Check your A/C line for intercooler hose clamp interference NOW before this...
08-23-2011, 01:49 AM | #1 |
Rep 294
My A/C stopped working this weekend, and I discovered the same issue referenced in this thread.
Close up of gradual wear on A/C pressure line that caused pinhole leak BMW changed the part number of this A/C line twice, the new line I picked up today has different bends, and they have wrapped this interference area with a ridged plastic sleeve, like a thick shrink-wrap. I don't believe it's strong enough to withstand rubbing from a stainless steel t-clamp, but it's better than bare metal. BMW added a plastic sleeve at the problem area, leading me to believe this is an issue with factory intercoolers and charge pipes. I think it's still a good idea to wrap your clamp with tape or silicone hose here anyway. New line installed, black plastic shrink-wrap is visible. I cannot say the area of interference has changed, it's still in the same place. This is a CP-E charge pipe. Although I am under BMW CPO warranty, I decided to do this repair myself because of the risk they would deny the claim based on the fact I have aftermarket intercooler piping. I have heard of factory piping causing this as well, and that is supported by this updated part. This line runs from the air compresser (located under the alternator, under the intake box) around the front of the engine to the condenser connection (close to passenger headlamp). I hope you will all double check to make sure you don't have interference.
2012 X5 35D - Platinum Gray / Cinnamon Options: Sport, Tech, Cold Weather, comfort seats, leather dash, high beam assist, lane-departure warning, soft-close doors, two-row, self-leveling suspension, hi-fi stereo
Tracks driven (in any car): Nürburgring Nordschleife (05/2011), LeMans (ok, just the public part), Eagles Canyon Raceway, MotorSport Ranch Cresson, COTA Austin |
08-23-2011, 02:32 AM | #2 |
Back in a BMW
205
Rep 5,208
my brother had his AC go out his 335 last week, his issue was the blower motor. $53.25 and a trip to my fav. tech and it was all set.
Ian
08-23-2011, 10:25 AM | #3 |
Rep 1,708
yep, going to see more issues with this. I noticed mine was slightly worn, so I added a silicone hose around the clamp... I was being lazy, but plan to add rubber hose zip tied around the AC line.
08-23-2011, 12:13 PM | #5 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
I've seen wear on my line as well even prior to the CP-e intercooler install. Thanks for the heads up post!
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
08-24-2011, 01:40 PM | #7 |
Rep 291
Wow, wish I'd seen this about 1 day ago. Just took my car in today because the AC quit working. Not sure if my issue is the aftermarket intercooler or the blower motor - should know soon, but I hope they don't deny me repair because of this.
08-24-2011, 01:46 PM | #8 |
Rep 1,054
Its easy to fix that your self. I had the same thing happen, and used a patch. It worked for a while but I need a line.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
08-25-2011, 01:30 PM | #11 |
Rep 294
The line is $194 retail but you can do better than that.
08-25-2011, 01:33 PM | #12 |
Rep 291
I just got the call from my dealer. Same thing. They want $860 or something like that for the leakdown test, part, install and recharge.
They are going to charge me $210 for the part, $250 for the leakdown test they performed (which pisses me off a little because I'm sure they would have seen the issue if they'd just looked at the damn line before the test), and recharge. So I'm in for $250 plus whatever I can source the part for no matter what. Does anyone know what that part number is, or the description? I found a few AC lines on www.getbmwparts.com but there are no part numbers, only descriptions and I'm not sure which one it is? There is a condenser to compressor pressure hose, an evaporator to compressor pressure hose, and suction hose? |
08-25-2011, 01:39 PM | #13 | |
Rep 294
08-25-2011, 01:49 PM | #14 |
Rep 870
Can we check the line with all OEM parts still attached? or do I need to remove airbox, etc? Also, is the driver side or passenger side?
thx for the heads up!
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 / Center Armrest Pouch / JB4 / BT
08-25-2011, 01:54 PM | #15 |
Rep 294
Honestly it's hard to see it when the charge pipe is all connected. I'm not sure if you could wiggle the factory pipe around enough to see it. I think you can get your fingers back there to check the interference, though.
08-25-2011, 02:06 PM | #16 |
Rep 291
Is there anything special that needs to be done to recharge the system? Seems like it's as simple as replacing the hose and then recharge with a kit you can get at Autozone or something like that. Is that correct?
The part is $122 on getbmwparts.com |
08-25-2011, 02:38 PM | #17 | |
Rep 870
Nice list of cosmetic mods, I'm quite jealous.
08-25-2011, 03:52 PM | #18 |
Rep 1,307
Thanks very very much for bringing this to our attention. I am out of warranty and ALWAYS CONSTANTLY checking these forums to lookout for such potential problems and prevent costly repairs.
Just to be sure, the area of problem is where I have highlighted in red, correct? I think that when the pipe gets very hot, it expands a little bit. Adding that with motion of the car causes wear overtime. |
08-25-2011, 04:39 PM | #19 |
Rep 1,307
I could not check visually for any wear, so I just put my right hand in there and used my pinky to try and feel if there's any wearing or carving. So far so good. Mine's a stock 2007 E92 335i with factory pipes, so if there's any wearing it should be apparent by now. However, there is indeed very little clearance between so I see how this would be a problem with aftermarket piping.
08-26-2011, 10:32 AM | #20 |
Rep 294
Yeah you got it, JunkStory
08-26-2011, 10:43 AM | #21 |
Rep 160
Drives: 2007 335i coupe
I also have an 07 E92 and about a month ago my A/C quit working. I haven't looked into it since I don't use it much but now that you mention it I think its time.
Thanks for the heads up, I would have wasted money trying to recharge it with a not so obvious leak, I'm pretty sure this is what is causing my issue. |
