E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > BOV Necessary?
      05-16-2011, 01:13 AM   #1
E90Vader
E90Vader's Avatar
Drives: 2007 335i
BOV Necessary?
Just wondering if an aftermarket BOV is necessary for our cars?
once COBB comes out with there stage 2 tune, the boost will be quite high! Will a BOV increase performance or help the car in any way? Or is it just a gimmick for sound?
Not sure if the sound would even be noticeable on a Steptronic tranny?
      05-16-2011, 01:16 AM   #2
NiVeDh
NiVeDh's Avatar
Drives: '08 E90 335i, '99 E36 M3
You won't be able to hear it over your straight pipe exhaust anyway.
      05-16-2011, 01:19 AM   #3
JayKay335i
Egypt
189
Drives: ///M323 DCT
get diverter valves
      05-16-2011, 07:29 AM   #4
Penn999
Penn999's Avatar
49
Drives: 335i coupe
Its really your preference, I just like the sound. Anything is bettee than stock, exspecially if you have a tune and are running 14+psi
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
      05-16-2011, 08:30 AM   #5
X2Board
X2Board's Avatar
Drives: I'm back, bitches! '13 E92 ZCP
That was my first thought too.
      05-16-2011, 10:21 AM   #6
Syndicategt
Syndicategt's Avatar
Drives: 335i
Either a BOV or upgraded DV's will be able to hold higher levels of boost better than the stock DV's. But to answer your question, No, just adding a BOV will not increase power. You will hear it on the AT when you let off the gas pedal.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
      05-16-2011, 10:42 AM   #7
Zeph
Drives: 2008 E92 335i 6MT SGM CR/BD
+1 stock DV's are plastic with rubber diaphrams... I wouldn't even trust them on stage 1 much less stage 2! BOV's for sounds are really more noticeable in manuals
I would upgrade the charge pipe though, either way you go. The metal pipes seem to help with throttle response as opposed to the stock rubber/baffled hose. .02
      05-16-2011, 10:44 AM   #8
Willizm
Willizm's Avatar
24
Drives: 2009 335Xi and 01 Trans Am WS6
Yep, got a Tial BOV for the sake of not having to worry about my weak DV's leaking. ETS didn't have an option for DV's or I would have probably gone that route. On an AT car the sound isn't noticeable unless you are purposely goosing it and letting off.
      05-16-2011, 08:35 PM   #9
E90Vader
E90Vader's Avatar
Drives: 2007 335i
Was not sure if the stock BOV was sufficient or if I really should look into a new BOV.
Thanks for the info guys.
I read somewhere that Charge pipes were not necessary.. People are starting to think they are needed as well!?
      05-16-2011, 08:50 PM   #10
Penn999
Penn999's Avatar
49
Drives: 335i coupe
you read wrong, as i said..its been tested that anything over 14ish psi and you are going to have a slight leak from the stock DV's. they werent designed to hold boost over 6-8psi. If you have a tune you are asking them to hold twice as much psi as they were designed to hold...
      05-17-2011, 12:14 AM   #11
Toker335i
Toker335i's Avatar
65
Drives: 335i/Sold--10" GTR
I got a er charge pipe with hks bov and i love it! Get it!
10' Solid Red GTR
08' 335i 6MT - Sold
92' NA 300ZX 5speed - Sold
06 IS350 - Sold
      05-17-2011, 12:15 AM   #12
Brey335i
Drives: e46 ///M3
My stock charge pipe and DV's leaked a little... no problem after I upgraded
      05-17-2011, 07:59 PM   #13
E90Vader
E90Vader's Avatar
Drives: 2007 335i
Whats the difference between a diverter valve and a BOV? How much do Charge pipes cost + install?
      05-18-2011, 12:36 AM   #14
PeteW84
COBB'ed
PeteW84's Avatar
Drives: 13 Mini Cooper S
2008 335i  [7.56]
The main difference between the two is that DV's divert/dump the air back to the charge pipe, your stock set up. Blow off valves, on the other hand release/dump the air into the atmosphere not the charge pipe, creating the wossshh sound. Some people like the sound, some don't...
13 Mini Cooper S
08 E92 335i (SOLD)
      05-18-2011, 08:42 AM   #15
Zeph
I love the sound of some BOV's, like the Synapse... I like them as long as they don't squeel! I also like getting rid of the hot air and not re-using it. My wife, on the other hand, liked it better when it was "quiet and tame". Fortunately, it is my car.
      05-18-2011, 09:22 AM   #16
secretsquirrel
secretsquirrel's Avatar
130
Drives: f80
Way to stand up for your man rights.
I'm also in the market for a BOV or DV. Sigh, more money..
      05-18-2011, 10:21 AM   #17
domrep
domrep's Avatar
Drives: AW E93 335i
+1 on on synapse. no ricey whine.
      05-18-2011, 11:59 AM   #18
Brey335i
Drives: e46 ///M3
BOV sounds better IMO, but the price is astronomical for a good setup with a charge pipe.
      05-18-2011, 12:04 PM   #19
Syndicategt
Drives: 335i
OMG I get into this argument every time she's in my car. "Your exhaust is too loud.....wah wah wah!" "Why would you do this to your car?"
I told her if I wanted a quite car I would have bought a Prius, silent under 5 mph
FYI, my exhaust isn't even loud.
      05-18-2011, 08:14 PM   #20
PeteW84
COBB'ed
PeteW84's Avatar
2008 335i  [7.56]
The synapse sounds good, not too loud but definitely noticeable. Love mine, got the full synpse kit...
13 Mini Cooper S
08 E92 335i (SOLD)
      05-18-2011, 08:56 PM   #21
D335NUTZ
The Blue Beast
D335NUTZ's Avatar
China
142
Drives: 2008 E92 335xi in Montego Blue
I got a Tial 50mm BoV for the sound. There's no performance difference between bov and dv.
Cobb AP Stage 2+ | BMS DCI | UR Catless DP | UR Chargepipe | Tial BV 50mm | BSH OCC | ETS FMIC | Eisenmann Race Exhaust | KWv1 Coilovers | Volk TE37 TC Kline Ed.
      05-18-2011, 09:01 PM   #22
Brey335i
Drives: e46 ///M3
+ 1. Completely subjective
e90post
