IDrive & Tire Pressure
04-18-2007, 11:31 PM | #2 | |
Rep 367
Drives: Alpinweiss 2009 E92 M3
i'm sure the fact that the temp was well below 0 F had something to do with it. i put a little air in, reset the TPM and all was good. no problems since.
2009 E92 M3 - 7/3/09 ED, 8/17/09 redelivery 1997 E36 M3 - Track Rat 2014 Jeep Grand Cherokee Overland |
04-20-2007, 07:30 PM | #4 | |
Rep 2,760
Even a Buick Lacrosse does one better!
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
04-20-2007, 09:51 PM | #5 |
Smiling politely
165
Rep 7,931
On the sedan, it uses the other tire pressure sensor system (FTM). All warnings show up on iDrive with a narrative explanation -- this is nice, so you don't have to figure out what the little icon means. So a warning based on the FTM also would be shown on iDrive.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
04-24-2007, 04:54 PM | #8 |
Rep 2,984
your warranty will not be voided if you change your tires provided you use german approved compressed air.
"...I maybe drunk, but you're ugly, and I can sober up..." |
04-25-2007, 12:22 AM | #10 |
Rep 26
Yes, tire pressure notification system definitely works. Both of my front tires have had low tire pressure already. It gives you a notice that tells you which tire the system has detected has low pressure and doesn't go away until you pump air. It also cautions you not to drive over 60 mph. Hope that helps
