COBB V3.00, cause transmission malfunction
08-19-2011, 08:24 PM | #1 |
Perfect
43
Rep 543
First of all, I just want to point out the issues I encountered. It may be just single case.
I updated the v300 stage1 93 map a while ago. Then I went on track. Whenever I pushed the car hard at the corner, or on the straight, this map will cause transmission failure. I mean it's not once, it's multiple times! It almost killed my transmission.. I tried to uninstall cobb then went back on track, no issue at all.. That means the v3.00 map cause this issue right? I don't have this problem when I was running v201 or v203 map. But I have encountered "engine malfunction" with the v203 map on the track(however, it didn't actually reduce power, just the sign) BTW, can anyone tell me where I can find the old V203 map and flash it back? much appreciated. |
08-19-2011, 08:39 PM | #2 |
Rep 40
This same thing happened to me a couple times on v2.03 93 octane during some spirited street driving.
Happened when I traveling about 50-60 mph and tried to accelerate. Both times, I pulled over, shut car off and restarted. All was good after that, but still a mystery why it happened. |
08-19-2011, 08:50 PM | #3 |
Rep 660
AT or MT?
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
08-19-2011, 09:04 PM | #5 |
Rep 660
I hope i wont have this issue..
08-19-2011, 11:12 PM | #7 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
Can you go back to 2.03 by clicking off Beta maps?
08-20-2011, 01:06 PM | #11 |
Rep 5,876
You can always download any calibrations from the Cobb website...suggestion on BETA maps is to contact Cobb through either email or phone, they're available...
some vendors have really strict rules about beta releases and would disown you if you posted something like this on their beta map lol just load a previous final release and work with Cobb to solve the issue that's IF this really is tune related.. |
08-20-2011, 05:32 PM | #13 |
Rep 1,717
Drives: lifted tacoma on 38's & ducati
car totaled out !!AW335i, oem aero lip, m3 csl rims, oem m3 sides, vorst csl carbon trunk, tinted, lowered on H&R sport, AR DP's, Bastauck dual exhaust, BMS intake, etc
NEW RIDE white GTR! |
08-20-2011, 05:37 PM | #14 |
Rep 5,876
08-20-2011, 06:49 PM | #15 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Keep one important thing in mind though: if you want to go back to 2.03 or earlier maps you MUST downgrade your AP firmware. I also recommend uninstalling and reinstalling the flash from your ECU.
Cobb specifically said that running 2.03 or earlier maps on 3.0 beta firmware will produced undesired effecs.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
08-20-2011, 07:37 PM | #16 |
Rep 610
FWIW I hadn't experienced this issue on any of the older cobb maps. Haven't ran the accessport since the newest firmware :/
335i - stock for now
Escalade - Urban Assault Vehicle T/A - Forged ls1, PT8285 turbo, heads, cam, 4l80e w/Transbrake, s60 rear on e85. |
08-20-2011, 11:09 PM | #17 | |
Perfect
43
Rep 543
Does it mean I can just install these V203 maps on the car? |
08-20-2011, 11:13 PM | #18 | |
Perfect
43
Rep 543
I will go test the v203 map and see how everything works on the track soon. |
08-21-2011, 04:57 PM | #19 |
Rep 871
I just had issues today on the new BETA 3.00 maps. My car threw a fuel pump code and internal DME error: something to do with actual torque. First time my car has ever thrown either of these two codes. Not feeling too good right about now. The results of throwing these codes was pretty traumatic engine quivering. Not at all confidence-inspiring!
Fully Loaded |
08-21-2011, 05:27 PM | #21 |
Rep 5,876
Lol ppl do you realize these are "BETA" right? Run an official release if you don't want/anticipate any issues or talk to Cobb...why some of you guys think board members can help with a beta Cobb tune is beyond me really
08-21-2011, 05:31 PM | #22 |
AC
95
Rep 2,387
taking your AT to the track is asking for trouble. the torque converter overheats faster than your engine. no oil cooler or inter-cooler will help your transmission.
if you are serious about tracking your car, switch to MT.
Your Supreme Leader
