E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY video: convert h11 to 9006 foglights
      04-18-2007, 10:28 AM   #1
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
for those who bought the mtech kit, you must convert your h11 foglights to 9006. all the harness you need should come with the kit. heres is how it's done.
http://pepsiboi.livedigital.com/content/1511648
      04-18-2007, 04:57 PM   #2
shragon
shragon's Avatar
wonder why bmw decided to use 9006 for the m-tech kit.
nice diy!
      04-18-2007, 06:37 PM   #3
cm3rc
cm3rc's Avatar
Drives: 2006 E90
06 325i  [0.00]
nice one Long!
      04-18-2007, 07:01 PM   #4
Hunter399
Hunter399's Avatar
323
Drives: F90M5
Nice
ofcorse i just ordered a set of 9006 HID fog bulbs...
      05-13-2007, 07:54 AM   #5
MWcoupe
24k GOLD
MWcoupe's Avatar
Drives: Mineral White M4
should u get the mtec 9006 kit or is there any cheaper 9006 out there?
      03-25-2009, 11:28 PM   #6
MemphisRheins
MemphisRheins's Avatar
Drives: 06 330xi
links down
2006 330xi 6MT, ZCW/ZPP/ZSP
      04-04-2009, 12:31 AM   #7
r.c.y.k.
Drives: 335i
ya, links down, may op fix it please!
      07-28-2009, 12:34 AM   #8
yamazaho
Wang D.D.S.
yamazaho's Avatar
Taiwan
185
Drives: 14' WRX, 15' W205
2006 325i  [7.76]
Link still not fixed!!! I need to know this so I can do the installation myself!!!
      10-16-2009, 02:37 AM   #9
yamazaho
Wang D.D.S.
yamazaho's Avatar
Taiwan
185
2006 325i  [7.76]
this up, can the link be fixed Long!?!?
      02-09-2010, 07:07 AM   #10
piggelin
piggelin's Avatar
28
Drives: BMW 320i E90 2005
anyone? link is still broken
      02-09-2010, 10:30 AM   #11
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
i'll make another one as soon as i install another one. sorry guys. livedigital.com went down.
      02-12-2010, 06:31 AM   #12
piggelin
piggelin's Avatar
28
i really needed this haha
      11-23-2010, 10:51 PM   #13
azure
Drives: E90 325i
i need this too!!!
      01-24-2011, 11:27 PM   #14
jzchen
Drives: '08 335xi E90
Text version of how to do this...
realoem.com can give you the part numbers for the foglight sockets/connectors if you don't have them already. (I removed my M Aero bumper and put back the original one so I know.) You can just remove the little metal clips from the connectors, (original connectors are black, M aero are grey), and plug them into the new ones.
Look at your new connector, you will find a blue bar/piece inside that can slide up and down.
Disconnect your old plug from fog light bulb, and look for this blue bar/piece. Raise it up. It helps hold the clips in place.
Now you'll need to remove the metal clips that attach to the prongs of the bulb, but they are still held in place by something else:
Do this by pushing a small screwdriver down the sides of the clip. Looking at a clip, (there are two per socket/connector, inside you see two pieces of metal that look like " || " which attach to the metal prong from the light bulb. Push hard to break a little plastic thing holding the metal clip in place at the "+" position. +||+. Once you've pushed through on each side, (don't push too far or you might damage the rubber plug/water seal. I'm actually not sure whether I damaged one or it was damaged before when the shop swapped to the M bumper. I damaged 1 of the 3 that I did, the 1st clip just slid out because the one who installed it didn't slide it into the plug/connector all the way.)
You can now easily slide the clip out the back of the connector and slide it in the new one. (Be sure you remember to slide the blue bar/piece down before you attempt to attach the plug to your new bulb, otherwise you will break it. I did that in my excitement. I nearly completely destroyed the 1st old plug to remove the one clip because I couldn't figure out what else was holding it in. Again note that one clip just slid out because it wasn't inserted all the way.)
Sorry no pics, I'm not good at taking them and posting. If anyone must have them I can try to post some of the pieces I have left, (maybe pm me because I'm not planning on visiting this DIY anymore.) Or if you're in the area you can let me know and I can possibly show you...
Last edited by jzchen; 01-25-2011 at 12:19 AM.. Reason: Forgot a part of the proceedure!
      09-10-2011, 06:24 PM   #15
krnet2dboi
Drives: 2008 328i Base
Anyone have a pic by pic DIY for this?
There are only two types of cars in the world; BMW and the Rest
      10-23-2013, 12:47 AM   #16
tmdals0213
tmdals0213's Avatar
Switzerland
211
Drives: 2016 340i M-Sport
this needs to be updateddddd with some pics!
Diligentia Vis Celeritas
e90post
