N54 Fault Code CDA7 / 52647
05-19-2011, 07:12 AM | #1 |
Rep 56
Anyone can shed some light as to what the fault code CDA7 is?
Happens pretty consistently, anytime I accelerate gently to around 100mph, I get the half-engine light and reduced power. This light goes away in about a minute and power is restored. I'm running Procede V5 3-30. |
05-19-2011, 07:28 AM | #2 |
Rep 7,377
CDA7 STATUS, REVERSE GEAR .
No idea Do you get it in valet as well? if yes i would remove completely the procede and see if it still happens.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
05-19-2011, 11:12 PM | #3 | |
Rep 56
Happens in valet too. Will try removing the Procede though I think it's probably the car acting up. Thanks! |
01-13-2015, 11:56 PM | #6 |
Rep 1,951
Did any of you ever sort out what this was? My car has no obvious problems, but this is the one code that consistently comes up and doesn't seem to be related to "module unavailable." For example, I have code E18F on CCC, but that's something like "module failed to respond" which makes perfect sense, since I don't have a CCC.
