E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > question, how do you know when the turbos are going bad?
      08-09-2011, 10:43 PM   #1
lawwailok
lawwailok's Avatar
Drives: E90 335i, E70 X5
have a question here for all the expert. how do you know when the turbos are going bad? i've seen videos of how the turbos whine. but also, will you see boost drop in that case? what other symptoms can we tell?
i've been having some problems, it's on and off, not always happens tho. if i am holding gear, when rpm rises, let's say 2500+, there's some sort of weird noise. i can only hear it when radio is off, window down. it is not exactly like those turbo whine video i've seen. but just some kind of "whine"... it's very fainted. i did datalog, all data looks perfect.
so i just want to see if there's any symptoms i can tell if the turbos are going bad....
-eric
E90 335i TiAg *STOCK* see my garage for mod list..
E70 X5 SGM *try to stay stock* :/
      08-09-2011, 10:59 PM   #2
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Turbo's make noises... dont find your problems let them find you
      08-09-2011, 11:07 PM   #3
tibra1
Drives: 2011 ZCP M3 - 2007 335i crashd
Tell tale sign when seals fail ,,turbo burns oil n really bad smoking..you would get that b4 noise
      08-09-2011, 11:15 PM   #4
lawwailok
lawwailok's Avatar
i don't get any smoke at all
-eric
      08-09-2011, 11:17 PM   #5
lawwailok
lawwailok's Avatar
true, but sometimes when there's something unusual or sounds odd, it feels annoying and want to find the root to fix it
-eric
      08-10-2011, 08:10 AM   #6
///M3THOD
///M3THOD's Avatar
Drives: 991.2 GTS
i just replaced my turbos..
They were leaking oil from the seals and the drivers side exhaust line was dumping smoke. The turbos were spooling and holding pressure fine, but they were on their way out. I also had an unbelievable amount of wastegate chatter, even after the BMW 8mm actuator swap.
Another telltale sign is a whistling turbo.
Here's a youtube video of it.. it didn't happen very often, only about 3-4 times over a 3 month period. I noticed it while driving and pulled into some random neighborhood to shoot this video before it went away.
2014 Individual /// M5 Competition AW/AB
|| Vorsteiner FF-103 || BMS JB4 || Meisterschaft GTC || RPI || IND || Challenge ||
      08-10-2011, 12:55 PM   #7
lawwailok
lawwailok's Avatar
wow.... i have none of those symptoms... but just there's one sound which is annoying somewhat and cannot find out where it is from
-eric
      08-10-2011, 01:53 PM   #8
taylors335
taylors335's Avatar
Drives: Space Grey 08 335i
2008 335i  [7.00]
waste gate rattle ?
      08-10-2011, 02:28 PM   #9
noobster
Drives: 335i
are you sure its not the sound of awesome?
what does it sound like?
      08-10-2011, 03:19 PM   #10
///M3THOD
///M3THOD's Avatar
Drives: 991.2 GTS
      08-10-2011, 03:54 PM   #11
lawwailok
lawwailok's Avatar
it definitely doesn't sound like those "turbo siren", but more like some sort of accessory whine noise.. it is very fainted and not producing all the time.. it's kinda on and off thing... hard to describe.
-eric
      08-12-2011, 05:46 PM   #12
aw335can
Drives: 2007-335i, 2009 AW M3 CPE
Dealer replaced mine last year after smoke issue started.
InJen DCI - Cobb AP - Macht Schnell - HKS Legamax - OE Performance Suspension
      05-10-2012, 08:42 PM   #13
Bme30
Bme30's Avatar
88
Drives: 335i coupe
2007 335i  [0.00]
Any changes?? Did you ever figure everything out?
      05-10-2012, 09:13 PM   #14
skim7x
skim7x's Avatar
Drives: 335i, C63 AMG
2007 335i  [10.00]
Exactly what I was going to say. Don't worry about it. You'll know when they need to be changed.
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife
      05-11-2012, 01:44 AM   #15
gzim335
gzim335's Avatar
Drives: e92 m3
2007/1 e90 335i  [2.00]
did you leave ur bolt ons on the car when they changed ur tb
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth
kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery
      05-11-2012, 02:59 AM   #16
garfi
garfi's Avatar
Drives: E93 335i
What can we do If we noticed same issue with this video ?
I have same smoke problem now.. with my rb turbos
FBO (with BMW Performance exhaust) E93 335i | RB Turbos | Procede Rev3 | Vishnu Pwm Meth
      05-11-2012, 05:13 AM   #17
woptang22
woptang22's Avatar
169
Drives: 2009 E92 BMW M3
Im Not trying too highjack this thread but curious about turbos failing also. I have an 07 335i with 37,000. I have been running COBB tune for a bit now and recently starter using stage 2+FMIC. I dont believe I have any turbo issues, but Im guessing Id be looking for smoke as a sign of turbo failure? And I have a third party warranty. If at some point turbos did go bad, I could uninstall the COBB AP, but what about the downpipes? Could the stay on the car or would they also have to be removed. Again sorry, Im not trying to highjack this thread, just getting a bit of info. Thanks all..
2009 E92 BMW M3.
e90post
