Aftermarket radiators and/or transmission coolers
04-16-2011, 12:00 AM | #1 |
Rep 1,050
So I have the ER Race Oil Cooler setup and it works beautifully. Unfortunately, since I have an AT, My coolant temps are not great and I can get limp mode due to this.
Where are the radiators for AT people that Mt folks would benefit from too? Looking for a solution, I went to the Ferrari and race care builder garage around the corner from my office and asked what they would do (they don't know the 335 that well). Here's what they said: Put in a high quality replacement transmission cooler core on top of the intercooler that is as wide as possible. It needs to be about 3 inches tall. This way it won't get in the way of the radiator too much. Should cost about $500.00 for parts and labor.Thoughts? |
04-16-2011, 09:11 AM | #2 | |
Rep 1,543
04-16-2011, 09:50 AM | #3 |
Rep 7,377
very interesting. Looking forward to some results. I need as well to upgrade the cooling.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
04-16-2011, 10:36 AM | #4 |
Roll Tide
591
Rep 2,345
I would love a transmission cooler.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
04-16-2011, 11:07 AM | #5 |
Rep 1,617
+1
I hope the tuning companies gather the increasing demand for cooling options for us guys who take the N54 around a real track.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
04-16-2011, 06:32 PM | #6 |
Rep 1,050
Turkey Baster, Please share your results. I'm between a rock and a hard place with this as I am in the process of purchasing an E36 M3 track car but it will take a while before I ever drive it on the track.
I could deal with up to 300.00 on a tranny cooler. I checked out some cores and lines and it is definitely not very expensive. I just found out my tiny little tranny cooler is leaking. It's under warranty. Have you seen how small this thing is? Crazy. |
04-16-2011, 10:56 PM | #8 | |
Rep 1,543
04-17-2011, 10:38 AM | #9 |
Rep 4,392
Why not just add a second radiator ? Of course though you will have to go through BMW for this as it does require upgrading your DME. Cost is about $2500.00
getting a larger OC and adding a second radiator should do the job ? |
04-17-2011, 10:45 AM | #10 | |
Rep 1,617
You can purchase the secondary water radiator for 500ish. No need to upgrade the DME.
04-17-2011, 01:40 PM | #11 |
Rep 1,050
I have 2 oil coolers, 1 in each fender. No room.
04-17-2011, 02:21 PM | #12 | |
Rep 1,154
ohh, keep us posted on this! A DIY would be sweet too. |
04-17-2011, 03:18 PM | #13 |
Rep 4,392
04-17-2011, 03:56 PM | #14 |
Rep 1,050
the setup I would want
Hey all, Since I ave both wheel wells occupied with oil coolers this is the setup I would want:
The AR retrofit blocks too much flow to the radiator for me but let's see how it works. Maybe the increased cooling to the tranny will offset the diminished radiator cooling. It's all on you Turkeybaster. |
06-27-2011, 05:55 AM | #15 |
Rep 7,377
bump? anyone done anything on this subject?
07-13-2011, 10:27 AM | #16 | |
Rep 66
07-13-2011, 10:43 AM | #17 |
Rep 7,377
my shop is going to install one in front of the IC and remove the OEM heat exchanger om my rebuilded AT transmission. Will post pics when done end of August.
07-13-2011, 10:57 AM | #18 |
Rep 1,050
See earlier post of mine. Wide and short core tranny cooler on top of the IC. If you don't have to block anything don't. I researched available cores and there are a few that will achieve this.
07-13-2011, 01:50 PM | #19 |
Rep 23
Might want to look at how the M3 DCT is cooled. A good description can be found here http://www.m3post.com/forums/showthr...mission+cooler.
I've worked through the same thing but haven't done anything because I haven't experienced high transmission temp induced limps yet. I currently have a stage 2 STETT oil cooler installed. If I needed to add a transmission oil cooler I would install MOCAL OT/1 oil stat in the oil line from the transmission to the original transmission oil cooler. I'd locate the new transmission cooler in the left hand wheel well or above the FMIC. The reason I'd keep the original oil cooler and have it last in the oil flow is that the original oil cooler is also used to warm the transmission (where it get cold this is important). If I needed in increase the radiator cooling I'd add in a cooler like the stage 2 STETT inside the lefthand wheel well and use the OEM pipes. |
07-26-2011, 02:38 AM | #20 |
Rep 968
Drives: 2007 335i Coupe
I'm doin the 2nd radiator fro the BMW Performance kit in the left wheel well with the VK oil cooler(found one used) in the stock oil cooler location. If the VK is not enough the AR 2nd oil cooler can be added easily in front of the stock radiator. Since the tranny fluid is tied to the water cooling system through heat exchanger I'm hoping the 2nd radiator will take care of the water and tranny temps. I will let you all know. Installing all mid August with Mtech front bumper with foglight delete and 335is scoops.
