CM fx100 slipping in high gears
05-19-2011, 10:20 AM | #1 |
Rep 634
So after an initial long break in period with this clutch it was holding up great for the last 3000 miles. Then driving home a couple days ago I hit the gas in 5th gear and noticed a slight jump then drop in rpm. I was able to repeat this both in 5th and 6th gears and then it stopped and held fine. I get in the car yesterday and after startup I decide to try again(waited till temps reached 200 so car would boost) and I go full wot in 6th and it slips even worse then the day before, but after driving and going through the gears it stops happening and holds fine. I called clutchmasters they said they have heard of this on cars that have a proportioning valve between slave and master cylinder. Does anyone have any ideas what could be the problem. Why am I getting these small slips in high gears and only when I initially drive. Thanks
05-19-2011, 06:32 PM | #3 |
Rep 5,876
Other than mine going out after 4500km I already heard of three others with short life span from clutchmasters...mine was a 6 puck ceramic and I thought that may have been the reason but now I'm starting to wonder wtf is up with CM on these cars...try talking to Luis at CM and put in a warranty claim as that's definitely not normal...
I wonder if anyone here has run a CM clutch for a longer period than 15,000km, anyone? |
05-19-2011, 06:40 PM | #4 | |
Rep 634
I spoke to awd motor sports the vendor I purchased it from and they said they have never heard of a problem with a cm clutch. They said they would call cm and see what they could do. They havent called me back its been 5 days. Just bc they havent heard of a problem doesnt mean they dont exist its supper frustrating have to pay for install again, and not having your vendor at least least try and help me get new parts. Last edited by 335iLI; 05-19-2011 at 06:45 PM.. |
05-19-2011, 06:50 PM | #6 |
Rep 634
05-19-2011, 07:25 PM | #8 |
Rep 634
05-19-2011, 07:28 PM | #9 |
Rep 5,175
05-19-2011, 07:36 PM | #10 | |
Rep 634
I talked to cm they said the fx100 doesnt hold that much. Maybe they should change that 70% to 10% |
05-19-2011, 07:40 PM | #11 |
Rep 5,175
05-19-2011, 08:18 PM | #14 |
Rep 634
05-19-2011, 08:37 PM | #15 |
Rep 5,175
05-19-2011, 08:44 PM | #16 |
1 Stock M
76
Rep 1,650
Drives: Something Slow
CM is good. I def would go with ACT though. Never had a problem with those clutches before.
Veteran USMC/Iraqi Freedom
Current: E46 M3 Retired: 2009 E90 AW M3 Retired: 2007 E90 AW 335i. |
05-19-2011, 08:47 PM | #17 |
Rep 854
i was so close to getting the CM clutch/flywheel, im glad i didnt, i did get my flywheel resurfaced by them though in under 30 minutes!
I have a ACT clutch and its great no problems.
10' Solid Red GTR
08' 335i 6MT - Sold 92' NA 300ZX 5speed - Sold 06 IS350 - Sold |
05-19-2011, 10:15 PM | #18 |
Rep 634
05-19-2011, 11:05 PM | #20 |
Rep 634
