E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Question about ipod adapter
      09-29-2005, 06:33 PM   #1
sharadrai
Drives: 2006 325
Ok I'm 7-8 days away from getting my e90. So I wanted to get everything before hand and the first thing was the adapter for the ipod. I have NAV on my e90. NOw I was going to order this.
http://store.sik.com/merchant.mv?Ses...egory_Code=AAi
Do I need anything on top of this? Like any other wire ? From the photo it seems I would need a male/male wire? WOuld this by itself fit the aux input ?
Or I was considering this
http://catalog.belkin.com/IWCatProdu...duct_ID=149006
but in this case I know I need to but more stuff and its more costly.
Thanks in advance. Any other suggestions are welcome to. I tried to search but could not find specific answers to my questions.
      09-29-2005, 06:36 PM   #2
cdheaven
I'm Starving , So I Guess You Are What You Eat
cdheaven's Avatar
229
Drives: 2006 325i
i have never seen anyone use this, the charger part might be too tall. i would go wit the monster one, its like 10 bucks more and its been proven here to work well, do a search, you will find the thread
2006 325i Sparkling Graphite Metallic-Black Leatherette
Navigation-Bmw Assist Automatic-Xenons Carbon Fiber Front Lips-Aluminum Pedals Power/heated Front Seats
5% Tint all around 30% On windshield all the way down
      09-29-2005, 06:41 PM   #3
LEDZEP
LEDZEP's Avatar
417
Drives: 2009 E70 & 2011 F25
I use this one: http://www.sik.com/ram_din.php
And this one: http://www.monstercable.com/productPage.asp?pin=2132
The one you show has the advantage of one iPod connection, but you'll still have to get the 1/8"-1/8" audio cable. I chose the two above because I like the single right-angle audio 1/8" direct to iPod, and also it's not good to charge the device constantly. When mine needs charging I switch to the charger and a separate cable.
That said, the one you've selected will work nicely too.
I think it is bad luck to be superstitious
      09-29-2005, 06:45 PM   #4
noflash
Captain Caveman
noflash's Avatar
148
Drives: '06 325eyeyiyi
2006 325i  [0.00]
If you use the Belkin charger you only have ONE wire going to the Ipod.
A small aux cord plugs into the base of the charger, not up by the ipod.
Costs same as Monster.
Got mine at CompUSA.
E90 325i Monaco Blue, Black Leatherette, Sport, Cold Weather, Xenon, Sat Prep, 18" BBS RGR
Mods: Polorized Film for Business CD, added lumbar, rock chip on hood
      09-29-2005, 06:52 PM   #5
LEDZEP
LEDZEP's Avatar
417
noflash - how does it fit clearance wise? Does the armrest cover close OK with the charger there?
      09-29-2005, 06:52 PM   #6
sharadrai
Drives: 2006 325
This is great guys for all the info. Now why do u say charging all the time is not good..does that affect the battery life.... bcos if this is the case I think your solution is the best since all others while charge the ipod all the time....
      09-29-2005, 06:55 PM   #7
sharadrai
Drives: 2006 325
Also I was looking at your solution. So the cord on the charger hooks into the 6-pin FireWire port (female) on the ram din ??? Is that right ?
      09-30-2005, 02:28 AM   #8
puck724
COLTS 4 LIFE!!!
puck724's Avatar
Drives: 2006 330i
2006 330i  [0.00]
i use the sik adaptor with an AUx cable and the griffin airclick...its great. i have a pic of my setup in the photos area under PUCKS PICS...
2006 330i --sapphire black--black leather --alumminum trim --premium package --cold weather package --park distace control --automatic transmission --navigation with iDrive
      09-30-2005, 07:20 AM   #9
MCS
e90 newbie
35
Drives: 2012 M3 E93
2006 330i  [0.00]
I got the Belkin and it works like a charm. They're being auctioned on eBay for about 5-6 bucks apiece. The audio cord that plugs into the unit and to the AUX port can be purchased at radio shack.
Sound is great. Wish they carried forward the e46 integration with Ipod.
E93 IL Blue M3 ZPP, ZCW
      09-30-2005, 10:50 AM   #10
cosmosblau
cunning, baffling, powerful
cosmosblau's Avatar
19
Drives: '08 BMW 535i
2006 325i  [0.00]
You definitely want the Belkin. Here's why:
•Only one cable into the armrest (from the power adapter, you need a short mini to mini cable, available at radio shack)
•Adjustible volume to raise the input level (which you WILL need)
•It FITS the e90
•It's available in BLACK:
http://catalog.belkin.com/IWCatProdu...duct_Id=193794
2013 328i Alpine White Black Leather Sport Line Premium Pkg SprintBooster
      10-01-2005, 02:06 PM   #11
AskNiko
AskNiko's Avatar
Drives: E90 325i + 4Runner
06 325i  [0.00]
My iPod Solution
Here's my iPod solution.
1. I bought the Monster Cable through eBay for $32 delivered.
2. Bought a 6 ft. audio cable from Target for $5. I couldn't find a shorter cable.
3. Routed the audio cable inside the coiled power cable. I had to splice to shorten the audio cable because it was too long.
I normally have the iPod laying on the passenger seat while I'm driving and hidden when I have the car parked.
I also found out that it is best to connect from the audio output from the power cable vice the audio output on the iPod so you don't have to adjust auxillary volume input settings.
|U.S. Spec. 325i | 6 Spd. Manual | Titanium Silver | Black Leatherette | Aluminum Trim | Sports Package | Xenons | Sat. Prep. |
      10-03-2005, 01:01 PM   #12
AC
AC's Avatar
Drives: SG 330i
I've had problems on my e90 with the Belkin autokit. Too much hum/distortion. Think it had to do with the power outlet. Tried 2 identical Belkin autokit and both gave the same results. I've used the Belkin autokit on my other car, and it had no problems, so it might be specific to the e90. I am using a 4G ipod (no photo). You might get different results from different versions of ipod.
A quick comparison can tell you whether there is a problem. First, connect up Belkin, and have your ipod play a track through it. Then remove the connection to the Belkin, and plug the input via the headset jack. If the audio from the headset jack sounds better than the Belkin line-out approach, there is a problem.
Ended up going with a purely line-out approach (SendStation PocketDock Line Out USB) and it sounds great!!! Only thing is that it does not include charging.
      10-03-2005, 04:04 PM   #13
AskNiko
AskNiko's Avatar
06 325i  [0.00]
No hum/distortion with my Monster Cable using the audio out on the charger.
The audio out on the actual iPod also didn't have any hum/distortion but I had problems adjusting the auxillary input levels to match with the radio and cd player volume levels.
      10-03-2005, 04:18 PM   #14
AC
AC's Avatar
Drives: SG 330i
[QUOTE=AskNiko]No hum/distortion with my Monster Cable using the audio out on the charger.
QUOTE]
That's good to know. Could the line amplifier on the belkin which is distorting due to dirty power supply. Maybe I should give the Monster Cable a try.
      10-03-2005, 05:48 PM   #15
cosmosblau
cosmosblau's Avatar
19
2006 325i  [0.00]
There is no hum on the e90 with the Belkin for me with my 3G or my wife's 4G iPod. Sound quality is excellent. The Line is silent.
Perhaps your car is defective.
      10-03-2005, 07:01 PM   #16
theclay
theclay's Avatar
20
Drives: '06 330i
2006 330i  [0.00]
I would go with monster. IMO belkin products are cheaply made, I have never had a good experience with their products.
Jet Black, Black Leather, Aluminum Trim, Sport, Premium, Steptronic, 35% tint
      10-03-2005, 08:34 PM   #17
noflash
Captain Caveman
noflash's Avatar
148
2006 325i  [0.00]
But Belkin has one cord!
Monster has two!!
That sold it for me. My Belkin sound great and what's to break? It's a cord?!?!
To each his own. I love my setup (and I am afraid of monsters!).
I'll have to take a pic. Sit's perfectly below the shifter. I have one of those sticky suits for my ipod and it couldn't fit better.
      10-03-2005, 08:45 PM   #18
AC
AC's Avatar
Drives: SG 330i
Could very well be. Never tried the ipod setup in another e90.
I have use the belkin setup before on my other car, and it is a really sweet solution with only 1 cable, and hooks up nicely to the ipod. Unfortunately it did not work in my e90.
Do you guys have i-drive/Nav as well? Wonder if it's sharing the same power source.
      10-04-2005, 01:44 AM   #19
cosmosblau
cosmosblau's Avatar
19
2006 325i  [0.00]
No iDrive on my car.
      10-05-2005, 09:41 AM   #20
MCS
e90 newbie
35
Drives: 2012 M3 E93
2006 330i  [0.00]
I use the Belkin cord with no audible sound defects with iDrive/Nav. Great solution in my opinion.
e90post
