E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 1 Series M Coupe stock front mount an upgrade for a 335i
      04-11-2011, 10:27 PM   #1
TwinSnails
Drives: 335i, X5 G05
I like the idea that my car as stock as possible, saves me the hassle of changing the car back to stock form before taking it into the dealer. I've been a bit hesitant to get an aftermarket IC because I'm a bit nervous as to what the dealer will think, but would like like an alternative over the restrictive stock IC. Possibly the front mount from a 1 Series M Coupe? I would imagine that Bmw would make it larger than the stock 335i IC, it definitely looks larger.
The stock 335i IC is: 7620 cm3.
Do anyone know the size of the 1 Series M coupe stock front mount? Checked real oem w/ no luck.
F30 - M Sport 335i
      04-11-2011, 10:30 PM   #2
Brey335i
Drives: e46 ///M3
I wouldn't be surprised if it was the same. They took the engine and cooling parts from the 335is / Z4 and those don't have upgraded intercoolers. We'll see soon, but I fear it might be the same.
      04-11-2011, 10:54 PM   #3
momstmg78
Drives: 335i sedan
don't believe so
      04-11-2011, 11:01 PM   #4
TwinSnails
Originally Posted by maxnix View Post
Is the 335is FMIC larger than the 335i FMIC?
i believe they are the same, but the 335is has more cooling features than the 335i.
F30 - M Sport 335i
      04-11-2011, 11:15 PM   #5
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
Forget the intercooler! I want to know if the differential from the 1M is transplantable into the 335i!
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      04-11-2011, 11:27 PM   #6
JoeyFiasco
JoeyFiasco's Avatar
22
Drives: '09 Coupe
just as much as the one from the M3 is
      04-12-2011, 11:42 AM   #7
EastBayE90
Formerly (-(ellblazer420
EastBayE90's Avatar
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
Agreed swapping that diff would be EPIC
(410whp 445ft/lbs | DCI + Meth Only)
OpenFlash OTS Stage 1 Flash | Vishnu PWM Meth Kit | Vishnu DCI| Forge DVs
      04-12-2011, 12:09 PM   #8
vasillalov
vasillalov's Avatar
1121
2023 BMW M3  [0.00]
Sure, but they must have designed new half shafts in order to fit the M3 diff into the 1M. As far as I can remember, it was the difference in the half shafts that prevents us from bolting up an M3 diff into our 335.
      04-12-2011, 12:13 PM   #9
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
Just go quaife.. Easy and works great with less maintenance. Only professional drivers would feel a slight improvement with the m diff.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      04-12-2011, 12:32 PM   #10
BMWeber
Drives: 08 135i
the whole rear end of the 1M, sub frame differential and all are identical to an M3 so transplanting a 1M diff would be the same as a M3 diff.
      04-12-2011, 01:52 PM   #11
GeorgeSmooth
GeorgeSmooth's Avatar
38
Drives: 2008 E90 335i AT
The half shafts of the M3 fit in the 335. They do not fit in the 135 as it has shorter half shafts and differently designed hubs.
The only custom thing that needs to be made is the propshaft from M3 to 335.
As for the 1m diff I am sure it will bolt in with its own driveshafts. Don't know about prop compatibility though as I believe the 1M is using a M3 gearbox so the lengths are going to be wonky.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63
      04-12-2011, 02:19 PM   #12
Blk07335i
Blk07335i's Avatar
Drives: 2024 G87 M2
Confirmed...intercoolers are the same from 335i to 335is so I would assume that the 1M has the same one.
      04-12-2011, 02:24 PM   #13
DaFish
DaFish's Avatar
Drives: 2014 435iX, FBO
They have bigger OIL coolers I believe, not FMIC.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S
      04-12-2011, 02:32 PM   #14
968tomr
Drives: 2007 E92 335i
I believe the cooling changes
Are the same changes as the 335is and z4 Sdrive 35is - new cooling fan, remapped water pump, and a secondary water radiator on the drivers side of the car. It is similar to the BMW Performance Power Kit available through BMW Performance from a cooling perspective. Very different from a drive-line perspective though.
-Tom
      04-12-2011, 03:12 PM   #15
BMWeber
Drives: 08 135i
I hate to be off topic but just a quick comment. have you researched this at all? because just about every thing you just said is incorrect. do a little research and few part number comparisons
      04-12-2011, 03:23 PM   #16
zsapphire7
zsapphire7's Avatar
Drives: 08 e92 M3
what i want is the 1M steering rack
      04-12-2011, 04:35 PM   #17
GeorgeSmooth
38
Sorry whilst you where comparing part numbers I was busy fitting the M3 diff to my car. I should of phrased it that the half shaft does not go in as deep in a 135 therefore it has not enough space to push in a M3 shaft. But what do I know.
09 C63
      04-12-2011, 04:41 PM   #18
Brey335i
Drives: e46 ///M3
Owned
      04-12-2011, 05:21 PM   #19
Ghost170
Ghost170's Avatar
Drives: VIP Sport 335!
lol..!
07 E92 335!
AA AE GP HR LC M3 KW BMS BMW LUX CYBA STRI WORK HELIX MTECH LSWEEE(Wavetrac)!
      04-12-2011, 05:39 PM   #20
BMWeber
Drives: 08 135i
I think I miss stated my point or did not give enough information. the only difference in the 335i rear and a 135i rear end is the actual hub. 335i and 135i use the same shafts, wheel carriers, subframe, suspension links virtually the same. seeing as I have fit 335i hubs to my 135i to give me the ability to use a wheel with a 10mm lower offset. and in the proses I bought the whole rear of a 335i to make sure I did not have any issues. and plan to switch to an M setup in the future and the only sure way to fit a M3 or 1M diff is to have the entire M setup subframe, diff, shafts, hubs and wheel carrier.
so my comments were in you referring to the 135i being different to the 335i and also the 1M uses the same transmission as the 135i. in general the 135i and 335i are identical under the body 95% of the parts are the same
      04-14-2011, 07:34 PM   #21
TwinSnails
lol.
F30 - M Sport 335i
      04-15-2011, 05:58 AM   #22
marconi118
Drives: 06/07 e93 335i
the 1M has the same bolt pattern as the 335i on the gearbox output flange (105mm instead of 110mm for the M3)
e90post
