No fuel pressure, no start
08-19-2011, 07:30 AM | #1 |
Rep 569
No blown fuses, and I am not getting high or low fuel pressure.
Has anyone experienced this? I had to recharge the battery, I spent an hour last night trying to get codes to pop up... NONE. Car shut down on me while driving and never started again ( after I popped off a dv that was not seated correctly) Can anyone recommend a diagnosing procedure or what parts would be related...I have to order them today so I have them in case that's it to fix this weekend. I have thought HPFP, LPFP, pressure sensor. Please help |
08-19-2011, 07:45 AM | #2 |
Rep 7,377
if its HPFP there is a recall so you can get the dealer to replace it. check the codes if you can or just take it to the dealer....
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
08-19-2011, 08:18 AM | #5 |
Rep 569
It turns over and over. It just cranks. The battery only ran down bc I made it crank so long trying to produce a code and doing a couple datalogs which indicate no pressure from the hpfp or the lpfp. I checked all fuses that I thought could be related. I'm going to check the lpfp to make it is getting 12v. If it is getting 12v while cranking it would lead me to think that's the problem.
