335i oscillations in decel under power after Catless install
04-07-2011, 01:11 AM | #1 |
Welcome to the Thunderdome!
13
Rep 141
Setup: 2008 E90 335i, FMIC, Catless DP, DCI, and Vishnu V5.
Problem: While decelerating under power (still in gear) car begins to oscillate between a normal decel, decreased power and then back to normal decel.....oscllate fore and aft instead of a smooth decel. Of course no problem in neutral. Problem is worse down hill in gear. First noticed it after AR catless DP install. I've been back to the shop to check for leaks, install, etc. everything is good with the install. Anyone see this before after catless install? |
04-07-2011, 03:24 AM | #3 | |
Rep 7,377
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
04-07-2011, 03:28 AM | #4 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
I suspect your o2 sensors were re-installed reversed. Which will cause an off/on power issue as the engine cycles rich-lean-rich-lean. But it should trigger some codes after some driving.
04-07-2011, 11:12 AM | #5 |
13
Rep 141
Thanks for the help...No codes present, Map DIC 3-30....would Vishnu autoclear clear all codes associated with DP's or just select ones?...should I shut clearing off and see what pops up? Is there anyway to tell by looking which o2 sensor is which?
2008 e90 335i, Vishnu V5, DCI, PWM METH, AMS FMIC, AR catless, BMS o2 sim, and HKS exhaust.
04-07-2011, 11:18 AM | #6 |
13
Rep 141
Had same issue in previous maps (12-17) and stock with V5 removed...
04-07-2011, 11:20 AM | #7 |
1737
Rep 17,960
Drives: A Lot
04-07-2011, 11:13 PM | #8 |
13
Rep 141
Well, installer marked'em during the install to make sure he didn't install them backward, so probably not the case.....
could it be the o2 sensor is on it's way out.....couple weeks ago (prior to catless dp install) got misfires in 5&6 cylinders, cruddy plugs changed them out.....problem solved.... Doesn't bank 2 o2 sensor control these cylinders.....Could it be I had bad o2 sensor that was exacerbated (from my word of the day calendar) by the catless DP install? |
04-07-2011, 11:42 PM | #9 |
Roll Tide
591
Rep 2,345
I have the same oscillation. It seems like power kicks out then kicks back in. I noticed it a lot today while on a 85mph road trip, especially going downhill. We also marked the o2 sensors for the install.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
04-08-2011, 12:05 AM | #10 | |
13
Rep 141
Is there any data log way to check if o2 sensor is crapping out....like voltage or anything? I data logged it 2 weeks ago and it oscillated every second or so between .039 - .843.......normal? |
04-08-2011, 12:19 AM | #11 |
Roll Tide
591
Rep 2,345
Yup letting off the gas is when I noticed it most, too. Pop the car in neutral and no more oscillations (obviously).
04-09-2011, 03:41 PM | #12 |
13
Rep 141
Was using Vishnu as o2 modifier before harness upgrade, I just sprung for BMS o2 sim v3....well see if that makes a dent...
04-09-2011, 06:27 PM | #13 |
Roll Tide
591
Rep 2,345
I doubt that will as the ECU still uses the values from the o2 sensors, just the fix or CANclear removes the codes. Someone correct me if I'm wrong. When I get back from vacation Tuesday I'm going to swap the plugs and see if that helps. Shouldn't take but a few minutes (including removing/replacing underpan) to swap the harness plugs. I seem to recall they're right next to each other. Maybe try that first?
04-15-2011, 03:33 AM | #15 |
13
Rep 141
Installed BMS o2 DP fix (o2 simulator v3) today, problem solved, or at least masked...........for now it's smooth on stock tune and very very smooth 3-30 DIC. Seems to have leaned out the car quite a bit.....Plugged it right into the vishnu procede v5 harness 19, 20, & 23 pins.......the v5 o2 modifier occupied the 19 & 20 pins...sure someone can shed some light on what feature occupies 23 pin on yellow harness. Full day of driving with v5 CANclear function disabled, hard pulls, no codes, and no interference w/procede.
