Did I install my Forge DVs in the wrong orientation?
05-14-2011, 04:46 PM | #1 |
Rep 190
In my mind it makes sense to put the outlet opposite of the nipple into the charge pipe, and have the other end routed back to the Pre Turbo intake.
I was looking at the stock DVs and they are mounted vice versa ... what am I missing? |
05-14-2011, 07:59 PM | #6 |
Rep 190
Daya installed his the same way in this thread
http://www.e90post.com/forums/showth...tt+charge+pipe super confused at this point |
05-14-2011, 08:19 PM | #8 |
Rep 502
As I said earlier you have them turned the wrong way. I have Forge DV. The top that screws on and has the nipple on it should be facing each other. Here is a pic of the older version with the nipples on the side, but the concept is the same. The CP connects to the SIDE of the DV not the end. BTW this pic is from the install instructions from ForgeMotorsports.
05-14-2011, 09:14 PM | #11 |
Rep 708
Email STETT, if that's where u got them, they will know what the products are designed for...
05-14-2011, 09:14 PM | #12 |
Rep 461
05-14-2011, 09:25 PM | #13 |
Rep 708
That pic from STETT is the same pic the OP posted..... Sooooooo OP, are you using a STETT CP or are you installing on the stock CP? Also what version of the Forge DV's are you using? The N54 direct replacement units have the nipples on the sides.
05-14-2011, 09:33 PM | #14 |
Rep 6,631
OP, your picture is correct. The Forge DVs for the stock charge pipe are installed differently than the ones for your Stett.
E90 LCI N54 6AT
05-15-2011, 01:51 PM | #15 |
Rep 563
Thats right. The first run of forge were orientated side ways. The newer design is mounted with nipple on top.
Easiest way to be sure is find the hole where you can push the flapper up. This opening goes into the charge pipe. |
05-15-2011, 02:04 PM | #16 | |
Rep 708
The versions you see standing straight up with the nipple on the end is a universal unit I believe. Both inlet and outlet have standard hose couplings, rather than a machined OEM-like clip-in fitting. |
