rotors every 25K $800 Oil/Filter every 5K-8K $120 All fluids every 60K, Coolants flush, Brake Flush, Transmission Oil, Differential Oil- $400 4 Wheel alignment $100 Other issues with a 335 after 50K Injectors Solenoids Steering Sensors Light Bulbs Clutch after 80K if driven hard/improperly I purchased a 1 owner 52K miles 335i 6MT, I put on 13K miles, and only issues was a warranty HPFP ( had 3 prior in service records). I had the 60K service all fluids done for $400 Got rid of the RFT's and out on Hankooks $750 New Brake Pads $200 2 Software updates N/C Low Boost Turbos issue after track day $300 Diagnosis. ** Make sure you get all the service records for the car before considering buying it, a dealer can get these for you with VIN. You need to see if the service/warranty work was basic small things, or major ongoing problems. Mine had 3 lightbulbs, 3 HPFP and 1 set of plugs, 1 set of brakes in 50K. |
08-25-2011, 04:23 AM | #16 | |
Rep 30
08-25-2011, 04:31 AM | #17 | |
Rep 2,979
08-25-2011, 04:38 AM | #18 |
Rep 30
08-25-2011, 04:48 AM | #19 |
Rep 2,979
$695 each...so yeah, I'd say that's waaayyyy exaggerated..
http://www.trademotion.com/partlocat...catalogid=4462
08-25-2011, 04:50 AM | #20 | |
Rep 1,307
08-25-2011, 04:51 AM | #21 |
Rep 2,979
Oh no doubt...didn't think about that...
08-25-2011, 05:59 AM | #22 |
Going nowhere fast.
56
Rep 2,243
Turbos
I am sorry, I was always told new turbos for the 335i are $6K, I guess thats for OEM BMW-
So you can get a Indy to replace the turbos aftermarket for $600 unit plus labor? I heard you get rebuilt OEM's for about $2K, but never heard of ones for $600.... |
