E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Oil Temp. Too high?
      08-20-2011, 07:47 PM   #1
MikeDalle
MikeDalle
MikeDalle's Avatar
Drives: 2007 335i (E90)
Oil Temp. Too high?
My oil temperature sits at about 240, should I be worrying about this? I know the N54 runs hot but mine sits between 215 and 250.
      08-20-2011, 07:52 PM   #2
O HELLA BMW
I <3 My E93
O HELLA BMW's Avatar
Drives: 12” 335is vert
my oil gauge never goes over 240/250
Bagged and Wrapped E93 335i
      08-20-2011, 08:00 PM   #3
achien
AC
Drives: E90 Post Members Crazy
you should only start to worry if it goes over 250F.
Your Supreme Leader
      08-20-2011, 08:51 PM   #4
cstmx_ryder
cstmx_ryder's Avatar
Drives: A metal box with a roundel
I think it starts to go into limp at 270 deg. So I'd say anything below that is fine.....also depends on where you live geographically.....
'08 AW E90 335i
PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10
      08-20-2011, 09:43 PM   #5
Litos
Drives: 2012 Challenger RT Junk
240 is good, especially in NOLA.
sometimes mine gets to 250 but it doesn't stay there long....
      08-20-2011, 09:45 PM   #6
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
fun fact, my car's oil temps run higher in cooler ambient temps (70-80) degrees than in the extreme heat. When it hit 104 degrees in NYC last month idling in traffic, my oil temp didn't even touch 240. Guess that oil cooler was working overtime!
E90 LCI N54 6AT
      08-20-2011, 10:20 PM   #7
MikeDalle
MikeDalle
MikeDalle's Avatar
Thank you all for replying so quickly. I also heard that certain cars were equipped with extra oil coolants for the engines. Is this true? How do you know if your vehicle has this?
      08-20-2011, 10:23 PM   #8
bimmertt
bimmertt's Avatar
93
Drives: 2007 e92 335i
mine is always at 240 in the summer
      08-20-2011, 10:36 PM   #9
tibra1
Drives: 2011 ZCP M3 - 2007 335i crashd
Normal
      08-21-2011, 10:08 AM   #10
secretsquirrel
secretsquirrel's Avatar
130
Drives: f80
Mine is at 240 in the summer and 245 in winter. Oddly it is a little warmer in the winter.
      08-21-2011, 10:10 AM   #11
MKR_DmD
MKR_DmD's Avatar
Germany
Drives: 16 Jeep Cherokee
The stock thermostat doesn't open till 240 so that is your normal operating temp. You really don't have to worry about it till your get above 270, and you should only see that on the track.
      08-21-2011, 12:37 PM   #12
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Same experience. I think it "knows" when its hot! LOL
      08-21-2011, 01:26 PM   #13
Syndicategt
Syndicategt's Avatar
Drives: 335i
I run a consistant 265 at the track....your are fine at 240 for daily driving
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
      08-21-2011, 03:47 PM   #14
mid-corner fun
Drives: F80 M3, '22 X3MC
anything up to 270 is fine, beyond that you'll experience power loss. Game over at 300F.
Example from last year. Fixed it since then with a STETT stg2 OC. And this would only happen at the track with stock (or no) OC
      08-21-2011, 04:24 PM   #15
BMWsky
Drives: 335i
My stock oil cooler never goes over 240 while driving around town. At the track it'll touch 260.
      08-21-2011, 06:51 PM   #16
MKR_DmD
MKR_DmD's Avatar
Germany
260 on the track, I wish I lived somewhere where it was cool. Fighting 100+ heat sucks on the track. 280 is my normal with peak of 290
      08-21-2011, 08:02 PM   #17
BMWsky
Drives: 335i
Ouch!!
      08-21-2011, 08:29 PM   #18
turb0mik3
turb0mik3's Avatar
242
Drives: E90 335i Racecar
2010 BMW 335i  [8.90]
As stated above, shouldn't peak above 240F during daily driving, maybe 250 spirited. I have the ER stage 2 and never go above 245, even on the track with exterior temps exceeding 100F
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ |
NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>>
      08-21-2011, 09:40 PM   #19
MKR_DmD
MKR_DmD's Avatar
Germany
ER stage 2, is that the dual core? I am saving that space for an extra radiator or AT cooler.
      08-21-2011, 10:01 PM   #20
turb0mik3
turb0mik3's Avatar
242
Ya, dual core. The stock radiator does the job in my opinion and would be a waste. HP said they were coming out with one but haven't heard much about it.
      08-21-2011, 10:10 PM   #21
MKR_DmD
MKR_DmD's Avatar
Germany
Ya after I due a couple more track days, I will figure out what I need the most.
Mflowt5, you might want to block out your license plate since you are on the track.
      08-22-2011, 01:10 PM   #22
BaMBaM4002
BaMBaM4002's Avatar
Drives: 2007 E92 6sp -BSM/Coral
Yeah ive experienced the same issue from time to time. Around town or on the hwy in 85 degree weather, I can literally watch my temp move up from 245 to about 255, going back and fourth pending my throttle and speed lol obvious its pretty safe if others are seeing the light of 270....
e90post
