Procede and too much torque
05-15-2011, 08:05 PM | #1 |
Rep 133
So I am still wrestling with how to get the most power efficiently to the ground with my procede and helix turbos. I have full bolt ons and an LSD.
I started on Map 2 with boost Control and traction control at 100 percent. I had dtc off. I found that even with dtc off BMW traction control just freaked when I applied anything but the slightest throttle. I then tried reducing boost control to 60 percent and things got much better. I finally switched to map 1 and got the best traction. In short - too much torque at a standstill / low rpms is too much of s good thing. Any suggestions on how to continue to fiddle to get better traction? I did try the procede traction control but i didn't like how the procede seemed to be fighting BMW traction control so i turned it off. Second question - I find that when I change suspension settings (mostly adjusting rebound) the BMW traction control adapts it's power delivery and wheel braking to optimize traction to each wheel. I find that the car will really hunker down after s few days of driving / adaptation. I am finding that things aren't adapting as finely with the procede. Now that said, I've been fiddling about a lot with procede maps and settings. Does anyone know if the procede interferes with the stock traction adaptation? As a side note. The helix turbos are awesome. I will do a full review soon. Also the procede has had great linear power delivery. I love the adjustability. Finally even with new turbos I still had waste gate rattle. The procede waste gate fix worked like a charm. |
05-15-2011, 08:10 PM | #2 |
Rep 1,661
I had a lot of problem with traction until I got the proper tires...go for ultra high performance summer or extreme summer performance. The Advan AD08's are the stickiest street tires I have ever driven on. Once they get nice and warm you shouldnt have problems. If that doesnt help you should look at getting m3 rear subframe bushings and m3 chassis bits.
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
05-15-2011, 08:36 PM | #4 |
Rep 1,661
nice setup! You just gotta milk it man...get on it and then ride her out.
05-15-2011, 09:38 PM | #5 |
Got Boost?
Rep 234
Wait...your traction control is kicking in with it turned off? Are you hitting it once so that the DTC symbol lights on the dash or holding it down till the round arrow symbol comes on...traction control shouldn't be interfering at all if it is off.
- - My Car Domain - -
2010 BMW 135i AT, AW, ///M Sport JB4|BMS DCI|MS 3" cattless DPs|Golf Tee|33% Tint|///M Pedals |
05-16-2011, 12:11 AM | #7 |
Got Boost?
Rep 234
hmmmm...what size tire advans are you on? We can fit a 10" wheel w/o rubbing in back, allows quite a wide tire.
05-16-2011, 12:25 AM | #8 |
Rep 133
Last step is to fit 255s / 275s font / rear. However my issue is more with fine tuning traction. I don't know how to explain it but my dinan tune and stock map definitely adapted more finely to traction to all four corners. Car felt completely balanced to all four corners. The procede seems less refined in balancing traction individually to each wheel. Again this could be because car has not fully adapted.
In short stock / ecu tune seems to better deliver power relative to grip and at the same time balance to all four wheels. I am just wondering if the procede is interfering / confusing traction control. |
05-16-2011, 08:06 AM | #9 | |
Rep 1,288
Drives: 2014 435iX, FBO
It must be really pulling .... wow.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
05-16-2011, 08:07 AM | #10 | |
Rep 1,288
05-16-2011, 12:12 PM | #12 |
Rep 5,450
Is this a stick or slushbox? When you did the LSD, what did you do for a final drive ratio?
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
05-16-2011, 01:07 PM | #13 |
Rep 1,432
05-16-2011, 08:41 PM | #16 |
Rep 133
After adjusting the boost gain I've fixed most of my off the line traction issues. Issues now are more with how the car self adjusts to traction on bumps and corners. Even st low rpms and speed the car doesn't seem to be adapting as fast or as well to optimize traction.
05-16-2011, 09:12 PM | #17 |
Rep 923
Its hard to compare how well the stock ECU handles power delivery considering how much less power there is to deal with. I would say ditch the Yokohama's when they are wore out and get some Michelin PS/2's to get a little better grip. What firmware are you running on the Procede? You shouldn't rely on the factory traction control to try and handle the power output of the tune when you are going WOT (assuming that is when you are having problems with traction). You will have to adjust the throttle input based on gear/RPM. One thing you can try is shut DSC off completely, and set the Procede Traction control to 30%. See how that feels. I believe with the current firmware, traction control will fight the DME somewhat, so Shiv is working on a fix for it so choose one or the other.
05-16-2011, 09:17 PM | #18 | |
Rep 923
05-17-2011, 09:22 AM | #19 |
Rep 133
I notice issues mostly powering through corners but also going in a straight line over bumps. The traction to each wheel is being upset by the procede. I really noticed it today in the rain. Holding any corner while applying any throttle is impossible. The car seems to be settling a bit (as adaptations settle in) but still acting strangely.
05-17-2011, 09:49 AM | #20 | |
Rep 923
