First impressions of meth ...
08-07-2011, 09:11 PM | #1 |
Rep 190
Installed my Snow Stg 3 meth kit today and just got back from my first test runs. Let me start off with my mods:
BMS DCI STETT CP + FORGE DVs COBB AP ( 93oct V202 map) Snow Stg 3 Started out by testing on the stock tune with the cobb not installed. First impression was no change in the butt dyno. Which had me wondering if I was even spraying. ( I never tested the pump with the nozzles out of the charge pipe spraying water) So I decided I would install the COBB and see if I notice any drops in IATs. From all the reading I had done, I expected IATs to drop slightly below ambient at the top of 3 or 4th gear pull, this was not the case. Ambient temp was 72 and I was hitting 108-110 at the top of 3rd. I was still concerned that maybe I wasn't spraying at all. I then turned the controller off and did another 3rd gear pull and whoa!! IATS hit 140F at the top of 3rd. So this confirmed that I am spraying something. This got me thinking about my mix of meth. I have the 2.5 gallon tank and added about 1/3 gallon of distilled water , 1 gallon of Peak -20f windshield wiper fluid, and 1 bottle of HEET. I have no clue what kind of meth/water mix I have , I just added what I had around the garage. I didn't expect much in the butt dyno considering I am running the cobb , but I did expect my IATs to be closer to ambient. I suspect my stock FMIC is garbage and full of oil. My valves were worst than any I have seen on this forum at 55k miles, and My stett CP has oil puddles in it after only 5k miles. I will continue to play with the settings and different mixes. For now I am a satisfied, I've had the kit laying around since January and just now got it installed. Only thing weird I noticed is that I can hear the solenoid for the power nozzle make a "CLICK" sound when it activates. I can hear it inside the car, I am not sure if this is normal? |
08-07-2011, 09:27 PM | #2 | |
Rep 1,109
With that thread tittle i was expecting something like this:
2007 328i Crimson Red *SOLD*
2010 335i MSport AW E92 |
08-07-2011, 09:38 PM | #4 |
3441
Rep 79,211
Your meth concentration is very weak. Off the top of my head you are running maybe 40% meth concentration at most. I'm also unsure what nozzle is on the stage 3.
You should try using real methanol and something near 70% meth concentration. The point is moot however, the current stage 1 Cobb AP is not designed for meth. So you are simply wasting it until you can up the boost and ignition for meth. Just so you know, In near 100 Ambient temps, I was at 93 intake temps into 4th gear, running 19 Peak PSI tapering to 16 PSI by redline. Stock FMIC. Stock DP. So you either need a bigger nozzle, more meth concentration, or both. (and of course more boost which isnt available yet). |
08-07-2011, 09:49 PM | #5 | |
Rep 190
08-07-2011, 09:55 PM | #6 |
Rep 110
1 gal Peak -20: 33% methanol (42 oz meth; 86 oz H2O)
1 bottle HEET: 99% methanol (12 oz meth) H2O: 1/3 gal (42 oz H2O) 54 oz of methanol and 128 oz of H2O = 30/70 mix. But... this.
'16 M4 ZCP | 6MT | YMB | CSAT
'16 Aprilia Tuono V4 1100 RR, '08 FJ Cruiser |
08-08-2011, 05:50 AM | #7 | |
Rep 54
09 335xi Barbara Red Metallic Cobb AP BMS DCI
08-08-2011, 08:22 AM | #8 |
Rep 1,809
You will not gain anything from meth when using the Cobb tune, at most you will prevent some heatsoaking in hot days. You could however use the 93 octane map with 91 octane fuel + meth.
08-08-2011, 08:42 AM | #9 |
Rep 1,109
+1
08-08-2011, 09:00 AM | #10 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
Wouldnt you see less boost with lower intake temps?
08-08-2011, 11:09 AM | #12 | |
3441
Rep 79,211
Boost juice is a waste of money, your shipping nearly half of water and paying a premium for it. Just find a local automotive hot rod place and ask them if they sell meth or kno someone that does. Worst case scenario go to home depot and just get denatured alcohol. |
08-08-2011, 11:16 AM | #13 | |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
08-08-2011, 11:23 AM | #14 |
Rep 3,730
If you don't have anyone who sells methanol near you just buy some Boost Juice (50/50)from SummitRacing.com, yes it's expensive but sometimes it's your only option. You can also try Homedepot, they sell denatured alcohol which is usable.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
08-08-2011, 12:51 PM | #15 |
Rep 957
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
08-08-2011, 01:03 PM | #16 | ||
Rep 1,054
To try the nozzles out of the charge pipe is a must after the installation if you're asking me... Last edited by Big Tom; 08-08-2011 at 01:10 PM.. |
08-08-2011, 01:45 PM | #17 |
Rep 375
235 ml/min is def not much meth and I dont like how snow performance doesnt rate their nozzles on their site. Sounds like the OP needs more meth concentration and bigger nozzles.
08-08-2011, 03:07 PM | #18 | ||
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Meth is sprayed AFTER the intercooler. So even if you dump 5 tons of meth in the system, the intercooler will be just as heat soaked. Quote:
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
08-08-2011, 04:52 PM | #19 |
Rep 432
08-08-2011, 07:48 PM | #20 |
Reborn
84
Rep 1,217
He's referring to how COBB bases boost targeting with load.
08-08-2011, 07:51 PM | #21 |
Poor Kid with Dreams
28
Rep 702
Correct me if I'm wrong, but the Cobb controls boost by targeting load. In hotter conditions the boost will increase and in cool environments the boost will decrease to keep the same torque target.
'07 BSM 335xi JB4, DCI, CX Racing I/C, ER Chargepipe, Meth, KW V3 - Pending Sale '95 Mustang GTS 347ci Ported TFS TW Heads,Custom Cam,Victor 5.0 IM,Tubular Front Suspension,Full Exhaust,Big and Littles |
08-08-2011, 08:41 PM | #22 |
That guy
117
Rep 5,740
yes, i was referring to the fact that with load tuning, it takes more boost on hotter days to reach a load target and less boost on cooler days. Assuming the cooling effects of method has the same effect as a cooler day, I was just suggesting that even with a cobb stage one, meth would benefit in helping lessen the stress on the turbos.
