04-17-2011, 02:53 PM | #1 |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
DIY Tools Recommendation
I plan on doing more DIY work on my cars and I was hoping to get a thorough recommendation on tools that I should be readily equipped with.
I plan on doing pretty much any basic installations and maintenance on my cars. Ideally I want to do my own suspension, brake, and maintenance work. I would love to get recommendations on the following:
Anything would be very helpful. Thanks again!
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
04-18-2011, 01:32 PM | #4 |
///M Fan
366
Rep 2,159
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
If you can afford it, I would go with Snap-On or Mac. I'll stay away from Craftsman. I would go with Kobalts too, it is part of Snap-On. I have all three of them. I have about a $6k-$7k in tools at the house, pretty much can take the engine apart and put it back together. It is worth to buy a set of good brand tools, they'll last you forever.
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
05-23-2011, 02:35 PM | #5 |
Rep 1,430
I know this is a little old, but honestly you can nearly take the car apart with a basic metric socket set, some screwdrivers, and a torx set.
05-23-2011, 04:48 PM | #6 |
Rep 293
I use Makita LXT for my cordless tools, I particularly love both of their impacts (there is a big one and a little one) the big one is good for wheels and the little one is good for suspension bits and other not-so-stuck and not-so-big parts. I recommend spending good money or a torque wrench, as they tend to need to be serviced every few years and accuracy is pretty important.
Keep in mind, the 50% point is the most accurate a torque wrench is so plan on that when buying wrenches. Torque sockets are pretty much necessary above ~60 ft-lbs, just to be safe, the chrome ones have a tendency to explode instead of to just deform like the black impact type. also, six point sockets provide the best grip to bolts on the car, and I don't think i've seen any oe 12 point bolts on the car, so try checking those out. it prevents a majority of rollover. |
05-23-2011, 08:06 PM | #7 | |
Motorsport Passion!!!
103
Rep 1,111
And also for the TQ wrench, the midpoint of a torque wrench's range is the most accurate correct?
05-23-2011, 08:20 PM | #8 | |
Rep 293
And if you are thinking about torque sticks, they only work best with air impact tools And yes, the midpoint of the wrench is more accurate (my snapon wrench after it's most recent calibration has a 1.9% error at 150 ft-lbs ( it is a 50-250ft-lbs) and a ~4% error at the 50 and 250 settings. I know, it isn't that much, but the values will begin to drift after a while and become an issue, i generally use that wrench in the 100-200ft-lb range. I got a discount on the snapon torque wrench and that's why I got it, there are plenty of other reputable manufacturers out there, the half inch drive is good for wheels and a 17mm socket is the size for OE bolts. 100ft-lbs is a good setting. EDIT: not torque sockets, brain fart they are impact sockets. |
05-23-2011, 09:22 PM | #9 | |
103
Rep 1,111
05-23-2011, 10:23 PM | #10 |
Ninja
390
Rep 4,014
if you are going to be doing some interior work:
http://www.amazon.com/No-Scratch-Too.../dp/B000LNBLTK
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
05-24-2011, 06:50 AM | #11 | |
Rep 293
05-24-2011, 08:14 AM | #12 |
Rep 1,848
With respect to car lifts - this one may not be the most affordable, but it is portable and doesn't require any special tools or power requirements.
www.ezcarlift.com |
05-24-2011, 05:05 PM | #13 | |
Rep 293
05-24-2011, 08:16 PM | #14 |
Rep 1,848
I agree. However, I will tell you this sucker is solid. I have powder coated 359M's and the first time I took them off to put on my track wheels, they were pretty much stuck to the hub. It took quite a bit of beating to get the wheels off and the scissor lift never budged.
05-24-2011, 08:29 PM | #15 | |
Rep 293
05-25-2011, 03:23 PM | #16 |
Rep 399
Should I get 3/8" or 1/2" Torx bits? Specifically I'm thinking of the Torx 50 that hold the front seats. Is a 3/8" ratchet enough for that or should get a bit for my 1/2" ratchet?
Thanks
-David
