2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Recall
      06-09-2011, 10:48 AM   #1
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
Recall
Just had a recall on my 4 week-old F10. Recall 0064650100, some kind on water ingress seal on the A/C electrics.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      06-09-2011, 02:33 PM   #2
Captain Chaos
Captain Chaos's Avatar
Drives: cars n stuff
Super, mine gets PDI'd next week they can do it at the same time.
      06-09-2011, 04:45 PM   #3
Mud
Drives: M4
already? Well I guess at least they are on top of it...
      06-15-2011, 07:14 AM   #4
Mud
Drives: M4
Details;
0064650100 - BMW (UK) Quality Enhancement Procedure - Delivery stoppage - Seal the fan housing - F0x F1x
Situation
Due to a manufacturing defect, the fan housing of the vehicles concerned is not leaktight.
Effect
Moisture can enter the vehicle interior through a hole in the housing cover.
Vehicles concerned
F0x F1x
According to VIN selection (15.04.2011 - 21.04.2011).
Action
Seal the fan housing using butyl.
Procedure
Disconnect the battery negative lead, see Repair Instructions 61 20 900 "Disconnect battery negative lead".
Remove the right/rear dome strut, see Repair Instructions 51 71 346 "Remove and refit/replace (rear) right dome strut".
Undo the auxiliary electronics box and swing it to one side.
Undo the screws (1) from the fan housing cover (2). (Similar to graphic).
Lift the housing cover slightly and turn it to one side.
Seal the triangular hole in the upper right area (see graphic below).
Butyl must be used as the sealant, similar to part number 83 19 2 165 900. You do not
have to order this part number if you have other butyl available in the workshop.
Note: A maximum amount of 2 cm of butyl is required for sealing.
      06-15-2011, 07:19 AM   #5
xenon
xenon's Avatar
England
1397
Interesting. Mine was booked in on Monday but I had a call from the dealer saying "the part had not arrived from Germany" and that I'd have to rebook for the following week. If it just needs butyl sealant then what gives???
Ian
      06-15-2011, 07:34 AM   #6
Mud
Drives: M4
Surelt they dont wait for glue from Germany!
      06-15-2011, 08:09 AM   #7
xenon
xenon's Avatar
England
1397
I'm assuming it's an example of dealer bullshit. Where did you find that info, Mud, and do you have the pictures that go with it?
Ian
      06-15-2011, 11:08 AM   #8
Mud
Drives: M4
Here is the only pic I got sent attached.
Got the info from my contact at BMW.
      06-15-2011, 01:30 PM   #9
Captain Chaos
May be the right rear dome strut is replaced by default, could be the part they're waiting for I guess..?
      06-16-2011, 01:42 AM   #10
xenon
xenon's Avatar
England
1397
Perhaps, but I can see no reason why you'd need to replace a gas strut on a four-week old car?!
Ian
      06-16-2011, 04:46 AM   #11
Mud
Drives: M4
According to BMW my car is not affected by this recall
      06-16-2011, 07:32 AM   #12
xenon
xenon's Avatar
England
1397
Only one week of production so I don't suppose there's that many. I'm waiting for the dealer to call me when the "part" arrives.
Ian
