Some fuel pump photos!
04-16-2011, 09:12 AM | #1 |
Joint Chiefs of Staff
4918
Rep 115,980
I got a few photos that you guys might be interested in with all this fuel pump talk. BMS is setting up a fuel pump voltage booster for one of their customers and took a few photos showing the fuel pump location, connectors, and contacts. The main power connector should look familiar to many of you!
Mike |
04-16-2011, 09:20 AM | #2 |
Rep 5,876
Omg
"My fuel pump brings all the boys to the yard, And their like It's better than yours, Damn right it's better than yours, I can teach you, But I have to charge" Lol Last edited by dzenno; 04-16-2011 at 09:30 AM.. |
04-16-2011, 09:33 AM | #4 |
Rep 5,876
Mike, John and i tested that already at Champion a few weeks back by applying 14V to the pump and the pump still lost pressure as measured on a FP gauge...just an FYI, good luck but I really don't think voltage will do anything
04-16-2011, 10:00 AM | #6 |
Rep 5,040
04-16-2011, 10:35 AM | #7 |
Roll Tide
591
Rep 2,345
So while Shiv is bench testing, calculating figures and considering internal turbine sizes, etc, you're just cranking up the power and taking pictures. Research is good. Do some.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
04-16-2011, 11:20 AM | #9 |
Rep 3,550
lol exactly what I was going to say..
Current:
'13 F10 535i xDrive - lightly modded for now Previous: '12 e92 M3 Melbourne Red/Bamboo - ADV.1 ADV10, Volk TE37SL, OSS, Innotech F1, Arkym, iND '09 e92 335i Alpine White/Saddle Brown - fully modded |
04-16-2011, 11:28 AM | #10 |
Rep 469
Drives: BMW 16' M3
Wow, it never ends.
04-16-2011, 11:38 AM | #11 | |
4918
Rep 115,980
Mike |
04-16-2011, 11:41 AM | #12 |
Rep 5,876
04-16-2011, 12:05 PM | #14 |
Rep 5,876
04-16-2011, 12:08 PM | #15 | |
4918
Rep 115,980
Mike |
04-16-2011, 12:08 PM | #16 |
Rep 3,460
04-16-2011, 12:33 PM | #18 |
4918
Rep 115,980
The DME runs 14 volts and varies its duty cycle to change pump speed. At full duty a volt meter will show 14v. At idle a volt meter will show around 7v. The voltage hasn't changed just the ratio of how long it was applied (e.g. the duty cycle). Here is a video showing the actual N54 low pressure duty cycle. This is why you use a real scope for investigative work before writing the white paper.
Mike |
04-16-2011, 12:34 PM | #19 |
Rep 5,876
Maybe, GeorgeSmooth could answer that question or anyone running a flash and high boost...you have cobb flash so u could do it too as a reference point..easy peasy
04-16-2011, 12:57 PM | #20 |
Rep 1,357
Drives: '08 e92 335i COBB 4.01 Stage 1
The tuning war is like the fashion industry.
Shiv comes up with the newest design and shows it on the catwalk at some fashion show. Terry is sitting at the front row drawing the sketch of the latest design of Shiv's and brings it to his shop to make a similar outfit for half-price. People then buy the cheaper one to save money. But remember, someone had to have an idea first and innovate or there wouldn't be anything to copy from... |
04-16-2011, 01:34 PM | #21 | |
4918
Rep 115,980
Mike |
04-16-2011, 02:29 PM | #22 |
been there... done that
Rep 277
Can't believe Shiv would have missed the concept that on-demand, electronic fuel pumps all use a square wave variable duty cycle to control the pump speed...strange.
