Can I run Map2 JB4 with the 335is safely
05-05-2011, 01:15 AM | #1 |
Rep 251
Just sitting here thinking at 2:15am...
I know map2 requires additional cooling such as a FMIC and possibly downpipes...But since 335is already has additional cooling put into place, what are the chances us 'is' guys can run this map safely, using 93oct of course... Or any of you already running Map2 with no problems? |
05-05-2011, 02:21 AM | #3 |
Rep 957
i run map 2 all the time and only have vishnu intakes. downpipes and FMIC going on the car once they arrive from jet hot though so still, map 2. i spoke to robert from vishnu on the phone its not about the temps so much with running map 2 stock settings vs map 1 but the stress on your turbos. with dci's you are now making it much easier for turbos to get that extra air to hit those higher boost targets. i run map 2 now and it feels and runs great with 93 octane. powerful. at LEAST intakes, and even more bolt ons obviously =. better.
05-05-2011, 02:46 AM | #4 |
DSC OFF!
34
Rep 230
i tried on 335i MAP2, but it feels lower power then autotuning.. And talking about can you run safe MAP 2 on 335is, answer is yes you can... no need extra fmic...
05-05-2011, 03:01 AM | #5 |
Rep 1,809
335is has the same IATs and the same EGTs as the 335i (same intercooler, the same 4 cats). You really need downpipes (to lower backpressure and evacuate hotter gases faster) and intercooler for this. Why risk it ?
05-05-2011, 03:14 AM | #6 |
Legit :)
17
Rep 369
^ this, to be sure, log and make a WOT run, if you timing drops, then you have to lower the map, just LOG and see how it goes
05-05-2011, 07:06 AM | #9 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
Map 1 or 5 for your current setup. I run Map 5 and prefer it to Map 1.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
05-05-2011, 10:02 AM | #11 |
246
Rep 3,441
^ yes
06-01-2011, 03:16 PM | #12 |
Rep 94
what if i install dci, can i run map2? do i still need downpipes or fmic? tscdennab said 335is has the same intercooler as 335i. sorry im a beginner, but doesnt 335is have an extra cooler over the 335i? I dont want to install a fmic or downpipes because i want to keep mods as simple as possible so if i wanna remove them it wont be a big problem
06-01-2011, 05:18 PM | #13 |
246
Rep 3,441
Don't run Map 2 until you have the correct mods that BMS developed it for.
The FMIC is not that intrusive of an install and makes a big difference. DPs are another story.
