Procede v5 installed - clutch slip?
04-07-2011, 02:06 AM | #1 |
Rep 645
Hello,
i just installed procede v5. i hit one of the steering wheel stalks by accident, and sometimes in 6th gear when i go WOT, the rpms jumsp without making power. it feels like the clutch is slipping but i don't smell the clutch burning. i hit the stalk again, and it it won't do it for the time being, but sometimes out of no where during wot it would do it again? anyone have any idea what it could be? i also read that you should be unplugging the battery everytime you install/reinstall the procede or else it would log a tuner code within the DME that is hard to reset, is thsi true? any help is appreciated.
BMW E92 335i
retired: 04 BMW M3 | 05 Honda S2000 | 03 BMW 330ci | 01 Honda Prelude | 99 Acura Type-R |
04-07-2011, 02:13 AM | #2 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Also, you don't need to unplug the battery every time to install/reinstall the Procede. You can simply reset the DME and clear all codes/reset adaptations through the Procede's command center which takes just a few seconds. Shiv |
04-07-2011, 02:18 AM | #3 |
Rep 645
Thank you Shiv. so does this mean my clutch is done or can i drive with this clutch for a bit longer and maybe lower the boost value (what you mean is "start boost %" right??). I installed the v5 and left the default settings for a stock car, and this is too much?! lol i even lowered maximum boost to 14.
it is probably not performance oriented enough to handle the mighty procede v5 my car is at 77k kms on the first clutch. fyi - I just recently had the dealership warranty a brand new manual transmission...apparently it wouldn't stop leaking oil so they replaced it. i had v4 before then and never any slippage. now that i got my car back, i was excited to put my v5, and once i did it would slip on 6th gear only and a few times in 3rd gear. I wonder if it has anything to do with the job they have done or is it really time to get a new clutch?! thanks,
BMW E92 335i
retired: 04 BMW M3 | 05 Honda S2000 | 03 BMW 330ci | 01 Honda Prelude | 99 Acura Type-R Last edited by 3coupe; 04-07-2011 at 02:33 AM.. |
