Procede v5 Traction Control (video and datalogs)
05-19-2011, 12:46 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Now that we are back on track with v5, here's a little demo of the traction control system we've been working on. It's a bit more sophisticated and functional than the old TC we offered. It has the ability to reduced torque by as much as ~200lb-fts when traction loss is detected. As before, you will be able to set its "sensitivity" to best suit your driving preferences. It will work in combination BMW DCT/DSC. But it really shows its merit when all the BMW nannies are turned off as down below.
Same stretch of road. Tested in Mexico. Datalogs will show what the Procede is doing with boost with respect to detected wheelspin. Video will show what I'm doing with the steering to control oversteer/wheelspin. Put them both together and you have a pretty good idea of what is going on. BMW Traction Control ON (set to max sensitivity) BMW Traction Control OFF Summary Depending on the severity/duration of wheelspin, boost will be dropped to as low as 0psi. Once traction is regained, boosts will be brought back up to the normal target level. As the videos demonstrate, there is a lot more driver involvement needed when Procede TC is off. Much more throttle management. Much more steering correction at turn exit when applying power. Basically, more of a handful to drive. All testing was done on a 6AT FBO car running performance tires, a few m3 suspension bits and Koni FSD shocks. The roads were completely dry. I'm looking forward to retesting on wet surfaces. Disclaimer Do not attempt this on public roads. We do not condone such tomfoolery. This testing was done in a controlled environment with a professional test driver. Procede Traction Control IS NOT A STABILITY CONTROL SYSTEM. It will not apply brake force to any wheel. It will not prevent a loss of car control. It is purely a feature designed to manage wheelspeen under power. As always, this is an off-road-use only product/feature. |
05-19-2011, 12:49 PM | #2 |
Rep 2,661
cool but i like it off lol
05-19-2011, 12:50 PM | #3 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Very cool! When will this be available? Was that the N54(335i) or the N55(135i)? Where you running meth in those runs?
very nice views of mexico...
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
05-19-2011, 12:52 PM | #4 |
1737
Rep 17,960
Drives: A Lot
That was just demonstrating a traction threshold setting of 0% (TC on) and 100% (TC off). I personally run a value of 40% which allows just enough whelspin to have fun. But not too much to ever slow you down.
That was tested on an n54. No meth installed (yet). Just 91oct and FBO. |
05-19-2011, 12:52 PM | #5 |
Rep 7,377
controlled environment good driving shiv! cant wait to test it on my car since i dont have any traction right now
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
05-19-2011, 12:58 PM | #6 |
Rep 2,663
If yo can, see if you can get your hands on a xi car to see the difference in wheel-spin with traction control off. I'll like to compare videos and see the difference in logs.
Will these logs look difference if DTC is engaged? (Pressing the DTC button once) |
05-19-2011, 12:58 PM | #7 |
1737
Rep 17,960
Drives: A Lot
05-19-2011, 01:01 PM | #9 |
Rep 728
Very exciting stuff Shiv. Can't wait to test it on track! Besides the smooth throttle response, this is probably my most anticipated feature for track use!
I'd be interested in seeing what datalogs look like w/ DTC pressed once (just DSC). Any chance you have any on hand?
PROcede | AMS FMIC | AR Catless DPs | AR Oil Cooler | BMS DCI Wavetrac LSD | KW V3 w/ Swift Springs | M3 Front Suspension |
05-19-2011, 01:04 PM | #10 | |
1737
Rep 17,960
Drives: A Lot
05-19-2011, 01:05 PM | #11 |
PSI
15
Rep 349
I dont know about you, but the only time I can get mine to even chirp the tires is a full launch in standing water --- if you're manual... you may be able to get some more out of the hole. Other than that, only on really tight bends with full throttle, but the traction loss only helps the car rotate at that point.
2011 335d, M-sport, Alpine White, Nav
05-19-2011, 01:07 PM | #12 | |
1737
Rep 17,960
Drives: A Lot
05-19-2011, 01:19 PM | #14 | |
Rep 2,663
So Shiv, If I leave TC off (100%), would it act as if I pressing the DTC button once or will I have to press it to feel what I'm describing above? |
05-19-2011, 01:34 PM | #15 | |
1737
Rep 17,960
Drives: A Lot
05-19-2011, 01:35 PM | #16 |
Formerly (-(ellblazer420
48
Rep 703
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
OOOOOOOO this will be a nice little add on to help me out with the new meth kit. Good work Shiv.
05-19-2011, 01:41 PM | #17 |
Rep 2,368
i like how the xi ppl are rubbing it in our faces. "Oh i never see traction control turn on... i dont see how this will be useful..." Obviously it just means either you havnt driven your car hard enough, dont have enough power, or you have so much traction its not even a concern.
05-19-2011, 01:45 PM | #18 |
1737
Rep 17,960
Drives: A Lot
Here are two little standing start, straight line runs I did with Procede TC ON and TC off. BMW nannies were completely disabled. Foot to the floor. Can you guess which run is which?
05-19-2011, 01:52 PM | #19 |
Rep 2,661
ya and im going to try that
05-19-2011, 01:54 PM | #20 | |
PSI
15
Rep 349
05-19-2011, 02:06 PM | #21 |
Rep 92
Drives: 2011 335xi
I cant get a clean 1-2 shift without the traction control light kicking on and bogging when i get on it. I messed with the settings on my procede and it seems to help some times
2011 Black 335 xi MT- M package- Cold weather- BMW Performance Grills-PIAA H8 yellow fogs-Procede V5-Vishnu DP 3.5 inch- CDV delete-Vishnu Charge Pipe - ***Waiting on meth kit*** - H&R Springs Sport Kit
05-19-2011, 02:09 PM | #22 |
Rep 3,730
I was thinking the same thing I can't wait to test these out! (in Mexico hopefully) Keep up the great work Shiv!
How does this effect the functionality of LSD's? Does it work in coordination with it, or will it cut off torque once it detects wheel spin?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
