Which Intercooler should I get?
04-15-2011, 05:42 AM | #1 |
Rep 39
I have an 08 335i. I live in Houston Heat and Im currently waiting for my Cobb Ap (Thanks to Alan************.com). BMS DCI is my only mod to my car. Im currently searching for an intercooler less than$1000 and no cutting/trimming required. I dont track my car just on & off wot.
Pls dont rectify me if this is a Thanks for your input guys! |
04-15-2011, 06:25 AM | #2 |
Rep 708
Did you search? YOU ARE BEATING A DEAD HORSE lol.
I have the cp-e intercooler and am very happy with it. It also comes with an in-line oil cooler which may be a good bonus given your climate. I'm only running the intercooler part of it and have nothing but good things to say. If you go to their website they have a white paper detailing the engineering put into the design and extensive testing. Pretty damn impressive. |
04-15-2011, 08:13 AM | #4 |
Rep 610
I picked up an ETS FMIC. It's really nice and comes with additional inlet and outlet tubing to increase efficiency over the stock tubing that most other FMIC's connect to. It's hard to say if it makes a difference, but it definitely can't hurt.
04-15-2011, 08:23 AM | #5 |
Joint Chiefs of Staff
4918
Rep 115,980
AMS is my number one seller, followed by ETS. In reality any FMIC will be a huge upgrade over the crappy stocker.
Mike Last edited by Mike@N54Tuning.com; 04-15-2011 at 08:58 AM.. |
04-15-2011, 08:26 AM | #7 |
Rep 809
04-15-2011, 10:30 AM | #8 | |
Rep 1,155
Base Line Base Line / Procede V5 Autotune Baseline / Procede V5 Autotune / ETS Intakes / ETS Charge Pipe Baseline / Procede V5 Autotune / ETS Intake / ETS Charge Pipe / ETS 5.0" Intercooler Baseline / Procede V5 Autotune / ETS Intake / ETS Charge Pipe / ETS 5.0" Intercooler / ETS Exhaust System Baseline / Procede V5 Autotune / ETS Intake / ETS Charge Pipe / ETS 5.0" Intercooler / ETS Exhaust System / ETS Downpipes Thanks! Michael |
04-15-2011, 11:50 AM | #11 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Yes, but the ETS intercooler has the highest pressure drop of them all. So your turbos need to work harder to make the same boost.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
04-15-2011, 01:24 PM | #12 | |
Rep 838
04-15-2011, 01:25 PM | #13 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
04-15-2011, 03:10 PM | #14 |
Rep 3,730
Answer: Any intercooler other than stock! There was a huge thread a year back which compared IAT's.
Ask yourself if you want to cut, use stock pipe, how much you are willing to spend. I went with ER's competition FMIC which they use on their track car. It also came with their charge pipe, which I had meth bungs drilled, a carbon fiber inlet shroud, and a Tial BOV (was cheaper than buying all that seperate).
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
04-15-2011, 03:35 PM | #15 |
Man with No Name
22
Rep 441
I thought this was true only for the older cores? ETS Michael want to comment this?
E92 335i coupe March 2007 |
04-15-2011, 03:41 PM | #16 |
Rep 1,155
Really?! The reason we may have a slightly higher pressure drop is due to our core design. Pressure drop is not a reason not to buy an intercooler. Below are 2 examples of fin design.
Above is a core with less pressure drop. The air simply passes right through the core as if the fin pack were a tunnel. ETS Core - The fins are offset and staggered which causes the air to split multiple times before reaching the outlet of the intercooler. This will result in a cooler intake air temp. ETS Core - Here is a picture of the core outside of the intercooler. This is a good example of an offset and staggered fin pack. You can tell by looking at the fin pack which intercooler is going to do a better job in cooling Hope this helps! Thanks, Michael |
04-15-2011, 03:50 PM | #19 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
04-15-2011, 03:52 PM | #20 | |
Rep 1,155
ETS Pressure Drop Graph From the graph you will see the blue line is the inlet pressure and the yellow line is the outlet pressure. WE show an average pressure drop of 1.3psi. This means the turbo is producing 15.09 psi and we are letting out 13.89 PSI. This is not a bad thing by any means. This means that the air is cooling inside the intercooler and becoming much more dense, it's still the same amount of boost it's just once the charge air is cooler it's more compact if that makes since. You will see some intercoolers have less pressure drop, but this simply means either the core is huge and has lots of flow area or the charge air is not cooling near as well. Thanks! Michael |
04-15-2011, 03:55 PM | #21 | |
Rep 5,728
Drives: 2019 M2 Competition
