328i top speed..
04-04-2007, 03:05 PM | #1 |
Rep 1,243
328i top speed..
My conclusion on the top speed.. I have a none sport package 328i, I have hit 130mph a few times but was not table to keep going or sustain it. Well today I was lucky enough to have a nice long 6-8 mile empty stretch of freeway, I went WOT from 100mph and hit 130 and the needle kept going then bam 135 the RPM seemed to just stick and not allow anymore. I let off and went down to 120mph then WOT back to 135 again hitting a limit... So my conclusion is the 130 limit is set to 135 mph to allow for speedometer error of around 5% which seems reasonable. So driving an indicated 50 mph you are really only going 47.5 mph which seems reasonable.
04-04-2007, 03:08 PM | #2 |
Rep 538
Drives: 2022 M3 Comp xDrive
I think somebody posted earlier that there is a setting that can display the real speed which the OBDC keeps track of which is 5% lower than the indicated speed on the speedometer.
2022 Tanzanite Blue ///M3Cx ||| 2015 550i ||| 2011 328i sedan ||| 2009 Z4 ||| 2007 328i Coupe
04-04-2007, 03:12 PM | #3 |
Rep 2,485
Just borrow a portable GPS and read the speed from that.
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
04-27-2009, 03:21 PM | #4 |
is also an E46 Fanatic
39
Rep 538
what is the top speed of e93 w/ sport package... for some reason it seemed the limiter kicked in at 130 mp/h.
Does having the top down make a difference? |
04-27-2009, 03:30 PM | #5 | |
Rep 2,032
Drives: Red Flyer
Not sure about the top, but BMW lists the speed as 130mph without the sport package and 150mph with: http://www.bmwusa.com/Standard/Conte...fications.aspx Same thing for a 335i.
04-27-2009, 03:33 PM | #6 |
3441
Rep 79,211
Ive been noticing at several "speed traps" that my speedo reads lets say 40 MPH but the speed trap read out is near 37. Ive hit several different speed traps in different towns and im always off by about 2 MPH.
Like most European cars, they feel slower at speed, but I truly feel the speedo is off. As far as top speed.... Havnt hit the limiter yet |
04-27-2009, 03:40 PM | #7 | |
Rep 2,032
Drives: Red Flyer
As noted above, the speedo is off by a few %. Going through the secret menus to get to the digital display will show the true speed.
04-27-2009, 03:42 PM | #8 |
Rep 10,411
The speedo get exponentially (sp?) worse as you increase speed. I would not be surprised if the speedo say 130 and you going only 120. They are always off and make the speed look higher than it really is.
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
04-27-2009, 04:49 PM | #9 |
Guest
36
Rep 611
I topped out my 2006 BMW 330i at ~145mph.
2006 Black BMW 330i, Black interior, ZSP, ZPP, Logic 7, Xenon, Ipod, Satellite Radio Preparation, Moonroof, 12'' 2 P2 subwoofers running on KAC-7204 amplifier, Hardwired Escort Passport 8500, Hardwired Garmin Nuvi 650 on Kuda Mount.
tutor,math tutoring,math tutoring,test prep,tutoring jobs,tutoring blog |
04-27-2009, 05:13 PM | #10 |
Rep 6,594
Search, there are a whole ton of threads on the speedo issue.
It basically comes down to a very strict law in Europe that states the speedo can NEVER, under any circumstance, read below the actual speed of the car. So instead of cutting it close, BMW (and other European cars?) chose to have an offset programed in. There are a series of hidden menus in the E9x cars that allow you to see actual speed vs. reported speed, in KPH only. But it's perfectly normal for these cars to read 2-10MPH slower, depending on speed. My opinion? Pisses me off. and if the law isn't the same in the U.S. they should deprogram this out of U.S. cars. Can't understand why it would be difficult.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
04-27-2009, 06:10 PM | #11 |
39
Rep 538
04-27-2009, 06:22 PM | #12 |
Rep 6,594
The car is perfectly capable of reading the exact speed, the offset is done deliberately.
See here for non-iDrive and here for iDrive.
04-27-2009, 06:24 PM | #13 | |
Rep 2,032
Drives: Red Flyer
http://www.e90post.com/forums/showth...ht=Secret+Menu
05-02-2009, 08:20 PM | #14 |
Rep 15
I felt that my speedometer was off and I too tested it on a couple of those roadside radar things that show your speed. I used the cruise control to be sure I was going a steady speed. On every pass between 40 mph and 70 mph indicated on the speedo the radar sign showed me traveling 4 mph slower than that.
