Low Boost and Code 12543 - need help please!
04-16-2011, 01:13 PM | #1 |
Rep 502
I have a 2007 E93 that has Procede V5, Forge DV, Vishnu DCI, and ER FMIC and Chargepipe. Recently upgraded to 3-15 DIC map and had some slow boost onset issues. I emailed Shiv and he sent the new 3-30 Beta map that seemed to make things slightly better. I still seemed to have an excessive lag in building up boost. Anyway, with daily driving was not noticeable only noticed on WOT. Last weekend had my ER FMIC installed and some of you may have read my thread on that where I was apparentky sent the MT one and not the AT one. The shop I used cut and welded the driverside pipe on FMIC after needing to rotate it to get appropriate fitting with factory mount because of the AT transmission cooler that is not on MT cars. Everything seemed fine after install except for still slower than usual build up of boost. Yesterday I got 1/2 CEL one way home from work. The CANClear reset it when I stopped somewhere so I was not sure of code. When I got home I did some testing and data logs. I also switched back from 3-30 map to 12-17 map to see if that solved problem. I got code 12111...uncertain but think its "speed plausibility code" whatever that means. Still with slow boost buildup. Then I reset code and updated to 3-30 DIC map once again to see if maps have much to do with my problem. Now I got a 12543 code and my boost will not go above 7-9 psi. On the 12-17 map I got max ~9 psi and on 3-30 map i got max 7 psi. Below are 2 data logs. I am uncertain how to read them but you can see the code being thrown and the boost and slow build up of boost.
Code 12543 is "exhaust fume turbocharger low side" Could this be problem with my Forge DV? Could it be a boost leak related to recent install of FMIC and CP? If it were that I would expect a quick fix by tightening some clamps or maybe small hole in welding area of driverside FMIC. However, that does not explain my slow boost build up that was ocurring prior to FMIC & CP install. Any ideas on causes of slow boost build up and my apparent boost leak? Your help is much appreciated!! |
04-16-2011, 01:57 PM | #2 |
441
Rep 18,331
Just go back to the 12-17 maps and reset the procede in the user software as well as in the command center from 11 to 1...Also clear the codes...I also had this issue with the newer maps and I would not boost more than 10 psi...Went back to the 12-17 maps and cleared what I stated above and everything is peachy again!
It looks as though you have one of the newer DME and IMO it seems to have issues with the new DIC maps...Everytime I go to the DIC beta maps my boost goes erratic and my wastegates are jerking back and forth like a high priced hooker doing a handjob! lol If its not the maps and firmware and you eliminated this variable, then you have a serious BOOST leak and I would think its your modified FMIC...You need to check both Last edited by cn555ic; 04-16-2011 at 02:03 PM.. |
04-16-2011, 01:57 PM | #3 |
3441
Rep 79,211
You either have a boost leak and or mismatched firmware.
Make sure your firmware coincides with the maps. I believe 3-30 Maps end with PRo....102 *** All else fails try a non beta firmware and map AKA 12-17 |
04-16-2011, 02:18 PM | #5 | |
Rep 502
Car is a bit hot now after datalogs so will wait for it to cool off and check my Forge DV. I think I'll make sure everything is greased up and moving well and make sure the DV didn't pop off partly. If that doesn't work I will take it in for a boost leak test at the shop that put in the FMIC. But what to do about the V5,...which map should I run? Damn this sucks,...and of course wife is not much help when she gets mad at me for not doing the "honey do.." list and instead focusing on my car. |
04-17-2011, 02:19 PM | #7 | |
Rep 502
These pics are looking down toward IC from top of engine bay. |
04-17-2011, 02:33 PM | #8 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
That's a boost leak alright
06-30-2012, 01:51 PM | #9 |
_______
169
Rep 1,088
Were you getting this fault while running in Map 0?
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
06-30-2012, 02:07 PM | #10 |
Rep 502
06-30-2012, 04:37 PM | #11 |
_______
169
Rep 1,088
I was getting the low boost code in map 1 and not in map 0. Im still able to get 12-15 psi in map 1. I usually get the fault under normal acceleration at 5-7 psi. Just wanted to narrow down the trouble shooting. I replaced the vacuum lines and checked the DVs. I'll check the intercooler connections next.
06-30-2012, 05:01 PM | #12 | |
Rep 502
