DIY: Parrot Bluetooth car kit installation with Steering adaptor
03-06-2007, 01:22 AM | #1 |
Rep 236
Part I – Head Unit removal.
To remove the head unit (non-idrive), follow these instructions: To take out the head unit, you will have to remove the element with the heater and a/c controls in it first, this is fastened with two clips on the sides: 1. Take an old Flat plastic tool(cooking pry) in a 60 degrees angle on left side. Do the same on the right side 2. The a/c control unit should move forward a bit. Repeat step 3 for both left and right side - you should now be able to pull the a/c controls forward. 3. Use a screwdriver to remove the two screws beneath the head unit and pull the it forward. Where the panel came from (screws of head unit are visible) Last edited by bmviz; 04-21-2007 at 11:39 PM.. |
03-06-2007, 01:24 AM | #2 |
Rep 236
Part 2
Part II - Microphone installation:
1. Microphone pickup quality depends on the mic physical location. 2. Run microphone cable to the left side and down under the driver door weather rubber strip. 3. Unscrew three torx screws under the steering wheel panel and run the cable to the middle section of the console. |
03-06-2007, 01:31 AM | #3 |
Rep 236
Part 3
Part III – Connects2 Adapter installation with fiber Amp
1. Route the car connector and male side of Connects2 harness to the lower opening and install head unit back. 2. Insert the Fiber Block to the Connects2 harness. 3. Position Parrot control unit (under the steering wheel) and run cable between it and adapter. 4. Connect white 12 pin connector of cable TEL66 (TEL84 for 3100) to socket C on the Conencts2 interface. 5. Connect white 4 pin connector and 10 pin connector to the CK3000 module (TEL85 to socket A for Ck3100) 6. Connect Parrot Ck3100 control pad to the 4 pin connector on TEL83 (Or LCD of 3100 to socket B on the Connects2 interface 7. Close the panel and verify that new cables are not covering the A/C air ducts. 8. Finalize Parrot control pad location in your can and enjoy. Links: IM me for more information BTW: I got couple BMW extra adapter and some MBZ that need to go.... free shipping in US. Last edited by bmviz; 08-21-2009 at 05:53 PM.. |
03-07-2007, 02:56 AM | #4 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
Great DIY. Thanks for sharing
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
03-07-2007, 04:13 AM | #5 |
Rep 108
Recently I"ve mounted CK3000 evolution. But my microphne is near the lamp.
Because on the mirror my voice wasn't clear enough. But your place for microph. looks better. Microphone: And here is the Parrot's 3000 control Last edited by Rufio; 03-08-2007 at 10:10 AM.. Reason: Added photos |
03-07-2007, 07:03 PM | #6 | |
Rep 236
I guess parrot microphone designed to be in open space and after moving it to current location it performing MUCH better. |
03-09-2007, 04:30 PM | #7 |
Rep 236
news
I just found out that the Connects2 and Parrot BMW Bluetooth has a parts approval from BMW South Africa.
see BMW Parrot Bulletin attached. |
12-05-2007, 11:44 AM | #8 |
Rep 172
06-18-2008, 08:04 AM | #11 |
Rep 967
Drives: E92 335xi, 2010 Boxster S
Unfortunately no, at present time Parrot only works with non Logic7 systems
06-18-2008, 08:55 AM | #12 | |
Rep 152
I have an e90 335i with logic 7 and i have a parrot ck3100, with a parrot multican steering wheel adapter working PERFECTLY. The ck3100 was installed by the bmw dealer prior to me taking delivery of the car in April 07. I installed the multican myself just last month. (they did not use a connects2 adapter) |
09-22-2008, 01:29 PM | #14 |
Rep 2
Where did you source your ignition live from?
Just trying to install an M6100 I have perminant live but cannot source ignition live. Based on your photo I have exact same stereo as yours. |
10-25-2008, 03:32 PM | #15 |
Rep 2
11-10-2008, 06:09 PM | #17 |
Rep 267
with the correct iso connector,(im thinking about the ck3000)is it simply a case of connecting it all together,or do the cars wires have to be cut,at any stage.i have pro nav also,so does that mean the instalation will be different.
11-10-2008, 07:00 PM | #18 |
Rep 1,699
anyway to hook this up with the steering wheel controls?
Current: 10' E90 Jerez M3 DCT
///Mods: Xpel front clip wrap, Nokya 2500k H8 halos, matte grills, IND reflectors, scoops, MS drop-in, MS track pipes, Dinan exhaust, 240E, ESS tune, BBS CHR, s04 255x35 295x30, KW Clubsports, ceramic pads Retired: 08' E92 328i JB 6mt 212 rwhp 190 rwtq |
11-10-2008, 11:35 PM | #19 |
Rep 24,685
Drives: '04 330i ZHP
i have the ck3100... wish i woulda gotten the 3000 cuz its small enough to mount in the ashtray with some molding clay. couldn't get the 3100 in there.
anyone have any good spots to remount where its not out in the open? mine is right above the hazard light button on the black trim using 3m velcro (like from an ipass/ezpass) similar to this. |
11-15-2008, 02:50 PM | #21 |
Rep 24,685
i did from hfvt.com
03-21-2009, 09:58 AM | #22 |
Rep 33
I thought with the steering wheel adaptor there's no need to have the ck3000 showing...i'm trying to have this be as close to OEM as possible. Can someone please let me know if; with the steering wheel adaptor to allow control with via the buttons on the wheel, there is a need to have the small parrot control switch showing as almost all of the above posts show?
Tags |
ck3100 |
