Boost tube through firewall?
08-07-2011, 11:53 AM | #1 |
Rep 190
I have everything wired on My Meth kit, besides the wire to the solenoid and the boost tube. Where can I get through the firewall that will place me near the charge pipe on the other side?
08-07-2011, 12:01 PM | #2 |
Rep 2,875
If you take off the panel under the steering wheel column, and you look to the part where the steering goes through the firewall, you'll see a rubber grommet piece that surrounds the actual steering column; that's where you can poke through with a coat-hanger to lead the boost tube/wiring through.
That's where I used to set up my Rixster vented boost gauge..... Hope this helps
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
08-07-2011, 12:02 PM | #3 |
Rep 794
1 Under the steering wheel there will be 3 Torx Screws.
2 Drop the panel 3 on the bottem left corner there will be a rubber nipple poke a hole threw it with a screw driver or somthing 4 run the wire and you will see next to the power steering i believe in the engine bay,
Gone But Not forgotten:
-07 Shelby GT500 W/ Full Bolt on E85 -08 335i 6MT W/ Full Bolt On E85/Meth -08 M3 DCT W/ Full Exhaust / Tune -13 B8 Audi S4 APR Stage 2+ |
08-07-2011, 01:41 PM | #5 | |
Rep 1,027
No drilling is required. Look at steps 12-15 in the install guide. I used a metal coat hanger and taped the tubing at the end and pulled it through to the engine bay. Hope this helps.
2002 E46 M3 /// 2008 E93 335i FBO /// 2010 E93 335i M-Sport /// 2014 F33 435i M-Sport /// 2009 E90 M3 ESS VT2-625 /// 2011 E93 335is /// 2013 E70 X5M
08-07-2011, 04:55 PM | #6 |
Rep 794
theres no wall. dose it have wires going threw it?
