Bleeding Clutch Help :(
05-16-2011, 09:59 PM | #1 |
Rep 151
So I removed my CDV today and now I can't figure out how to bleed the system. I've read all the DIY's on here, but I still can't unscrew the valve. I'm using a 11 open ended wrench. There's only enough room to turn it about 2cms. I can't do a full rotation.
Also, do I need to turn the plastic nipple too? Here is a picture for reference. I've already taken out the plastic covering though. I'm not sure if I even need to bleed though. My clutch feels the same, but I'm sure there is air in there. Any long term consequences of leaving the air? |
05-17-2011, 06:53 AM | #3 |
Rep 923
I never bleed my clutch with I installed the modified Clutch Delay Valve, but if you want to bleed it, removed the rubber cap from the bleeder valve, loosen the nut on the bleeder valve about a 1/4 to 1/2 turn, and attach a bleeder hose. The next part takes 2 people....one will depress the clutch pedal, after the clutch pedal is in, tighten the the bleeder valve nut. Once its tight again have the other person pull the clutch pedal back up. Repeat until no air bubbles come out of the bleed line. The technique above is taken from where I read somewhere on the forum, so I am not sure if there is a easier way, but since no one else replied I thought I would try and give ya a little help. As far as the consequences of not bleeding the little bit of air out, I'm not sure.
05-17-2011, 07:24 AM | #4 | |
Rep 4,703
As for the consequences of having air in your system? You need to compress fluid to release your clutch, if you have air in the system you cannot compress as much fluid so you may find that you are grinding some of your gears when shifting or the clutch pedal may feel a little mushy as opposed to firm. If your pedal feels fine and your gears are changing smoothly then don't worry about it. |
05-17-2011, 02:39 PM | #5 | |
Rep 151
Thanks for the info. I know everything you said. I'm just having a hard time loosening the bolt. I can only turn it just a little bit and nothing comes out. I've read that one must also turn the rubber nipple. I need clarification thanks! |
05-17-2011, 02:46 PM | #6 | |
Rep 28,154
make sure the clutch resiviour is full, its in the back of the brake master cylinder, it doesnt hold very much at all have someone pump the clutch a few times, and then hold it down, open the bleeder, yes its tight it may take a few repositions with the open end of the wrench, let the air/fluid come out, and repeat until the pedal feels good. keep in mind during bleeding that the clutch system doesnt hold much fluid, so every two or three bleed cycles check the fluid level |
05-17-2011, 06:05 PM | #7 |
My X5d tows my spec miata to the track.
74
Rep 1,254
I tried bleeding my clutch with the above method when i flushed my brake fluid and it never worked. I don't know what kind of shithead designed that valve location but he ought to have his ass removed. Anyway, I ended up just opening it and used a suction bulb to draw the fluid out. I just could never get the clutch pump method to work. I read somewhere that depressing the clutch all the way let's air in and you're only supposed to go half way. Try the suction method. Its much easier.
05-17-2011, 06:07 PM | #8 |
Rep 10,587
you can just remove the slave cylinder and do it while its in your hand, easier. Lets you position the bleeder as the high point as well to make sure all air is out.
05-17-2011, 06:13 PM | #9 |
Reading > Posting
20
Rep 220
The problem most people run into, including myself, is just that the resovior isn't actually full. There is a partition inside to seperate the brake and clutch systems. Even if it looks full, make sure to top it off and make a run at pumping/bleeding again. Good luck
05-17-2011, 10:02 PM | #10 | |
Rep 151
05-17-2011, 10:03 PM | #11 | |
Rep 151
05-18-2011, 07:37 AM | #12 |
Reading > Posting
20
Rep 220
I am by no means an expert, so I really couldn't tell you. My guess would be enough fluid to still operate, but not enough to displace the air in the lines. If you're still stuck I would send a PM to Matt@Camber-Toe. Great guy and very knowledgeable
10-23-2012, 01:51 PM | #13 | |
Rep 65
Finally somebody is feeling my pain!
I just tried to bleed this MFocker and damn there is no way I can even reach that. See pictures taken: http://www.e90post.com/forums/showthread.php?t=761695 Quote:
10-07-2021, 06:40 PM | #14 |
Rep 39
Sorry to revive an old thread but there is surprisingly not a lot of traction on the actual resolution. You can definitely bleed the slave cylinder with a manual bleed or pressure bleeder.
After 2 hours of bleeding today we figured out that only the very top right of the master cylinder is the slave cylinder reservoir. **It holds practically NOTHING.** We had to refill the entire master cylinder after each bleed to be sure we didn't run it dry again. We did it manually then, once we figured this out about the slave cylinder reservoir, followed it up with a power bleeder to make sure all the air was out. |
10-08-2021, 11:08 AM | #15 |
Rep 214
The best and easiest way to bleed the clutch is in the below video and thread. No need to pump the pedal, no need to open and close the bleeder multiple times. Just one time.
You want to pump fluid into the slave cylinder from below so that it pushes all the air UP through the system and out the reservoir (cap open). If you go the other way (push the air down, against gravity), it is very easy to run the system dry. I do not recommend this. What happens when you pressurize the reservoir is the fluid easily runs down and out of the slave cylinder and then your system is full of air. The air does not get pushed down, only the fluid runs out due to gravity. Yes, turning the bleeder screw is a bit tough but with the right wrench and angle you can turn about 1/8 at a time. It sucks, but it is not too bad. You need to get a syringe from autozone or a small oil can, fill it with brake fluid, attach it to the slave cylinder bleed nipple, open the reservoir cap, lower the fluid level in the reservoir, then push fluid into the slave cylinder until your reservoir fills up. This will push all the air up through the system and out the cap of the master reservoir. Easy and foolproof. https://www.e90post.com/forums/showthread.php?t=256352 |
10-08-2021, 12:14 PM | #16 | |
Rep 2,026
Use a socket and extension to crack the bleed valve open... then use the wrench once it's loose. I have found that it needs to be open by several threads not just 1/4 turn. |
01-05-2023, 03:01 PM | #17 |
Rep 1
Just replaced the clutch master and slave cylinder on my 2009 335i. After seeing other DIY's, was concerned about bleeding - this worked like a champ!
Getting that upper slave cylinder nut off the stud was a fun time - Not! Thanks for the reverse bleed link! |
01-08-2023, 01:55 PM | #18 |
Rep 29
I've had a lot of luck with the standard pump and release method. One thing that seems to help a lot if there is a TON of air in the system is to rapidly jiggle the clutch pedal near the top of its range to try and knock some bubbles loose. I also recommend starting with one of those handheld vacuum pumps that you can fit on the bleed nipple and using it in combination with the pump and bleed method. Once you get some pedal back, ditch the vacuum.
Lastly, to access the bleed nipple better, I usually do this with the transmission mount off, so it hangs down more. This only works if your driveshaft is disconnected, so it's most useful after doing a clutch job. Be patient and keep the reservoir topped up. It will happen eventually! |
