E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > heat issue???
      04-06-2011, 11:33 AM   #1
klaasjoe
Drives: 2007 bmw 335i sedan
heat issue???
Hey guys pretty new here and just started modding my 07 335. last month I put on the jb4 with no issues and running map 1 which raises the boost a little. Yesterday I did an afe intake and cpe/tial bov and it seemed like after I installed it and drove the car the temps went up about 20 degrees??? I dont really remember what they were before but now it is like 230-240. I am pretty sure it was running at 220 or less before. Any advice would be greatly appreciated
2007 335I sedan (jb4,tial bov,afe intake)
01 cobra (novi 2000,nos,aftercooler,550rwp)
92 supra (1jz,regulus body kit 353 rwhp)
99 disco2 dd
93 probe
      04-06-2011, 11:50 AM   #2
phazedkid
e92
Drives: e92
maybe it's hotter in LA recently than it was a month ago? Or maybe now you run your car harder to hear all the glorious noises your intake/bov make? Or maybe you did a couple of hard pulls, which will raise your engine temp higher than if you were just cruising?
it's hard to point to one factor without holding everything else constant. but 230-240 is well within the n54's normal operating temperature, especially in warm/hot weather. So I don't really think you have much to worry about here.
      04-06-2011, 02:36 PM   #3
klaasjoe
thanks for the advice....Are there any cooling mods besides the oil cooler. I cant seem to find any radiators or fan upgrades???
99 disco2 dd
93 probe
      04-06-2011, 02:39 PM   #4
blacknbean
Drives: e92 335i 6MT
240 is right in the middle and 100% normal. when you get close to 300 thats when the ECU starts complaining and will put the car in limp mode before you can damage anything. nothing to worry about.
      04-06-2011, 02:44 PM   #5
Bobble
Bobble's Avatar
Drives: Whatever POS the wife leaves
BMW power pack includes an extra radiator and cooling pieces but that's part of the package. MR 5 was toying with retrofitting just the cooling bits but not sure how far or what success he's had with so I defer to him. At one time I thought I remember AMS bringing an upgraded radiator to the platform but have not seen that either so hit either of those two sources up. BTW the temps you are referring to on the gauge cluster are oil temps which I assume you knew so to get cooling temps to read out you'd need the performance wheel or be data logging and displaying which your JB can do for you.
      04-06-2011, 02:51 PM   #6
jdbretz
jdbretz's Avatar
51
Drives: '18 X5d, '12 M3 ZCP, '12 F30
The temperature you seeing is not your coolant temp, it is your oil temp. You don't need any radiator/fan upgrade. That is why you can't find any because they are not necessary for daily driving. The stock ones are effective. If you plan on tracking your car, you may consider upgrading your oil cooler (assuming you have the stock one install). If you don't have a stock oil cooler, and you are seeing oil temps consistantly around 270 or above, then you probably want to consider buying one if you plan on pushing the car.
      04-06-2011, 03:30 PM   #7
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
230-240 is normal operating temp
      04-06-2011, 03:40 PM   #8
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
What you're seeing is not excessive... and probably you're pushing your car harder
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
      04-06-2011, 04:09 PM   #9
klaasjoe
Sweet thanks for all the advice you put my mind at ease. I will log it with my jb. totally forgot about that feature. sorry for the lame question but all my other cars the temp needle always stays at halfway so when I saw it yesterday i was freakin out since it is my wifes dd
99 disco2 dd
93 probe
e90post
