08-15-2011, 03:13 PM | #1 |
Rep 1,311
Re-paint APracing Calipers and disc hats - suggestions?
Hey fella's,
Well, It looks like my only option other than purchasing new brakes is to re-paint the disc hats and calipers since off the shelf wheel cleaners pretty much destroyed the paint finish. Refer to my pictures. I will be ordering new hardware which is required for removing the disc hats. The plan is to remove the hats (front/rear disc hubs) and repaint them with high-temp caliper/exhaust/engine paint. Satin Black. Calipers will be removed, cleaned and most hardware & pads removed, some parts taped off (bleed valves, bottom transfer tube, etc) Re-paint the calipers black with same type of high-temp paint. The only problem is how to not paint over the yellow APracing logo? Or what to use to repaint the logo so it looks the same? Should I try to tape the logo off and touch it up, or re-paint th logo with a small brush using yellow hi-temp paint after the calipers are painted and dried? Would i need to scuff up the yellow logo paint or remove it? What methods, suggestions to you all have? I'v reviewed some online links but most are re-painting their calipers in a very "Ghetto" half-ass way. I want to make this look as good as possible without sending my brakes off tor a month. |
08-15-2011, 04:19 PM | #2 |
Grease Monkey
293
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
Too bad about the finish being wrecked!
I noticed that Sonax wheel cleaner was starting to get hard on my brakes as well so I am no longer going to use it, P21S is the best wheel cleaner there is when it comes to being gentle on brakes. As for your questions on repainting, I would look into having the hats re-anodized since paint may be susceptible to damage/peeling due to wheel changes. Painting the yellow by hand is an option or you could use an x-acto knife and mask it up...... your choice. If you can be without the car for a while I strongly recommend contacting IND, they paint lots of brakes and can do them in any color you want. If you explain that you need a quick turnaround I am sure they can expedite the process too! |
08-15-2011, 05:05 PM | #3 |
Rep 1,311
Awesome man! Thanks for the advice. I did not know IND will repaint calipers. I just talked to them and that's the way I'm gonna go. Probebly will go with a gray for the calipers and just re-paint the hats myself.
08-16-2011, 11:36 PM | #4 | |
Grease Monkey
293
Rep 2,646
I don't recommend you painting the hats, I don't think the finish will be durable enough...... Send them the whole works and have it done properly, you will be much happier and it won't cost much extra. |
08-17-2011, 02:22 PM | #7 |
Rep 1,311
