Is it safe to say that Cobb has the best . .
08-11-2011, 10:52 PM | #1 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
logging capabilities on the market today?
08-11-2011, 11:00 PM | #3 |
Rep 794
From what I've seen they look great.
Gone But Not forgotten:
-07 Shelby GT500 W/ Full Bolt on E85 -08 335i 6MT W/ Full Bolt On E85/Meth -08 M3 DCT W/ Full Exhaust / Tune -13 B8 Audi S4 APR Stage 2+ |
08-11-2011, 11:08 PM | #4 |
Rep 13,583
Drives: JB E92 335i
The COBB AP definitely has one of the most advanced logging capabilities as compared to the competition. For a complete listing of current and new monitors, visit our BMW AccessPORT Data Monitor List.
08-11-2011, 11:34 PM | #6 |
That guy
117
Rep 5,740
Here is the listing of items - I am trying to get explainations on what each means on this thread. So if you have answers, please post their.
http://www.e90post.com/forums/showth...8#post10209328 post 27 Accel Ped. Pos. - (%) - Actual pedal position - 100% means floored. Actual Load - (Load) - Actual load the engine is generating. Baro Pressure - (PSI, kPA, kPA) External baro pressure. Battery Voltage - (V) - self explanatory Boost - (PSI, kPA, kPA) - boost at manifold Boost Mean Abs - (PSI, kPA, kPA) - ??? Boost Set Limit - (PSI, kPA, kPA) - Max boost that the load based tuning will request. Boost Setpoint Factor - (Factor) - ??? Charge Air Temp. - (°F, °C, °C) - Intake temp at manifold? Cyl1 Timing Cor - - Number of degrees less than the map's set timing curve in given cylinder Cyl2 Timing Cor Cyl3 Timing Cor Cyl4 Timing Cor Cyl5 Timing Cor Cyl6 Timing Cor ECT - (°F, °C, °C) - Engine Coolant temp Fuel HPFP - (PSI, kPA, kPA) HPFP pressure - actual Fuel HPFP (Req.) - (PSI, kPA, kPA) HPFP pressure - requested Fuel LPFP - (PSI, kPA, kPA) LPFP pressure - actual Fuel LPFP (Req.) - (PSI, kPA, kPA) LPFP pressure - requested Fuel Mode - (Mode) ??? IPW Cyl 1 - (%) ???? IPW Cyl 2 - (%) ???? IPW Cyl 3 - (%) ???? IPW Cyl 4 - (%) ???? IPW Cyl 5 - (%) ???? IPW Cyl 6 - (%) ???? Knock Volt Cyl. 1 - (V) Voltage the knock sensor is read, movement indicates knock??? Knock Volt Cyl. 2 - (V) Knock Volt Cyl. 3 - (V) Knock Volt Cyl. 4 - (V) Knock Volt Cyl. 5 - (V) Knock Volt Cyl. 6 - (V) Lambda (Bank1) - (AFR, λ, λ) - AFR on bank 1 - actual Lambda (Bank2) - (AFR, λ, λ) - AFR on bank 2 - actual Lambda Req. (Bank1) - (AFR, λ, λ) - AFR on bank 1 Lambda Req. (Bank2) - (AFR, λ, λ) - AFR on bank 2 Load Requested - (Load) Requested load from the engine. LTFT (Bank 1) - (%) ???? LTFT (Bank 2) - (%) ???? MAF - (g/s) - Mass of air moving through engine?? MAP - (?) - ??? Oil Temp. - (°F, °C, °C) - Oil temp. Req. Boost Abs. - (AFR, λ, λ)??? Req. Boost Delta - (AFR, λ, λ)??? RPM - (RPM) - rprms STFT (Bank 1) - (%) ???? STFT (Bank 2) - (%) ???? Timing Cor. (BAT/ECT) - (°) ???? Timing Cyl. 1 - (°) Timing on cylinder 1 Timing Cyl. 2 - (°) Timing Cyl. 3 - (°) Timing Cyl. 4 - (°) Timing Cyl. 5 - (°) Timing Cyl. 6 - (°) - Torque Limit Active - (?) ??? Torque Limit Modifier - (?) ??? Torque Output - (%) ??? Torque Requested - (%) ???? TPS Act. - (%) Throttle plate position - 80 is full throttle. VANOS Exh. Act. (CRK) - (CA) ???? VANOS Exh. Req. (CRK) - (CA) ???? VANOS In. Act. (CRK) - (CA) ???? VANOS In. Req. (CRK) - (CA) ???? Vehicle Speed - (mph, kph, kph) Speeeeeeeddd WGDC After PID (CRK) - (%) ??? WGDC Bank 1 - (%) Wastegate duty cycle - bank one WGDC Bank 2 - (%) Wastegate duty cycle - bank two WGDC Base Value - (%) ?????? |
08-11-2011, 11:35 PM | #7 |
That guy
117
Rep 5,740
08-12-2011, 12:30 AM | #10 |
Formerly (-(ellblazer420
48
Rep 703
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
I second that I miss my k-pro so much sometimes. It was and still is ahead of it's time.
08-12-2011, 08:58 AM | #11 |
Rep 2,991
it amazes me how Cobb has grabbed the N54 tuning world by the freaking balls only 7 months after it's initial release.
we are at the early stages of this wonderful tune and it's logging capabilities. it's clearly one of the most loved tunes out there right now. it's almost like being "Rookie of the Year", but also being voted "MVP". it may be the new kid on the block, but the impact it's making in the N54 community is astounding...... |
08-12-2011, 09:26 AM | #13 |
Rep 468
Hey Everyone,
We will be posting up a pdf with descriptions which will grow into a guide of what you can expect from a healthy car and when parameters are going out of range. Should be up later today. Thank you for all the kind words! Cheers, Rob |
08-12-2011, 09:28 AM | #14 |
That guy
117
Rep 5,740
That's awesome. And that should be a sticky.
08-12-2011, 09:31 AM | #15 |
Rep 498
The nice thing about Cobb is their vast tuning experience. They have APs for a lot of different platforms. I know they are fairly successful on the WRX/STIs and Mazdaspeed3s. They are pretty much the only tuner on GTRs. So, I'm not surprised that they are doing well in our platform.
08-12-2011, 10:08 AM | #17 |
Rep 2,604
Drives: G80 Comp XDrive
Can't wait to test these new logging capabilities at the drag strip once I have stage 2 installed
08-12-2011, 11:33 AM | #19 | |
Rep 288
G42 M240i xDrive
08-12-2011, 01:41 PM | #21 | |
Rep 5,876
its not about making power, its about how you do it, i.e. refinement...if all you want is just some power throw an SSTT or JB+ on and Bob is your uncle lol love that phrase |
08-12-2011, 03:37 PM | #22 | |
Rep 2,991
pfffft, not bad for 07 support that's been around less than 4 months. ........and i did that in 93 degree heat in Austin Texas.......with low 12 /F's.... if THAT'S stage 1 power, Stage 2 will wipe the floor with anything currently available - and continue to do it SAFELY !!!!! |
