      05-19-2011, 08:42 PM   #1
rapter
Drives: 1(M)other f*^#er of a car
Winter tire 1m discussion
I would like to start the winter tire discussion on this thread. Specifically for those in the north who will likey not be putting the car out in 4-6 inches of snow but still would like to cruise in the and on the cold asphalt.
Personally I would like to know/ share information on what rims and tires are available for this beast in 6-8 months.
I am looking to get 18" rims with the offset pattern similar to what has come with the vehicle. 17" would be ideal ... But I don't know if I will clear the calipers
The Calculations for offset that I have been able to make using 1010tires.com is the following:
The object in these cases is to be able to use the same stock tire sizes of 245 front/ 265 rear with different aspect ratios to accomplish the same offset.
Using the stock set of
9.0 wide x 19" x 31mm offset (Front)
10.0 wide x 19" x 25mm offset (Rear)
Offset Calculation for 8.5 front and 10 rear in an 18" diameter:
Front - 8.5" wide x 18" x 25mm offset - this will keep the outside face of the wheel in its' current position and the inside face of the wheel (the part closer to the center of the car) will retract by 12mm
Front - 8.0" wide x 18" x 18mm - this will keep the outside face the same and the inside face will retract by 26mm
Rear - 9.5" wide x 18" x 19mm - this will keep the outside face the same and retract 12mm on the inside
Rear - 10" wide x 18" x 25mm - These dimensions will remain unchanged from the stock configuration as the wheel width is the same.
The Tires:
Stock Tires Read as follows:
245/35 R19 Front
265/35 R19 Rear
Using an 18" Winter tire to obtain the minimal loss of rotational speed using the following:
245/40/18 = 0.1% too FAST (Traveling at 60mph = 59.9mph in reality)
265/40/18 = 0.2% too SLOW (Traveling at 60mph = 60.1mph in reality)
235/40/18 = 1.4% too FAST (Traveling at 60mph = 59.2mph in reality)
245/45/18 = 1.4% too SLOW (Traveling at 60mph = 60.9mph in reality)
What a science...
Tire prices care of TireRack:
(Front) Bridgestone Blizzak LM-60 245/40/18 = $233.00 each
(Rear) Bridgestone Blizzak LM-60 245/45/18 = $229.00 each
(Front) Michelin Pilot Alpin PA3 245/40/18 = $243.00 each
(Rear) Michelin Pilot Alpin PA3 245/45/18 = $245.00 each
      05-19-2011, 08:44 PM   #2
DiavelM3
4 Star General -Twilight Zone
DiavelM3's Avatar
Drives: '11 E92 M3 ZCP
I've always had really good luck with Conti Extreme contacts
      05-19-2011, 11:19 PM   #3
ducturd
Drives: Ted Danson
This is something I've been wondering about in the back of my mind. Specifically, what rims and what tire size choices are there?
Tirerack isn't listing any winter tire & wheel combos for the 1M (perhaps because summer is upon us?).
      05-19-2011, 11:31 PM   #4
HERR FSTIR
HERR FSTIR's Avatar
Drives: LBB M2C, VO 1M, GSA 1200
Whatever fits the M3 should work, so search for M3 winter setups at tirerack.
Personally I am leaning towards 18" Blizzaks. I don't think you can fit 17" wheels around the brakes.
      05-20-2011, 12:07 AM   #5
Drillslinger
Germany
22
Drives: BSM 1M / R53 / E91
Here in Germany BMW offers a winter tire package (Code ZPY IIRC) which uses the Michelin winter tires in a square setup, there was a thread on it before...
... yep, here we go: http://www.1addicts.com/forums/showt...&highlight=ZPY
Vorsprung durch Gas Geben!!
172 of 740
      05-20-2011, 12:25 AM   #6
HeyMoe53
Drives: '17 M240 AW/Coral MT
It's just me--but, if I owned a 1M, it wouldn't be out during winter. My humble 128 is tucked away December-February. My Focus takes care of winter, with the Blizzaks on.
That was my plan all along. Your plan may be different, but the thought of a 1M pulling through snow, slush, and slop, along with the attendant washing issues was never on my radar. But, hey, that's me. I'm sure that the above snow tire plans would work out for you, given the 1M's M3 suspension heritage.
Drillslinger--Here's hoping BMW brings the 1M to military sales. Can't think of anyone who would deserve such a sweet ride any more than you!
      05-20-2011, 03:26 AM   #7
Drillslinger
Germany
22
Thanks, but don't give me too much credit, lol. It's the active duty guys who deserve it... I haven't worn the "green suit" in a few years ;-)
172 of 740
      05-20-2011, 03:48 AM   #8
DarthColin
DarthColin's Avatar
Drives: 2011 1 Series M Coupe
I was waiting for someone to start this one. Gil at TireRack told me they would figure out a preferred winter package when they get their hands on one to test. I would really like to stick with a staggered setup.
Does anyone know the offsets etc. yet? I saw some black M6 18" wheels online that I thought would look cool. And they were cheap.
I live in Canada (think Minnesota winter), and will be travelling mostly on major highways in wintertime. Unfortunately, I may be able to report back on how the front spoiler functions as a plough.
‘If it even looks like rain and you pretend to be Michael Schumacher in a 599 GTO, you’ll end up in a tree’ -Clarkson
      05-20-2011, 05:06 AM   #9
Drillslinger
Germany
22
I'm pretty sure the wheels are the exact same ones that are on the M3 Comp. so whatever those are...
Edit: Ok, according to http://felgenkatalog.auto-treff.com/
M Coupe
9x19 *vorne (Front) 245/35R19 ET 31, 11.90kg (26.23 lb)
10x19 *hinten (Rear) 265/35R19 ET 25, 11.20 kg (24.69 lb)
(I don't quite get how the rears weigh LESS than the fronts though )
HTH
172 of 740
      05-20-2011, 06:16 AM   #10
Dan Parker
Drives: 2012 Golf R
Big torque + snow = suck
Snow tires or not I would avoid driving this car in the snow at all cost.
My .02.
Dan Parker
      05-20-2011, 07:39 AM   #11
rapter
M Coupe
HTH
The Tires:
245/35 R19 Front
265/35 R19 Rear
What a science...
      05-20-2011, 08:51 AM   #12
discoboy1
discoboy1's Avatar
Drives: E82 1M VO/F30 328D
Specs for winter wheels are 270M
18x8 et 20 square setup with 235/40/18 tires
http://felgenkatalog.auto-treff.com/left.php?start=2#
I am actually thinking of putting 235/45/18 all around... .1% difference with back and 2.2% front.
45 profile makes for a cheaper tire.
2011 E82 1M VO
2013 F84 35i VO
      05-20-2011, 09:11 AM   #13
1Mer
Drives: 1 Series M Coupe
I'm not intending on going out in the snow (got a Landrover Defender for that!) but I am looking for winter tires that have more grip at cold temperatures.
I prefer to keep the standard M359 wheels (actually I'm thinking of buying another set) and am just looking for winter tires to fit them.
Trouble is, it doesn't look like there's much choice out there in those sizes.
      05-20-2011, 10:44 AM   #14
discoboy1
discoboy1's Avatar
Here is a great tire calculator!
http://www.rimsntires.com/specs.jsp
2011 E82 1M VO
2013 F84 35i VO
      05-20-2011, 10:50 AM   #15
ESC OFF
ESC OFF's Avatar
40
Drives: 1M, CaymanS, 914, 500 Abarth
I've been running Goodyear Ultra Grip Performance Winters for winters, they are amazing tires, they are better in the dry than my stock run-flats!
The faster you go, the better it feels
      05-20-2011, 12:07 PM   #16
Grey Dove
Grey Dove's Avatar
Drives: Sold for a reptile
That's what I did and bought a set of M359 and will put the Vredestein Wintrac Extreme on them sizes 245/35/19 in front and 275/30/19 behind.
The tires run one winter on the e60 so they're kinda new and did great.
Oke the e60 weighs more but it also had 600nm torque
      05-20-2011, 01:19 PM   #17
swanny71
swanny71's Avatar
Drives: 1M, M135i
I used 245/35/19 & 255/35/19 Wintrac Xtremes on my e90 m3 last winter - they were very, very good. Put them on a second set of OEM 19" M3 alloys.
p.s. the M3 has gone so the wheels & tyres will be for sale October time. PM me if you want to get in first
      05-20-2011, 01:33 PM   #18
Rasya
Rasya's Avatar
Belgium
37
Drives: 2011 BMW 1M; 2016 M4 GTS
2011 BMW 1M  [10.00]
2005 BMW e60 M5  [0.00]
What did you pay those wheels in belgium?
Does anybody know why BMW is putting 265 tires on a 19x10" wheel? The tires appear undersized to me, I would think (as GS poses) you could fit 275 or even 285 on the standard 1M rims, no? My sincere apologies if I'm talking crap here
Anyway, my plan for an extra set of rims was to buy gunmetal Advan RS's, sized 18x9 and 18x10 or 18x8.5 and 18x9.5.
My dot-spec track tires on those rims would be 255 and 275/285.
And for winter use (maybe in two years or so, for now I'm good with my audi A3) I thought of 235/245 and 255/265.
Can anyone tell me about the possibilities here? Am I dreaming or is this possible. I really want track wheels, but I feel absurd buying 2 extra sets of wheels...
Thanks to anyone with ideas
      05-20-2011, 01:43 PM   #19
ptack
ptack's Avatar
Drives: 135i
2008 135i  [6.50]
My .02.
It's not that different from the 135i and with proper rubber, snow's no problem.
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod, Apex EC-7s, PPK Stage II
      05-20-2011, 01:44 PM   #20
Grey Dove
Grey Dove's Avatar
wheels...
The moto safety car has the 265/F-285/R setup. So it shouldn't be a problem
      05-20-2011, 07:47 PM   #21
DarthColin
DarthColin's Avatar
Thanks for info everyone. I'm leaning towards the Dunlop Wintersport 3D, on whatever decent-looking wheels that fit. Preferably 18" staggered, unless the experts say otherwise. Don't think I will be able to avoid driving it in the winter. If some people drive a 911 in the winter, then I should have no problem driving a 1M.
      05-20-2011, 10:46 PM   #22
dominoM
Private Low Class
300
Drives: G87 M2 ZB 6MT
I've had the Dunlop Wintersport 3D on my E36 M3 for 2 years now. Great tire.
Good thread. Thanks.
1addicts
