OBDII tuning on 07 335i sedan
08-10-2011, 12:54 AM | #1 |
Rep 333
Hey guys,
I just picked up a 07 335i yesterday with only 18k miles and was wondering if there are any good OBDII tuning devices out there to flash in a little more aggressive tune into it and to up the boost to around 13 psi on 93 octane? I noticed that Cobb has one, but it only states that its for the 08-10 models. Also, the car has the 6 speed auto steptronic and will it handle a modest upgrade to power ok without hurting anything? Does this auto use a torque converter or is it clutch packs? If I up the boost to 13 psi and a more aggressive tune, do I need to modify anything first to get to around 350 whp? Is the stock intercooler and everything ok to get to this power? Thanks for the help guys. Spoolin1 |
08-10-2011, 07:37 AM | #3 |
Rep 2,669
Cobb is is what your looking for. You will run 13 psi on stage 1 (which you can run all stock)
FMIC + Down Pipes will get you to 350+ pretty easy, you have to wait for Cobb Stage 2 though. Last edited by E90SoFlo; 08-10-2011 at 08:17 AM.. |
08-10-2011, 08:38 AM | #4 |
Rep 7,377
You wont have issues with the AT trans (TC) till you put upped turbos or nos
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
08-10-2011, 04:03 PM | #6 |
Rep 2,160
08-10-2011, 04:54 PM | #7 |
Rep 468
08-10-2011, 04:55 PM | #8 | |
Rep 468
Hi Spoolin1, Can I ask where you found we only support '08+? I'd love to get that changed. Cheers, Rob |
08-10-2011, 06:41 PM | #9 | |
Rep 2,160
No worries here ... I like 15psi of boost Rob, are the stage1 maps pretty much optimized for power on a stock car? Or when ATR/ATP is released can more power be safely extracted on a stock car? |
08-10-2011, 09:14 PM | #10 | |
Rep 468
Cheers, Rob |
08-11-2011, 06:36 AM | #11 | |
Rep 333
It was on your thread here http://www.e90post.com/forums/showthread.php?t=472813 . I didnt read far enough and only saw the part where it was for the 08-10, but after rereading through your first post, I ended up noticing that the 07 was now supported. |
08-11-2011, 08:27 AM | #12 |
Rep 2,991
Cobb for your 07 !!!
i got mine and LOVE IT !!!!! i'm running more like 15/16psi though with an aftermarket front mount intercooler and double cone intakes. i picked up @ 69hp and 98ftlbs from stock and my air fuel ratio consistently safe (low 12's to mid 12's) |
