2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 2011 550ix M Sport Wheel Size Question
      03-16-2011, 07:00 AM   #1
ikegram
Drives: Acura
Question 2011 550ix M Sport Wheel Size Question
The standard rim for this model is the 19" 351 M Wheels. What are the actual size specifications for this wheel?
I'm interested in replacing these rims with a set of Hartge Classic II rims of the same size. Does Hartge make a matching size in the Classic II's?
Assuming that Hartge has the Classic II in the same wheel size, could I install the tires that come with the 550ix on these wheels?
Thanks for any assistance offered.
      03-16-2011, 08:00 AM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
CB 72.5mm
5*120 bolt pattern
M14 x 1.25 bolt
19" BMW 351M
Front & Rear alloy wheels: 19x8.5" ET33 Tires: 245/40/19
Wheel part number: BMW 36117842652
20" Hartge Classic 2
Front & Rear alloy wheels: 20x9" ET30 Tires: 255/35/20
Wheel part number: HAR 36650940
19" Hartge Classic 2
Front & Rear alloy wheels: 19x8" ET37 Tires: 245/40/19
      03-16-2011, 08:27 AM   #3
ikegram
Drives: Acura
Thanks Bobblehead for the prompt reply.
Question...looks like these 19" Classic II's would be close to the standard rims:
However I noticed 2 specs that are different:
1. The 19" Classic II's rims are 8" wide compared to the standard 8.5" rims. Any issues with them being a .5" less? Need any offsets?
2. The tire specs for the 19" Hartge's are ET37's vs. the standard ET33's. What's the difference? Can I use the ET33's that come standard with the Hartge 19"?
      03-16-2011, 09:04 AM   #4
bobblehead
bobblehead's Avatar
Drives: warp speed
The 245/40/19 should fit the Hartge 8" wide without any issue. Offset - as indicated.
Offset is only refer to the rims ... has no relation to the size of the tires.
Based on the Hartge spec. - (in comparison to the stock spec.) .... The new wheel setup will give you:
4mm closer to the suspension/brake component - which is within acceptable allowance to clear the mentioned.
Before you proceed to buy the rims, you should also double check with the wheel/tire shop to make sure of any (brakes/suspension) clearance issue.
      03-16-2011, 09:35 AM   #5
ikegram
Drives: Acura
Thanks!
      03-16-2011, 09:58 AM   #6
bobblehead
bobblehead's Avatar
Drives: warp speed
those 19" Hartge goes for $750US a piece. or are you going for the replica ?
      03-16-2011, 01:05 PM   #7
ikegram
Drives: Acura
Planning to buy the real thing.
