Anyone else having problems with cobb on an 07?
04-14-2011, 09:18 PM | #2 |
Rep 546
I just recently installed Cobb on my 07 3 days ago an love it. No problems at all. I think the code you are seeing is one i saw when I first went Dinan stg1 which if i remember correctly was a low boost pressure i threw another one but they were both the same low boost pressure codes. BMW re flashed their stock tune and couldn't duplicate the codes BMW's turbos are kinda crap but Dinan stepped up sent me their turbos same basically just better built issue resolved after that.
04-14-2011, 09:23 PM | #3 |
Rep 1,222
I thought 30ff were caused by missing boost target, usually under boost can be caused by either a boost leak or a tuning issue? That sucks, it used to happen with the original jb3 v1-2, got worse with the temperatures increasing...hopefully it is resolved I would log and send it in to Cobb.
04-14-2011, 09:33 PM | #4 |
Rep 2,626
I've been running Cobb for a while. NO issues what so ever. Max boost is 15.5psi for a short duration then it tampers down to 13.
As stated above, 30FF is caused by not being able to build boost to the requested target. Did you install anything recently? May be a boost leak
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-14-2011, 10:08 PM | #5 |
Rep 10,587
no
04-14-2011, 11:04 PM | #6 | |
Rep 6,631
I'd contact Cobb about this issue, as it's not the first time I've heard about it either.
E90 LCI N54 6AT
04-15-2011, 09:52 AM | #7 |
Rep 190
At first I thought it was a major boost leak too, But I checked all my intercooler piping and it looks good. I can get rid of the problem after a few code clears and start and stops. The car will pull hard again for a few drives, then the problem happens again.
The weird part about is my WGDC never exceeds 70, wouldn't it go to 100 if I had a boost leak, as it is trying obtain the target load. DI might be better than Port injection, but I certain 16-17 psi is pushing the limit on pump gas. It's probably already knocking as it is, I've felt the car fall flat on its face a couple times. |
04-15-2011, 10:01 AM | #8 | |
Rep 2,626
Why don't you post a datalog of a third gear run
04-15-2011, 10:09 AM | #9 |
Rep 436
So how does the WGDC work the higher the number the more boost the DME is trying to achieve?
04-15-2011, 10:10 AM | #10 |
Rep 2,291
I saw you talking about PSI and the limits with your 3000GT above. You do realize that the PSI says nothing about an engine resistance to detonation, right? AFR is far more important. Different turbos (on different engines) can run far different PSIs on pump gas. For instance, Honda B16's can run 20-21psi on pump.
04-15-2011, 10:13 AM | #11 | |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Go see the VW/AUDI gearheads running 20+ psi on stock internals all day long.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
04-15-2011, 10:38 AM | #13 | |
3441
Rep 79,211
Stock Evo runs 20+ PSI. Throw up a log. |
04-15-2011, 10:39 AM | #14 |
Rep 339
Drives: 07 e90 335i
04-15-2011, 10:59 AM | #15 | |
Rep 1,051
As related to your knock concerns -- the detonation threshold for each engine is based on many many many variables. Boost level only plays a small part in the equation. Compression ratio, cylinder head design, spark plug choice, injection style, incoming air charge temps, and many other factors play a part in determining the detonation threshold. As mentioned, many engines run boost levels far in excess of 15-16 psi on pump gas, even from the factory. The code does seem odd and I also suspect there many be a boost leak or other issue at hand. Do you have the ability to pressure test or smoke test the intake tract on your car? Best regards- Lance |
04-15-2011, 11:36 AM | #16 |
Rep 13
I used to have a 3000GT VR4 too (loved that car) and yes in that community anything above 15psi was considered . As the other posters have mentioned, there are many factors that go into the detonation equation, but I still cringe a little out of habit every time I see something over 15psi.
04-15-2011, 12:07 PM | #17 | |
SYTFU Crew
36
Rep 1,179
Drives: 2010 Toyota FJ
check for a boost leak for sure
04-16-2011, 07:59 AM | #18 |
Rep 563
Does cobb plan a less aggressive lower boost (14 psi max) map. What boost levels you guys see with the 91 octane map
I use to love the jb3 map 3 as it was really nice around town and boost never got above 13 psi. Sold my jb3 to get Cobb but may wait until a less aggressive map is offered |
04-17-2011, 06:48 PM | #20 |
Rep 305
I have the same code. Smooth install, but not running strong. And throwing this code. I haven't installed a FMIC, but I did just replace my diverter valves and put on an aFe intake...
