Weird vibration! What could it be?
08-13-2011, 10:55 AM | #1 |
Rep 651
Hi, just yesterday I noticed my 335 had this \"vibration\" at highway speeds. It was one to 3 vibrations and felt like a transmission problem but it doesn\'t coincide with shifting. A few days ago, I almost ran out of gas but made to the pump and filled up the usual premium gas. Could this be injector as I noticed reduce power when it vibrates? HPFP?
08-13-2011, 04:10 PM | #2 |
Rep 322
Vibration in the steering wheel at around 50 mph (within a small range)? =Unbalance in the front wheels. (Light) vibration of the complete car at around 85 mph (but over a wider speed range)? =Unbalance in either front or rear wheels. The wider your wheels, the higher the chance for unbalances. In extreme cases, an incorrect alignment of your wheels causes your tires to wear off unequally (feathering or one-side wear) which can lead to unequal weight distribution of the tire and thus an imbalance.
Good luck resolving the issue. |
08-14-2011, 09:23 PM | #4 |
Rep 651
Let me rephrase. I used the word vibration but at that time it was the best word I could come up with. The more I think about it it's not a vibration but more like a 1/2 second of loss in power, like bad gas, injector or fuel pump. I don't feel vibration coming from steering wheel,wheel, suspension. And it only lasts a half second.
08-15-2011, 12:53 AM | #5 | |
E85 is my friend
19
Rep 224
//sparkling graphite metallic // sport package // logic 7 // m-tech wheel // HID fogs // LED angels // M3 style CF hood // matte black kindney's // AFE DCI // kittyless DP's // custom SS exhaust // Godspeed FMIC // 15ohm JB4// DV Mod //
08-16-2011, 06:48 PM | #7 |
Rep 651
Yes! But no warning lights. I do have JB+ but I'm not sure if that is causing it. Anyways I do have an appt with the dealership Thursday morning. I'm taking all my mods off. Wish I have a BT scanner
08-17-2011, 09:11 AM | #10 |
Rep 651
I took off my mods last night, CP, DCI, Jb+, in preparation for the dealership and I drove 20 miles to work this morning. So far none of the stuttering, misfiring, vibration that I felt before. Last night as I drove home and before the removal of mods, as I was turning I felt the worse stutter yet. It was so prounounced that I thought the transmission dropped from below. Yet, it was just a split second and power returned to normal as a sped off from the intersection. Weird huh? I wonder if the weather/outside makes it worse. As I usually notice it the issues more in the day/evening time. I'll see what happens when I drove home from work later. Thanks for yall's inputs
08-17-2011, 12:53 PM | #12 |
Rep 334
I too have a vibration at around 80-85 which can't be resolved, even after throwing $1000 into it. Can you please check something for me, Geesemonkey: I find the vibration is noticeably worse when the AC is on, than when it's off. What about you. Thanks.
Steve Foster Steve6foster@gmail.com '11 335i cp MT |
08-17-2011, 01:57 PM | #13 |
Rep 651
This vibration or stutter for me is not related to speed. Nor is it related to AC on or off. It just feels like the engine is going to shut off or like the fuel line got clogged.
08-17-2011, 02:03 PM | #14 |
Rep 1,153
Vibration at speed whilst under power, comming through the accelerator peddal?
Could be described as a flutter?
M Sport Package, (PDC), front / rear, Cruise control Mystic Blue Metallic, Beige Dakota leather, Alarm, Automatic transmission, Panoramic glass roof, Heated Seats, Lumbar etc etc "I don't Fuck around but when I do, I dont fuck around" Last edited by ZURICH; 08-17-2011 at 02:04 PM.. Reason: forgot something:-) |
08-17-2011, 05:02 PM | #15 |
Rep 651
08-17-2011, 11:11 PM | #16 |
Rep 132
OMG. A vibration? What you need to do is give a not so detailed description of the problem to a public forum on the internet. Presto change-o. All your automotive problems shall be solved...
godspeed
Disclaimer: You may not like what i have to say. Deal with it.
08-19-2011, 04:26 PM | #20 |
Rep 651
Car is in the shop. No problems as of yet. Actually since I took off my tunes. They ran an ECU scan and no codes accept for a bad relay switch. Could this caused by thee JB+?
