E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > I've got an engine leak on my `08 E92
      04-10-2011, 12:40 PM   #1
cray1801
Drives: 2008 335i Coupe
Noticed a wet hose at the bottom of the driver's side front engine bay.
First shot is looking up from the center front of the engine looking towards the drivers side. Second picture is looking down from drivers side front fender.
Third is the leak path on the plastic skid plate.
Looks like it coming from the large hose and dripping down onto a couple smaller high pressure hoses underneath.
I took it to the dealer and they said this was within the normal as far as leaking. Am I loosing boost pressure with this leak?
The engine seems to loose more than typical power above 5500rpms. I know power rolls off but I don't think to this extent.
Dealership did replace three injectors and the low pressure fuel sensor. Have not driven enough to tell a difference yet.
Thanks, Craig
      04-10-2011, 12:50 PM   #2
KyLu II
FREE DREAMK
Dominican Republic
162
Drives: the shiiit!
2011 Lexus LFA  [3.76]
This is defetnely NOT normal. Take it to a diffrent dealer
      04-10-2011, 01:02 PM   #3
acdHQK713K
acdHQK713K's Avatar
Drives: Car
Oil filter housing gasket.
      04-10-2011, 01:18 PM   #4
cn555ic
cn555ic's Avatar
Drives: 335i
It looks like the charge pipe is leaking oil...possibly blow by oil...
      04-10-2011, 01:22 PM   #5
acdHQK713K
acdHQK713K's Avatar
Drives: Car
Too much oil for that.
It's the gasket.
      04-10-2011, 02:27 PM   #6
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
Typically the oil filter housing leak isn't just located in that one spot-it follows the front of the engine and spreads out. Are you sure it's not from previous repairs on a hpf replacement and the tech made a mess and didn't clean up properly? Some seepage out of the charge pipes is acceptable but that's alot of leakage if that is indeed what's leaking. Clean the area and monitor it
      04-10-2011, 03:01 PM   #7
KyLu II
FREE DREAMK
Dominican Republic
162
Drives: the shiiit!
+1 on this, My cp leaks oil only when i run higher than stock boost, but like someone else said looks like too much oil for that...
      04-10-2011, 03:19 PM   #8
Turkeybaster115
Drives: 335I
+1
      04-10-2011, 03:21 PM   #9
cray1801
I really looks like it's from the charge pipe. Dealer cleaned it up so I'll keep a lookout on it. If it is indeed it's coming from the charge pipe would this reduce boost?
Previous owner said, right after all paperwork was done for the vehicle transfer, that he had to add a quart about every 7K miles! He also said he had it changed every 14K miles, factory recommended interval he said...
      04-10-2011, 06:39 PM   #10
acdHQK713K
acdHQK713K's Avatar
Drives: Car
Depends on where the gasket is damaged.
That is a lot of oil from a charge pipe. My money is still on the gasket. His car isn't young either.
      06-25-2013, 08:20 PM   #11
cray1801
Follow-up:
Well after another two more oil changes and about 15K miles, I saw some oil when I removed the lower panel.... but much less oil than before. Took it to the dealership (with pictures) and they replaced the intercooler piping under warranty (~$520 in parts I'm told).
I also had them walnut blast the intake, definitely runs stronger.
      06-26-2013, 01:50 AM   #12
Ovitrix335
Ovitrix335's Avatar
Drives: Bmw 335i
My oil filter housing gasket was leaking pretty bad, it made a mess everywhere. All bmw i owned i had to change the vcg gasket and the oil housing gasket. For some reason bmw can't get these gaskets right from the beginning...Loll
      06-26-2013, 03:40 PM   #13
N54King
King of the road
N54King's Avatar
18
Drives: E90 335i
Its deff the gasket ... check the front of your block you should find more evidence of it running down
Jet Black / Pre lci E90 / 6mt / FBO /
e90post
