E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Vishnu Gents
      04-17-2011, 05:07 PM   #1
marcvtec
Drives: M5
Vishnu Gents
Can we implement autotune with DIC soon please, this was a great feature you guys had running, on current map 2 I'm only seeing 15 psi, with autotune it was always higher.
By the time new vishnu fuel systems come running out the door it will be fall season and tracking season done at least this way we can maximize some summer time fun
      04-17-2011, 05:09 PM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
why dont you up the initial boost value if you want to boost more?????? Autotune enabled/disabled has nothing to do with it . put Initial boost 15 max boost 16 and IC 100 and see how the car goes. do some logs as well.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      04-17-2011, 05:46 PM   #3
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
You guys realize you can just log your cars to see how they are performing?
Based on ignition drop outs and ignition timing overall you can apply more boost if all is good.
Thats how things were done before autotune came about
To the OP, if you know the car can take more boost, then just apply the same settings your autotune setting normally ran.
Do a 3rd gear log from 3000 RPM to redline.
Look at ignition. If it appears to be a smooth linear line you might have more room for more boost.
General consensus for 93 Octane is 15.5 PSI FBO, 14 PSI Tune only.
16+ PSI Methanol.
      04-17-2011, 06:00 PM   #4
marcvtec
Drives: M5
I understand all these valid points
But autotune and traction control nanny are just such awesome features that cannot be ignored.
      04-17-2011, 06:01 PM   #5
E90Vader
E90Vader's Avatar
Drives: 2007 335i
What does DIC stand for?
      04-17-2011, 06:09 PM   #6
marinellie
Saving lives one shift at a time
marinellie's Avatar
Drives: 2008 BMW 335i
What does FBO mean?
2008 335i...... 6AT....Sports package.... Premium package.....Cold weather package....i Drive....Nav....Sat radio....Logic 7.....PROcede v4 auto tune....Injen Intake
      04-17-2011, 06:22 PM   #7
Beemw335
Drives: 335i
Originally Posted by marinellie View Post
What does FBO mean?
Lol and you told me last week that Im a noob because I dont have a lot of posts...... hahaha
Fbo= full bolt on
      04-17-2011, 06:27 PM   #8
Sparky66
Sparky66's Avatar
Australia
58
Drives: 335 E92 Coupe. Jet Black.
DIC = Dynamic Igntion Correction
Sticky is an Idiot
e90post
