Dissapointed day at the drag strip
08-13-2011, 04:13 AM | #1 |
Rep 1,065
Drives: RB PWRED E90 N54 6MT
RB Turbo/Procede V5/Vishnu PWM Meth Injection Kit/Vishnu DCI/AR Catless DP/AE Performance Exhaust(Sold)/Helix FMIC/Forge DVs/Rixster Vent Boost Gauge/Wavetrac LSD/KW V3/ACT Street Clutch Kit
08-13-2011, 04:29 AM | #3 |
Rep 1,065
yup, 6MT
08-13-2011, 02:47 PM | #4 |
Rep 2,875
Sup George!
I'd probably try a 80/20 meth mix, and what were your user adjustable values on the Procede? Did you get line-lock with your LSD? Maybe burning out would help with traction a little on street tires? Everytime I went to the strip, I also had traction issues, but that's without LSD or line-locks, and on street tires. My '60ft was just like yours, my best '60 was a 2.1 I believe, with the trap being 114.XX at 12.67. That was just with MS109..... I need to practice my launching skills to cut the '60ft time down to 1.8-1.9.....I know that's possible even with street tires.....LOL.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
08-13-2011, 03:09 PM | #5 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
If you are seeing 115+ traps with traction control intervening, your true traps can potentially be 116-117mph. Because I'm sure it's cutting throttle/boost going into 2nd gear as well. Theres really no secret to getting low 60' with a 6mt. You need either drag radials or slicks. And if u want to cut really good 60' times, you'll need a line lock to heat them up properly. I went from cutting 2.2-2.4 60s to 1.6-1.7 by doing that. At just 16.5psi u have the power to run low 12s. Do yourself a favor and work on taction. Just cranking up the boost to 20psi will make you a little better ET but it will be a bigger disappointment. It's also worth datalogging runs so you can evaluate everything including shift times.
08-13-2011, 03:47 PM | #6 | |
Rep 10,587
and it goes on and on
08-13-2011, 03:47 PM | #7 | |
Rep 1,065
So you are saying with 6MT , there's just no way to cut down the 60' time to 1.9 or 1.8 without drag radials or slicks? Were I suppose to take off easily on 1st gear or punch it hard right off the line?
08-13-2011, 03:48 PM | #8 | |
Rep 10,587
honestly though, if the track prep is horrible then you have no chance. I've seen 60ft w 335 w open diffs in the 1.8's w a 6MT on street tires, but its not easy.
08-13-2011, 03:54 PM | #9 |
Rep 10,587
to give you an idea, here is Jamie Furman's driving resume on bone stock street tire records. The man is a driving machine.
the list goes on and on ACR Z06 GT2 Ford GT etc
08-13-2011, 03:56 PM | #10 | |
1737
Rep 17,960
Drives: A Lot
08-13-2011, 04:08 PM | #11 |
Rep 1,065
so with my mods, am I trapping at the right speed?
08-13-2011, 04:15 PM | #12 |
1737
Rep 17,960
Drives: A Lot
With some more traction you'd easily see 116-117mph. And that is pretty damn solid for a daily driving set up. Those 120mph traps that you see from time to time are drag strip prepped cars. By that I mean 20psi peak boost running race gas+meth with weight reduction.
08-13-2011, 04:31 PM | #13 | |
Rep 949
08-13-2011, 04:41 PM | #14 |
Rep 2,991
