mountain bike fork mount for OEM racks
08-15-2011, 07:16 PM | #1 |
Rep 13
looking for a fork mount for my mountain bike . the oem bike holder that's on my rack isn't cutting it. the bike isn't that secured. i know bmw has fork mount but it's made for a racing cycle. will this also hold a mountain bike? any suggestions?
http://www.amazon.com/BMW-Racing-Cyc.../dp/B004FRBWMY |
08-15-2011, 08:37 PM | #3 |
Rep 258
I disagree. I had a yamika on my tl. It was good but didn't like the way it mounted to car. The bike holders were good though.
I got the BMW rack and race bike holders. The rack doesn't touch the roof, a plus. There is an old style race bike rack. It looks like the one in your link is the old style ( two parts) the new style is 1 piece. If your front wheel has quick release then it should fit race bike version holders. Just make sure you get newer version |
08-15-2011, 08:54 PM | #4 |
Rep 255
I have the ones where you dont have to take the wheels off, has a arm that holds the bikes frame. I had a set of the fork mounts and I ended up trading whem with someone for the these. It is much faster and easier to put them on and take them off.
They don't feel the most secure but slowly i have gained confidence with them, and have taken several 200+ mile trips with the bikes on my roof on the highway with no problems.
08-15-2011, 11:15 PM | #5 | |
Rep 13
http://www.rockymounts.com/Euro_PitchFork_p/1102.htm |
08-18-2011, 03:23 PM | #6 | |
Rep 50
08-18-2011, 03:29 PM | #7 |
Rep 572
I used to have the oem arm/frame mounted rack as mentioned above. I had a bike up top and make a sharp/quick turn and applied the brakes to avoid another car, and I bent the arm. Luckily I had another one on top without a bike on it.
Fork mount is the way to go for stability and confidence. |
08-18-2011, 04:48 PM | #8 |
Rep 394
i would go w/ the BMW base rack, and either a thule or yakima fork mount. if your bike is too burly for a fork mount (20mm or 15mm thru axle), there is a yakima system where you dont have to remove your wheels that can mount to the base rack as well.
go bears
08-18-2011, 11:52 PM | #9 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
Had this set up for a while and you can't go wrong with Thule racks.Must have a X adaptor kit in order to work with Thule racks.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
08-19-2011, 11:48 AM | #10 | |
Rep 394
if you are only using the racks for road bikes, this shouldn't be an issue, but i use mine for 30 lb+ mountain bikes, so wanted a bit more security.
go bears
