Rough idle and intake valve carbon build-up. How is this possible?
08-22-2011, 01:31 PM | #1 |
Rep 709
Drives: '07 335i (E93)
OK, so I need some assistance here from the experts...or at least someone who knows more than I do about this:
While my car was at the dealer I mentioned that I have noticed that it has developed a rough idle and just some diminished performance in general. They said they would check for any codes and get back to me. When I got my car back, they said that no codes were indicating a problem that could cause what I described, but they did say I have carbon build-up on the intake valves. I am not sure how they determined this. The SA asked what kind of gas I had been using, and I told her that I have put nothing in the car except Chevron or Shell since it was brand new (2007, 42k miles). This struck me as a ridiculous question as I will explain below. Then they said it would be $700+ to clean them. I said "thanks but no thanks" until I could do my own research. So here is my dilemma:
Finally, I hear that Seafoam may help here, but I'm not so sure that a few seconds of exposure to seafoam would be enough to dislodge these deposits that people claim take metal brushes to remove... Anybody?
Alpine White/Coral Red/Gray Poplar Convertible Sport/Prem/Step/Comfort/Nav/Sirius
MHD Stage 1 Flash, M-Factory Helical LSD By the way people: USE YOUR F&*#ING TURN SIGNALS! Pass the word. |
08-22-2011, 01:36 PM | #2 |
Rep 6,773
Its because its a direct injection engine that you will see carbon deposits on the intake valves as a result of the combustion process. When you have port injection the fuel passes over the valves and the detergents in the fuel clean or minimize carbon build up..
Do the intake valve cleaning, as this is the only way to remove the carbon buildup..no amount of fuel cleaners will help w this. My suggestion is to try and find and indy mechanic who has done it...it will be alot cheaper than what the stealership charges you I personally do not like using seafoam..as any pieces of carbon that break lose will get sucked right into your engine |
08-22-2011, 01:40 PM | #3 |
Rep 709
OK, but I still want to understand:
1. How it gets there in the first place 2, How it can possibly affect combustion
08-22-2011, 01:42 PM | #4 |
3441
Rep 79,211
Carbon deposits are left behind during combustion.
It doesnt effect combustion itself it effects the air flow to the combustion chamber. |
08-22-2011, 01:44 PM | #5 |
Rep 1,883
These cars burn a lot of oil, so there is a lot of crankcase gases. Build up can cause valves to not move as freely as they should.
I would've asked the dealer to explain why the type of gas you used affects carbon buildup. IMO, they love to make false claims to charge you. Always a good idea to test their knowledge.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
08-22-2011, 01:45 PM | #6 | |
Rep 6,773
The build up of carbon will cause improper air flow through the valves..and will rob you of power, cause rough idle, detonation etc etc. This is a well documented issue with the n54 around the 50K miles mark.. Last edited by tibra1; 08-22-2011 at 01:54 PM.. |
08-22-2011, 01:46 PM | #7 |
Poor Kid with Dreams
28
Rep 702
Oil from your positive crankcase ventilation system is recirculated into the intake manifold from the valve cover and is sucked into the engine via the intake stream. Any roughness on the intake side of the cylinder heads will create turbulence in the air and ruin the venturi affect that the engine relies on to be efficient.
'07 BSM 335xi JB4, DCI, CX Racing I/C, ER Chargepipe, Meth, KW V3 - Pending Sale '95 Mustang GTS 347ci Ported TFS TW Heads,Custom Cam,Victor 5.0 IM,Tubular Front Suspension,Full Exhaust,Big and Littles |
08-22-2011, 01:46 PM | #8 |
Rep 709
Any chance this issue is being taken care of through a TSB and they're just not telling me?
08-22-2011, 01:49 PM | #9 | |
Rep 709
08-22-2011, 01:56 PM | #11 |
Rep 322
Sorta, but a catch can alone won't cure the problem, (certainly doesn't hurt) the majority of the carbon is a just bi-product of the fuel burn in the combustion process
08-22-2011, 02:08 PM | #12 |
Rep 709
I didn't realize there was so much gas recirculation so as to cause this issue...maybe they shoulda teflon-coated the back side of the valves! LOL
08-22-2011, 02:09 PM | #13 |
Rep 709
08-22-2011, 02:12 PM | #14 |
Rep 2,291
As Tibra said, no. Nasty valves is not a defect. Its just a bad characteristic of DI engines in general (at least high performance Euro engines). Other manufacturers are beginning to use DI engines (toyota/lexus and ford). I'm pretty sure there owners wont be as understanding about sludge issues as luxury Euro owners, so I would expect them to have a solution pretty quickly.
08-22-2011, 02:29 PM | #15 | |
Rep 1,244
08-22-2011, 02:39 PM | #16 |
Rep 709
Which Nissan has a DI engine, GTR?
08-22-2011, 02:43 PM | #18 |
Rep 709
Knew it was turbo...didn't know it was DI...
08-22-2011, 05:18 PM | #19 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
search the forums, 2-3 decent write up on how to clean them at home.
08-22-2011, 05:50 PM | #20 |
Rep 40
OR
Reading stumbling/jerky acceleration threads, pottypants (I think) suggested an olde school solution to this new age DI problem. Took my car out on the open highway. 80mph 4th gear 30 minutes at about 4k. Never visually inspected carbon on my valves, but the stumbling is gone. It's free, try it. |
08-22-2011, 06:01 PM | #21 |
That guy
117
Rep 5,740
old school italian tune job?
08-22-2011, 06:05 PM | #22 |
Rep 40
Yea. I know not everyone is as ancient as I am, but..
"Back on the day" Dads would take the Country Squire out on the weekends, hit the highway to blow the carbon out. Always thought it was a wives tale, but it worked for me. |
