E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > JB4 Map 6 Questions
      08-11-2011, 01:05 PM   #1
Kuch335
2007 335i E92
Kuch335's Avatar
44
Drives: 2007 E92 TiAg, 2011 X3 35i
JB4 Map 6 Questions
Does anyone know what the values in map 6 would be to match map 0 .. in otherwords, what would 'stock' values be? I keep getting cyl 5 misfires with the JB4 on any map other than 0 so I want to see if a map 6 set to map 0 values would create the misfire, and if not, bump boost up until i get the misfire.. the misfires happen at open throttle, even w/o pushing past the kickdown..
Thanks..
2007 335i E92 AT - MHD E85 Flash, xHP Stage 3 , MR5 Intake, VRSF DPs, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, BL R8 Coils, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, CF Hood, Mini Battery :: 2011 X3 xDrive 35i - MHD Stage 1, Alum Charge Pipe
      08-11-2011, 03:13 PM   #2
Haus_07
E85 is my friend
Haus_07's Avatar
Drives: 2007 E90 335
Your best bet would be to email Terry over at burgertuning. He responds quickly, and being that he's the manufacturer of the JB series, he would be best suited to answer your questions.
//sparkling graphite metallic // sport package // logic 7 // m-tech wheel // HID fogs // LED angels // M3 style CF hood // matte black kindney's // AFE DCI // kittyless DP's // custom SS exhaust // Godspeed FMIC // 15ohm JB4// DV Mod //
      08-11-2011, 03:20 PM   #3
be1ieve1111
Thread Killer
Drives: 2014 EB M235i
This. He's good about answering questions within a reasonable time. Unless they're really busy.
      08-11-2011, 04:27 PM   #4
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Why dont you just go to map 0?
Eitherway it sounds like hardware related.
What is the mileage on the car?
How old are the spark plugs, fuel pump, injectors, coil packs ETC
If your signature is your mod list you should only be on map 1 unless otherwise directed from BMS to run map 6 and its settings.
e90post
